Vielleicht kann ja wer was mit dem Inhalt der Cam_Settings.conf der BauCam anfangen
{"alertEvents":0,"audio_format":0,"audio_record_disabled":false,"auto_pan_init_pos":-2,"cam_conn_status":6,"cam_rec_status":0,"cap_file_path":"","channel":"1","codec_optimization":0,"custom1_alarm_detect":0,"custom1_detect":1,"custom_alarm_detect":0,"custom_detect":1,"daybegin":8,"dayend":18,"device_type":1,"dynamic_key_frame":false,"enableMulticastMobile":false,"enable_audio":false,"enable_capacity":true,"enable_codec_optimization":false,"enable_days":false,"enable_io_log":true,"enable_manual_rec":false,"enable_motionlog":true,"enable_multicast":false,"enabled":true,"exporting":0,"exposure_control":6,"exposure_mode":4,"ext_di_dev_id":0,"ext_di_enable":false,"ext_di_port":0,"fov":"","fps_2":4,"hostname":"192.168.150.121","id":4,"image_height":0,"image_width":0,"is_deleted":false,"key_frame_interval":-1,"live_analytics_direction":1,"live_analytics_dwell_time":5,"live_analytics_height":0,"live_analytics_obj_size":0,"live_analytics_region":"","live_analytics_sensitivity":1,"live_analytics_setting":1,"live_analytics_type":0,"live_analytics_width":0,"live_bitrate_ctrl":1,"live_cbr_bitrate":0,"live_fps":4,"live_media_port":554,"live_path":"/h264/ch1/main/av_stream","live_quality":"5","live_resolution":"1920x1080","live_stream_no":1,"liveview_all":true,"liveview_mode":1,"media_port":554,"mobile_bitrate_ctrl":1,"mobile_cbr_bitrate":0,"mobile_fps":4,"mobile_liveview_mode":1,"mobile_media_port":554,"mobile_path":"/h264/ch1/main/av_stream","mobile_quality":"5","mobile_resolution":"1920x1080","mobile_stream_no":1,"model":"TV-IP311PI","motion_object_size":50,"motion_percentage":50,"motion_sensitivity":90,"motion_threshold":10,"mount_type":0,"multicastAudioPortMobile":0,"multicastGrpAddrMobile":"","multicastVideoPortMobile":0,"multicast_audio_port":0,"multicast_grp_addr":"","multicast_video_port":0,"mute":false,"name":"BauCam","notifyschedule":"7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF,7FF","occupied_size":327,"onvif_profile":"","osd_format":0,"osd_position":6,"osd_status":true,"param_chklist":0,"password":"Robers16061926","path":"/h264/ch1/main/av_stream","period_sync_time_hour":0,"port":80,"post_rec_time":5,"pre_rec_time":5,"pt_speed":3,"ptz_speed_keep_origin":false,"quality":"5","recStorageMountType":0,"recStorageStatus":0,"rec_bitrate_ctrl":1,"rec_cbr_bitrate":0,"rec_stream_no":1,"rec_time":30,"record_disabled":true,"recording_capacity":1536000,"recording_days":30,"recording_path":"/volume1/surveillance/BauCam","recording_prefix":"BauCam","resolution":"1920x1080","restart_day":0,"rotation_option":1,"rtsp_keep_alive":1,"rtsp_protocol":4,"schedule":"000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000","set_evt_prefix":true,"set_rec_folder":true,"status_flags":0,"stmout_port":0,"streaming_type":1,"time_server":"","tv_standard":1,"ui_stream_no":"1,1,1","username":"admin","vendor":"TRENDNet","video_flip":true,"video_mirror":true,"video_rotation":0,"video_type":3,"volume":0,"zoom_speed":3}
