more messages
Jan 9 15:38:58 findhostd: si_pid=[14002], process=[/bin/sh]
Jan 9 15:38:58 findhostd: si_ppid=[14001], process=[sh]
Jan 9 15:38:58 findhostd: findhostd.c:51(FHOSTDExit) exit on signal[10]
Jan 9 15:38:58 root: /usr/syno/etc/rc.d/S98findhostd.sh stop findhostd
Jan 9 15:39:01 kernel: nfsd: last server has exited
Jan 9 15:39:01 kernel: nfsd: unexporting all filesystems
Jan 9 15:39:01 kernel: RPC: failed to contact portmap (errno -5).
Jan 9 15:39:02 scheduler: scheduler.c (1297) Got signal. Die gracefully.
Jan 9 15:39:02 scheduler: scheduler.c (1315) rTorrent is killed.
Jan 9 15:39:05 syno_poweroff_task: lvm_poweroff.c:52 Failed to /sbin/vgchange -an > /dev/null 2>&1
Jan 9 15:39:32 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Jan 9 15:39:32 kernel: DS406-0: Swapping erase regions for broken CFI table.
Jan 9 15:39:32 kernel: Mac1: ************
Jan 9 15:39:32 kernel: vender Mac1 checksum error ucSum:0x00 Buf:0x00 Sum:0.
Jan 9 15:39:32 kernel: Vender partition MacNum:1 retlen:128
Jan 9 15:39:32 kernel: Serial Number: ********
Jan 9 15:39:32 kernel: raid6: int32x1 29 MB/s
Jan 9 15:39:32 kernel: raid6: int32x2 45 MB/s
Jan 9 15:39:32 kernel: raid6: int32x4 51 MB/s
Jan 9 15:39:32 kernel: raid6: int32x8 48 MB/s
Jan 9 15:39:32 kernel: raid6: using algorithm int32x4 (51 MB/s)
Jan 9 15:39:32 kernel: arm4regs : 429.200 MB/sec
Jan 9 15:39:32 kernel: 8regs : 369.200 MB/sec
Jan 9 15:39:32 kernel: 32regs : 513.600 MB/sec
Jan 9 15:39:32 kernel: raid5: using function: 32regs (513.600 MB/sec)
Jan 9 15:39:32 kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 9 15:39:32 kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Jan 9 15:39:32 kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Jan 9 15:39:32 kernel: VFS: Mounted root (ext2 filesystem).
Jan 9 15:39:32 kernel: ds107+_synobios: module license 'Synology Inc.' taints kernel.
Jan 9 15:39:32 kernel: Brand: Synology
Jan 9 15:39:32 kernel: Model: DS-107+
Jan 9 15:39:32 kernel: synobios: unload
Jan 9 15:39:32 kernel: EXT3-fs warning: checktime reached, running e2fsck is recommended
Jan 9 15:39:32 kernel: VFS: Mounted root (ext3 filesystem).
Jan 9 15:39:32 s62_synocheckapple: SYNOCfgICheckApple(124): format error: szBuf = ***** -tcp -ddp -uamlist uams_dhx.so,uams_noguest.so,uams_clrtxt.so -nouservol
Jan 9 15:39:32 s62_synocheckapple: SYNOCfgCheckApple(169): Apple Network configuration file format error!
Jan 9 15:39:33 s62_synocheckapple: SYNOCfgCheckApple(174): repair Apple Network configuration file successful!
Jan 9 15:39:33 kernel: EXT3-fs warning: checktime reached, running e2fsck is recommended
Jan 9 15:39:39 scemd: modules/disk_hibernation.c:79 Force hibernation enable, idle minutes 10
Jan 9 15:39:39 scemd: modules/raid_sys_volume_check.c:361 This model is not support raid system
Jan 9 15:39:39 synousbdisk: RCClean succeeded
Jan 9 15:39:48 load [local] UPDATE: trigger.c (97) Failed to attach shared memory.
Jan 9 15:39:49 kernel: Got empty serial number. Generate serial number from product.
Jan 9 15:39:49 load [local] UPDATE: trigger.c (97) Failed to attach shared memory.
Jan 9 15:39:50 load [local] UPDATE: trigger.c (97) Failed to attach shared memory.
Jan 9 15:39:50 scheduler: file.c (30) Failed to readlink [/var/services/download]
Jan 9 15:39:57 synorcd: hw_raytac.c (126) failed to open /dev/usb/hiddev5 (No such device).
Jan 9 15:40:34 afpd[2362]: ******:AFPServer@* started on 65280.211:128 (2.0.1)
Jan 9 15:41:01 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Jan 9 15:42:46 smart.cgi: readlink() from /sys/block/hda/device failed. (No such file or directory)
Jan 9 15:42:47 smart.cgi: readlink() from /sys/block/hda/device failed. (No such file or directory)
Jan 9 15:42:55 smart.cgi: readlink() from /sys/block/hda/device failed. (No such file or directory)
Jan 9 15:42:57 smart.cgi: readlink() from /sys/block/hda/device failed. (No such file or directory)
Jan 9 15:43:08 smart.cgi: readlink() from /sys/block/hda/device failed. (No such file or directory)
Jan 9 15:43:19 sshd[2404]: error: setlogin failed: Function not implemented
Jan 9 15:43:19 smart.cgi: readlink() from /sys/block/hda/device failed. (No such file or directory)
ca weitere 300x Jan 9 15:49:25 smart.cgi: readlink() from /sys/block/hda/device failed. (No such file or directory)
Jan 9 17:24:01 sshd[2454]: error: setlogin failed: Function not implemented
Jan 9 20:04:21 sshd[2516]: error: setlogin failed: Function not implemented
