Syno DSM Extractor GUI for Windows
DaveR
30. Mrz 2022
Windows GUI for extracting Synology DSM 7 pat files and spk package files.
You can drag and drop a .pat file or .spk file onto the window, or click the Select File button to browse for the .pat or .spk file. I'll add Windows right-click context menu later.
A week ago @TN-Notebooks asked for a Windows GUI app like WinRAR to unpack Synology .spk files. Without source code available for Synology's libraries a pure Windows app is not possible. So my Windows SDE.exe makes use of the default Ubuntu distro available in Windows System for Linux (which is extremely easy to install).
https://github.com/007revad/Syno_DSM_Extractor_GUI
If anyone wants to try it and provide feedback you can download:
Ready to extract the selected DSM 7 .pat file
Also supports DSM 7 .spk package files
Once you click the Extract button a shell window appears where you have to type your Ubuntu password.
I am working on an updated version that won't need to show the WSL shell window at all.
