- Mitglied seit
- 03. Jan 2022
- Punkte für Reaktionen
- 1.012
Synology hat heute Version 2.1.0 für Synology Photos freigegeben. Wichtigste Neuerung: Es ist wieder möglich, Fotos oder Videos nur vom NAS zu löschen, die sonst aber im Speicher des Smartphones bzw. bei Apple etwa in der iCloud bleiben. Das gewünschte Verhalten
![Zwinkerndes Gesicht mit herausgestreckter Zunge :stuck_out_tongue_winking_eye: 😜](/img/emojis/1f61c.png)
- „Von NAS und Telefon löschen“
- „Nur von NAS löschen“
Release Notes iOS
Important Note:
1. Following the update to this version, when backup is enabled, the Synology Photos mobile app will rescan items to check if all files are backed up in the previous version. If any unbacked-up files are found, the mobile app will automatically trigger a backup. This process will not lead to file duplication.
What's New:
1. Supports setting up your deletion preference. You can choose to delete files from both your phone and Synology NAS at once or only from your Synology NAS.
Fixed Issues:
1. Fixed an issue where users might be signed out unexpectedly when using the Synology Photos mobile app.
2. Fixed an issue where backing up a large amount of files might cause an insufficient storage error.
Release Notes Android
Version: 2.1.0-503
(2024-06-19)
Important Note
- The version is expected to be available in all regions within the next few days. The actual time of release may vary slightly depending on the region.
What's New
- Supports setting up your deletion preference. You can choose to delete files from both your phone and Synology NAS at once or only from your Synology NAS.
Bug Fixed
- Fixed an issue where users might be signed out unexpectedly when using the Synology Photos mobile app.
- Fixed an issue where a certificate processing error might prevent backups from finishing.
