Syno 415+ bleibt beim shutdown hängen
tesme33
01. Apr 2010
Hi
meine 415+ bleibt beim shutdown einfach hängen. Könnte sein dass dies ist seitdem ich VirtualBox 5.0.10 installiert habe.
Hat das noch jemand ?
Feb  5 14:52:21 nas01 kernel: [  103.207464] igb: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Feb  5 14:52:23 nas01 kernel: [  105.234440] EXT4-fs (md2): Ignoring removed nomblk_io_submit option
Feb  5 14:52:25 nas01 kernel: [  107.674282] Syno_HddMon: Initialization completed.
Feb  5 14:52:26 nas01 kernel: [  108.478292] scsi 8:0:0:0: Direct-Access     Synology DiskStation              PMAP PQ: 0 ANSI: 6
Feb  5 14:52:26 nas01 kernel: [  108.488444] sd 8:0:0:0: Attached scsi generic sg4 type 0
Feb  5 14:52:26 nas01 kernel: [  108.490028] sd 8:0:0:0: [synoboot] 245760 512-byte logical blocks: (125 MB/120 MiB)
Feb  5 14:52:26 nas01 kernel: [  108.503407] sd 8:0:0:0: [synoboot] Write Protect is off
Feb  5 14:52:26 nas01 kernel: [  108.510796] sd 8:0:0:0: [synoboot] No Caching mode page found
Feb  5 14:52:26 nas01 kernel: [  108.517257] sd 8:0:0:0: [synoboot] Assuming drive cache: write through
Feb  5 14:52:26 nas01 kernel: [  108.528445] sd 8:0:0:0: [synoboot] No Caching mode page found
Feb  5 14:52:26 nas01 kernel: [  108.534917] sd 8:0:0:0: [synoboot] Assuming drive cache: write through
Feb  5 14:52:26 nas01 kernel: [  108.555178] sd 8:0:0:0: [synoboot] No Caching mode page found
Feb  5 14:52:26 nas01 kernel: [  108.561643] sd 8:0:0:0: [synoboot] Assuming drive cache: write through
Feb  5 14:52:26 nas01 kernel: [  108.568994] sd 8:0:0:0: [synoboot] Attached SCSI disk
Feb  5 14:52:29 nas01 kernel: [  111.343577] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
Feb  5 14:53:41 nas01 kernel: [  182.955644] supdrvMeasureTscDeltaOne failed. rc=-3743 CPU[0].idCpu=3 Master[1].idCpu=0
Feb  5 14:53:43 nas01 kernel: [  184.966781] VBoxNetFlt: Successfully started.
Feb  5 14:53:43 nas01 kernel: [  184.982441] VBoxNetAdp: Successfully started.
Feb  5 14:53:43 nas01 kernel: [  184.989917] VBoxPciLinuxInit
Feb  5 14:53:45 nas01 kernel: [  187.113084] Bridge firewalling registered
Feb  5 17:02:16 nas01 kernel: [ 7902.954593] nfsd: last server has exited, flushing export cache
Feb  5 17:02:29 nas01 kernel: [ 7915.866377] VBoxPciLinuxLinuxUnload
Feb  5 17:04:40 nas01 kernel: [ 8047.422737] INFO: task rmmod:11981 blocked for more than 120 seconds.
Feb  5 17:04:40 nas01 kernel: [ 8047.429965] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Feb  5 17:04:40 nas01 kernel: [ 8047.446662]  ffff8802374c3d48 0000000000000082 ffff8802605a4904 ffff880275168770
Feb  5 17:04:40 nas01 kernel: [ 8047.454985]  ffff8802374c3d50 ffff88021c9cd0a0 ffff8802374c3fd8 ffff8802374c3fd8
Feb  5 17:04:40 nas01 kernel: [ 8047.463309]  ffff8802374c3fd8 ffff88021c9cd0a0 ffff8802751b4000 ffff8802374c3e88
Feb  5 17:04:40 nas01 kernel: [ 8047.471633] Call Trace:
Feb  5 17:04:40 nas01 kernel: [ 8047.474382]  [<ffffffff81482dad>] ? schedule_timeout+0x17d/0x1e0
Feb  5 17:04:41 nas01 kernel: [ 8047.481131]  [<ffffffff81041080>] ? usleep_range+0x40/0x40
Feb  5 17:04:41 nas01 kernel: [ 8047.487286]  [<ffffffff8105479b>] ? prepare_to_wait+0x5b/0x90
Feb  5 17:04:41 nas01 kernel: [ 8047.493732]  [<ffffffff81484946>] ? wait_for_completion+0x96/0x100
Feb  5 17:04:41 nas01 kernel: [ 8047.500665]  [<ffffffff8105f630>] ? try_to_wake_up+0x290/0x290
Feb  5 17:04:41 nas01 kernel: [ 8047.507210]  [<ffffffff8104c43b>] ? flush_workqueue+0x10b/0x5a0
Feb  5 17:04:41 nas01 kernel: [ 8047.513859]  [<ffffffffa08a106f>] ? rtR0LnxWorkqueueFlush+0xf/0x20 [vboxdrv]
Feb  5 17:04:41 nas01 kernel: [ 8047.521772]  [<ffffffffa08a10c8>] ? rtR0TermNative+0x8/0x30 [vboxdrv]
Feb  5 17:04:41 nas01 kernel: [ 8047.529000]  [<ffffffff81084f81>] ? SyS_delete_module+0x171/0x290
Feb  5 17:04:41 nas01 kernel: [ 8047.535836]  [<ffffffff8100b915>] ? fpu_finit+0x15/0x30
Feb  5 17:04:41 nas01 kernel: [ 8047.541702]  [<ffffffff81486732>] ? page_fault+0x22/0x30
Feb  5 17:04:41 nas01 kernel: [ 8047.547661]  [<ffffffff81487e91>] ? sysenter_dispatch+0x7/0x1e
Feb  5 17:06:41 nas01 kernel: [ 8167.623891] INFO: task rmmod:11981 blocked for more than 120 seconds.
Feb  5 17:06:41 nas01 kernel: [ 8167.631112] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Feb  5 17:06:41 nas01 kernel: [ 8167.647818]  ffff8802374c3d48 0000000000000082 ffff8802605a4904 ffff880275168770
Feb  5 17:06:41 nas01 kernel: [ 8167.656136]  ffff8802374c3d50 ffff88021c9cd0a0 ffff8802374c3fd8 ffff8802374c3fd8
Feb  5 17:06:41 nas01 kernel: [ 8167.664459]  ffff8802374c3fd8 ffff88021c9cd0a0 ffff8802751b4000 ffff8802374c3e88
Feb  5 17:06:41 nas01 kernel: [ 8167.672772] Call Trace:
Feb  5 17:06:41 nas01 kernel: [ 8167.675511]  [<ffffffff81482dad>] ? schedule_timeout+0x17d/0x1e0
Feb  5 17:06:41 nas01 kernel: [ 8167.682252]  [<ffffffff81041080>] ? usleep_range+0x40/0x40
Feb  5 17:06:41 nas01 kernel: [ 8167.688406]  [<ffffffff8105479b>] ? prepare_to_wait+0x5b/0x90
Feb  5 17:06:41 nas01 kernel: [ 8167.694853]  [<ffffffff81484946>] ? wait_for_completion+0x96/0x100
- kern.log 67573/67870 99%
Meine DS415+ hat das auch, aber irgendwann fährt sie trotzdem runter. Klar hat das was mit VB zu tun. Schau mal im passenden Thread vorbei.
Edit:
Mein Vorschlag: Versuche das Paket zu stoppen - es hängt dann. Danach leite einen Reboot ein - dauert etwas. Nach dem Reboot ist das Paket gestoppt und Folge-Reboots funktionieren wieder normal.
