Ich habe meine DS211j seit gut einer Woche laufen und es läuft alles soweit auf den ersten Blick problemlos.
Allerdings habe ich bei der Nutzung von TimeMachine folgendes Log in der Konsole, welches mich etwas beunruhigt. Evtl. hat jemand eine Info, was das genau zu bedeuten hat (Auszug aus Logfile der Konsole):
> Mar 29 22:12:06 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Starting standard backup
> Mar 29 22:12:06 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Attempting to mount network destination using URL: afp://xxxxxxxxxxxxxxxx@DiskStation.local/xxxxxxxxxxxxxxxx
> Mar 29 22:12:08 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Mounted network destination using URL: afp://xxxxxxxxxxxxxxxx@DiskStation.local/xxxxxxxxxxxxxxxx
> Mar 29 22:12:08 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Warning: Destination /Volumes/xxxxxxxxxxxxxxxx does not support TM Lock Stealing
> Mar 29 22:12:08 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Warning: Destination /Volumes/xxxxxxxxxxxxxxxx does not support Server Reply Cache
> Mar 29 22:12:08 xxxxxxxxxxxxxxxx kernel[0]: AFP_VFS afpfs_mount: /Volumes/xxxxxxxxxxxxxxxx, pid 13834
> Mar 29 22:12:11 xxxxxxxxxxxxxxxx hdiejectd[13841]: running
> Mar 29 22:12:12 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: QUICKCHECK ONLY; FILESYSTEM CLEAN
> Mar 29 22:12:15xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Disk image /Volumes/xxxxxxxxxxxxxxxx/xxxxxxxxxxxxxxxx.sparsebundle mounted at: /Volumes/Time Machine-Backups
> Mar 29 22:12:15 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Backing up to: /Volumes/Time Machine-Backups/Backups.backupdb
> Mar 29 22:12:22 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: No pre-backup thinning needed: 746.7 MB requested (including padding), 1.30 TB available
> Mar 29 22:12:53 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Copied 801 files (50.0 MB) from volume Macintosh HD.
> Mar 29 22:12:54 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: No pre-backup thinning needed: 686.8 MB requested (including padding), 1.30 TB available
> Mar 29 22:12:58 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Copied 276 files (93 KB) from volume Macintosh HD.
> Mar 29 22:12:58 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Starting post-backup thinning
> Mar 29 22:13:00 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Deleted backup /Volumes/Time Machine-Backups/Backups.backupdb/xxxxxxxxxxxxxxxx/2011-03-28-202742: 1.30 TB now available
> Mar 29 22:13:02 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Deleted backup /Volumes/Time Machine-Backups/Backups.backupdb/xxxxxxxxxxxxxxxx/2011-03-28-192836: 1.30 TB now available
> Mar 29 22:13:04 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Deleted backup /Volumes/Time Machine-Backups/Backups.backupdb/xxxxxxxxxxxxxxxx/2011-03-28-182722: 1.30 TB now available
> Mar 29 22:13:08 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Deleted backup /Volumes/Time Machine-Backups/Backups.backupdb/xxxxxxxxxxxxxxxx/2011-03-28-030006: 1.30 TB now available
> Mar 29 22:13:08 xxxxxxxxxxxxxxxx com.apple.launchd[1] (com.apple.netauth.sysagent[13834]): Exited with exit code: 255
> Mar 29 22:13:10 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Deleted backup /Volumes/Time Machine-Backups/Backups.backupdb/xxxxxxxxxxxxxxxx/2011-03-28-020038: 1.30 TB now available
> Mar 29 22:13:10 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Post-back up thinning complete: 5 expired backups removed
> Mar 29 22:13:10 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Backup completed successfully.
> Mar 29 22:13:12 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Ejected Time Machine disk image.
> Mar 29 22:13:12 xxxxxxxxxxxxxxxx com.apple.backupd[13833]: Ejected Time Machine network volume.
> Mar 29 22:13:12 xxxxxxxxxxxxxxxx kernel[0]: AFP_VFS afpfs_unmount: /Volumes/xxxxxxxxxxxxxxxx, flags 0, pid 13859
> Mar 29 22:13:12 xxxxxxxxxxxxxxxx kernel[0]: ASP_TCP do_thread_read: no reqInfo found for reqID 2
> Mar 29 22:13:12 xxxxxxxxxxxxxxxx kernel[0]: ASP_TCP CancelOneRequest: cancelling slot 23 error 89 reqID 10517 flags 0x9 afpCmd 0x14 so 0x961bcc0
> Mar 29 22:13:22 xxxxxxxxxxxxxxxx hdiejectd[13841]: quitCheck: calling exit(0)
> xxxxxxxxxxxxxxxx mDNSResponder[18]: PenaltyTimeForServer: PenaltyTime negative -30635, (server penaltyTime -202355727, timenow -202325092) resetting the penalty
Grundsätzlich ist das Backup demnach in Ordnung, nur beunruhigen mich die Einträge von "backupd" und "kernel":
1) "does not support TM Lock Stealing" (Mar 29 22:12:08)
2) "does not support Server Reply Cache" (Mar 29 22:12:08)
3) "Exited with exit code: 255" (Mar 29 22:13:08)
4) unmount scheint nicht zu funktionieren, siehe CancelOneRequest (alle Einträge zu Mar 29 22:13:12)
4) "quitCheck: calling exit(0)" (Mar 29 22:13:22)
3) PenaltyTime(Mar 29 22:32:07)
Welche Auswirkungen hat das für den weiteren Betrieb und die "Datensicherung" an sich? Weiß jemand, ob und wenn ja, was zu tun ist?
Vielen Dank für Eure Unterstützung!
