[ 4727.790000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4727.960000] usb 1-1.1: unlock for hub EH
[ 4728.620000] usb 1-1.1: lock for hub EH
[ 4728.700000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4728.770000] hub is performing EH
[ 4728.880000] usb 1-1.1: unlock for hub EH
[ 4728.880000] sd 5:0:0:0: [sdq] Unhandled error code
[ 4728.880000] sd 5:0:0:0: [sdq] Result: hostbyte=0x07 driverbyte=0x00
[ 4728.890000] sd 5:0:0:0: [sdq] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[ 4728.900000] end_request: I/O error, dev sdq, sector 0
[ 4728.900000] Buffer I/O error on device sdq, logical block 0
[ 4730.040000] usb 1-1.1: lock for hub EH
[ 4730.120000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4730.310000] usb 1-1.1: unlock for hub EH
[ 4731.320000] usb 1-1.1: lock for hub EH
[ 4731.420000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4731.590000] usb 1-1.1: unlock for hub EH
[ 4740.750000] usb 1-1.1: lock for hub EH
[ 4740.800000] hub is performing EH
[ 4740.830000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4741.020000] usb 1-1.1: unlock for hub EH
[ 4744.790000] usb 1-1.1: lock for hub EH
[ 4744.870000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4745.060000] usb 1-1.1: unlock for hub EH
[ 4756.300000] usb 1-1.1: lock for hub EH
[ 4756.380000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4756.560000] usb 1-1.1: unlock for hub EH
[ 4762.860000] usb 1-1.1: lock for hub EH
[ 4762.940000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4763.130000] usb 1-1.1: unlock for hub EH
[ 4763.130000] sd 5:0:0:0: [sdq] Unhandled error code
[ 4763.130000] sd 5:0:0:0: [sdq] Result: hostbyte=0x07 driverbyte=0x00
[ 4763.140000] sd 5:0:0:0: [sdq] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[ 4763.150000] end_request: I/O error, dev sdq, sector 0
[ 4763.150000] Buffer I/O error on device sdq, logical block 0
[ 4765.380000] usb 1-1.1: lock for hub EH
[ 4765.460000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4765.640000] usb 1-1.1: unlock for hub EH
[ 4778.980000] usb 1-1.1: lock for hub EH
[ 4779.070000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4779.250000] usb 1-1.1: unlock for hub EH
[ 4783.150000] usb 1-1.1: lock for hub EH
[ 4783.230000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4783.300000] hub is performing EH
[ 4783.420000] usb 1-1.1: unlock for hub EH
[ 4802.090000] usb 1-1.1: lock for hub EH
[ 4802.170000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4802.240000] hub is performing EH
[ 4802.360000] usb 1-1.1: unlock for hub EH
[ 4805.250000] usb 1-1.1: lock for hub EH
[ 4805.320000] hub is performing EH
[ 4805.330000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4805.520000] usb 1-1.1: unlock for hub EH
[ 4808.630000] usb 1-1.1: lock for hub EH
[ 4808.730000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4808.900000] usb 1-1.1: unlock for hub EH
[ 4808.900000] sd 5:0:0:0: [sdq] Unhandled error code
[ 4808.900000] sd 5:0:0:0: [sdq] Result: hostbyte=0x07 driverbyte=0x00
[ 4808.910000] sd 5:0:0:0: [sdq] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[ 4808.920000] end_request: I/O error, dev sdq, sector 0
[ 4808.920000] Buffer I/O error on device sdq, logical block 0
[ 4814.680000] usb 1-1.1: lock for hub EH
[ 4814.760000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4814.950000] usb 1-1.1: unlock for hub EH
[ 4818.280000] usb 1-1.1: lock for hub EH
[ 4818.360000] usb 1-1.1: reset high speed USB device using orion-ehci and address 10
[ 4818.550000] usb 1-1.1: unlock for hub EH
[ 4825.170000] usb 1-1.1: lock for hub EH
[ 4828.340000] usb 1-1.1: unlock for hub EH
[ 4828.340000] sd 5:0:0:0: [sdq] Unhandled error code
[ 4828.350000] sd 5:0:0:0: [sdq] Result: hostbyte=0x07 driverbyte=0x00
[ 4828.350000] sd 5:0:0:0: [sdq] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[ 4828.360000] end_request: I/O error, dev sdq, sector 0
[ 4828.360000] Buffer I/O error on device sdq, logical block 0
[ 4828.370000] usb 1-1.1: USB disconnect, address 10
[ 4829.700000] CIFS: UNC Path does not begin with // or \\
