tls error , was kann man dagegen tun?
ottosykora
17. Apr. 2013
Mit der Filezilla klappt neuerdings die Verbindung FTPS nicht mehr. Mit FireFTP Extension für Firefox geht es jedoch ohne Probleme.
Was kann man gegen diesen Fehler tun?
Filezilla Version:
FileZilla Client
Version: 3.7.3
Build information:
Compiled for: i586-pc-mingw32msvc
Compiled on: x86_64-unknown-linux-gnu
Build date: 2013-08-07
Compiled with: i586-mingw32msvc-gcc (GCC) 4.2.1-sjlj (mingw32-2)
Compiler flags: -g -O2 -Wall -g -fexceptions
Linked against:
wxWidgets: 2.8.12
GnuTLS: 3.1.11
SQLite: 3.7.16.2
Operating system:
Name: Windows NT 6.1 (build 7601, Service Pack 1)
Version: 6.1
Platform: 32 bit system
DS 212j mit letztem Update
Status:	Connection established, waiting for welcome message...
Response:	220 DiskStation FTP server ready.
Command:	AUTH TLS
Response:	234 AUTH SSL command successful.
Status:	Initializing TLS...
Status:	Verifying certificate...
Command:	USER anonymous
Status:	TLS/SSL connection established.
Response:	331 Guest login ok, send your email address as password.
Command:	PASS **************
Response:	230 Guest login ok, access restrictions apply.
Command:	SYST
Response:	215 UNIX Type: L8
Command:	FEAT
Response:	211- Extensions supported:
Response:	 AUTH TLS
Response:	 PBSZ
Response:	 PROT
Response:	 SIZE
Response:	 MDTM
Response:	 MFMT
Response:	 REST STREAM
Response:	 UTF8
Response:	211 End.
Command:	OPTS UTF8 ON
Response:	200 OK, UTF-8 enabled
Command:	PBSZ 0
Response:	200 PBSZ command successful (PBSZ=0).
Command:	PROT P
Response:	200 Protection level set to Private.
Status:	Connected
Status:	Retrieving directory listing...
Command:	PWD
Response:	257 "/" is current directory.
Command:	TYPE I
Error:	GnuTLS error -12: A TLS fatal alert has been received.
Error:	Disconnected from server: ECONNABORTED - Connection aborted
Error:	Failed to retrieve directory listing
