Apr 7 17:13:53 dovecot: Killed with signal 15
Apr 7 17:14:10 postfix/postsuper[992]: fatal: scan_dir_push: open directory defer/8: Permission denied
Apr 7 17:14:11 postfix/postfix-script[994]: fatal: Postfix integrity check failed!
Apr 7 17:14:18 spamd[996]: server socket setup failed, retry 1: spamd: could not create INET socket on 127.0.0.1:783: Address already in use
Apr 7 17:14:19 spamd[996]: server socket setup failed, retry 2: spamd: could not create INET socket on 127.0.0.1:783: Address already in use
Apr 7 17:14:20 spamd[996]: spamd: could not create INET socket on 127.0.0.1:783: Address already in use
Apr 7 17:33:17 postfix/postfix-script[1426]: fatal: the Postfix mail system is not running
Apr 7 17:33:17 dovecot: Killed with signal 15
Apr 7 17:33:43 postfix/postsuper[1653]: fatal: scan_dir_push: open directory defer/8: Permission denied
Apr 7 17:33:44 postfix/postfix-script[1654]: fatal: Postfix integrity check failed!
Apr 7 17:54:46 postfix/postfix-script[2471]: fatal: the Postfix mail system is not running
Apr 7 17:54:46 dovecot: Killed with signal 15
Apr 7 20:07:34 postfix/postsuper[2752]: fatal: scan_dir_push: open directory defer/8: Permission denied
Apr 7 20:07:35 postfix/postfix-script[2753]: fatal: Postfix integrity check failed!
