Verzeiht mir meine Unwissenheit.
Aber ich versuche (ohne tatsächliche Kenntnisse) Trac (http://trac.edgewall.org) auf meiner Synology RS812+ zu installieren.
Habe dazu IPKG gemäß http://www.synology-wiki.de/index.php/IPKG installiert.
ipkg update
ipkg upgrade
verliefen ohne Probleme.
Danach habe ich folgendes ausgeführt:
ipkg install py26-trac
Das Ergebnis ist:
Installing py26-trac (0.12.1-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/py26-trac_0.12.1-1_i686.ipk
Installing python26 (2.6.8-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/python26_2.6.8-1_i686.ipk
Installing readline (6.1-2) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/readline_6.1-2_i686.ipk
Installing ncurses (5.7-3) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/ncurses_5.7-3_i686.ipk
Installing bzip2 (1.0.6-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/bzip2_1.0.6-1_i686.ipk
Installing openssl (0.9.8v-2) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/openssl_0.9.8v-2_i686.ipk
Installing libdb (4.2.52-3) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/libdb_4.2.52-3_i686.ipk
Installing zlib (1.2.5-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/zlib_1.2.5-1_i686.ipk
Installing sqlite (3.8.1-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/sqlite_3.8.1-1_i686.ipk
Installing libstdc++ (6.0.9-6) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/libstdc++_6.0.9-6_i686.ipk
Installing ncursesw (5.7-2) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/ncursesw_5.7-2_i686.ipk
Installing py26-genshi (0.6-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/py26-genshi_0.6-1_i686.ipk
Installing py26-setuptools (0.6c11-2) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/py26-setuptools_0.6c11-2_i686.ipk
Configuring bzip2
update-alternatives: Linking //opt/bin/bzip2 to /opt/bin/bzip2-bzip2
Configuring libdb
Configuring libstdc++
Configuring ncurses
update-alternatives: Linking //opt/bin/clear to /opt/bin/ncurses-clear
Configuring ncursesw
Configuring openssl
Configuring py26-genshi
Configuring py26-setuptools
Configuring py26-trac
Configuring python26
Configuring readline
Configuring sqlite
Configuring zlib
Successfully terminated.
Schätze dass die Installation eigentlich funktionieren hätte sollen.
Habe jetzt aber überhaupt keine Ahnung wie ich Trac jetzt starten kann, bzw. wo sich die "installierten" Dateien jetzt tatsächlich befinden.
Hoffe ihr könnt mir weiterhelfen.
Danke
RS812+ || DSM 5.2-5644 Update 2
ipkg update
ipkg upgrade
Das Ergebnis ist:
Configuring bzip2
Configuring libdb
Configuring ncurses
Configuring openssl
Configuring sqlite
Configuring zlib
Danke
