Jul 13 12:03:10 DiskStation syno_scemd_connector: scemd_connector/scemd_connecto r.c:133 Fail to sendto() for scemd connector client.
Jul 13 12:03:11 DiskStation syno_scemd_connector: scemd_connector/scemd_connecto r.c:133 Fail to sendto() for scemd connector client.
Jul 13 12:03:12 DiskStation syno_scemd_connector: scemd_connector/scemd_connecto r.c:133 Fail to sendto() for scemd connector client.
Jul 13 12:03:20 DiskStation syno_scemd_connector: SYSTEM: Last message 'sc emd_connector/scem' repeated 4 times, suppressed by syslog-ng on DiskStation
Jul 13 12:03:20 DiskStation scemd: event_handler.c:291 event handler thread 1216 554048 created
Jul 13 12:03:20 DiskStation scemd: event_handler.c:98 Fail to sendto() for scemd event handler client.
Jul 13 12:03:20 DiskStation scemd: SYSTEM: Last message 'event_handler.c:98 F' repeated 1 times, suppressed by syslog-ng on DiskStation
Jul 13 12:03:20 DiskStation scemd: show_module_type.c:35 fan_type=6, raid_type=1 , led_type=1, thermal_type=1, diskled_ctrl_type=1, auto_poweron_type=1, dual_pow er_type=1, usbcopy_type=1, fan_number=1, eunit_pwron_type=2, pis_type=1, rtc_typ e=2, lcm_type=2, wifi_wps_type=254
Jul 13 12:03:40 DiskStation scemd: fan_config_get.c:46 Type: INTERNAL Fan Mode: LOW
Jul 13 12:03:40 DiskStation scemd: manage_services.c:496 hw polling thread 12362 68096 created
Jul 13 12:03:40 DiskStation scemd: manage_services.c:496 disk led ctrl thread 12 44656704 created
Jul 13 12:03:40 DiskStation scemd: manage_services.c:496 scemd connector thread 1253045312 created
Jul 13 12:03:40 DiskStation scemd: manage_services.c:496 led ctrl thread 1261433 920 created
Jul 13 12:03:40 DiskStation scemd: scemd_connector.c:150 scemd connector thread start.
Jul 13 12:03:42 DiskStation scemd: event_syssleep_handler.c:625 hotplugd pid = 6 612
Jul 13 12:04:03 DiskStation scemd: raid_sys_volume_check.c:164 MD0 active disks 2, designed disks 2
Jul 13 12:04:03 DiskStation scemd: raid_sys_volume_check.c:164 MD1 active disks 2, designed disks 2
Jul 13 12:04:03 DiskStation scemd: polling_hibernation_timer.c:1194 Hibernation enable, idle minutes 10
Jul 13 12:04:03 DiskStation scemd: polling_hibernation_timer.c:1205 SATA Deep sl eep timer 1
Jul 13 12:04:03 DiskStation scemd: polling_hibernation_timer.c:343 parse error w hile get schedule time from /etc/crontab
Jul 13 12:04:56 DiskStation scemd: fan_config_get.c:46 Type: INTERNAL Fan Mode: LOW
Jul 13 12:04:56 DiskStation scemd: event_syssleep_handler.c:617 hotplugd pid = 6 612
Jul 13 12:04:56 DiskStation scemd: event_traffic_monitor.c:119 package filter co ntent = "not ( dst port 123 or src port 123 ) and not ( dst port 137 or src port 137 )"
Jul 13 12:05:41 DiskStation scemd: manutild_ip_check.c:40 stop manutild.
Jul 13 13:17:53 DiskStation scemd: manage_services.c:459 scemd connector thread exit
Jul 13 13:17:54 DiskStation scemd: manage_services.c:459 hw polling thread exit
