VirtualBox x86_64 5.0 16-105871-3 Problem DS3615xs DSM 5,2-5644 Update 5
ktzhuce
31. Mai 2016
Das gleiche Problem VirtualBox_4.3.30-101610-1
00:10:29.106305 SQPmp    Request 222 on socket 10 queued for processing (1 items on Q)
00:10:29.106338 SQW04    Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:32.108702 SQPmp    Request 223 on socket 10 queued for processing (1 items on Q)
00:10:32.108736 SQW02    Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:32.415384 SQPmp    Request 224 on socket 12 queued for processing (1 items on Q)
00:10:32.415421 SQW03    Processing connection from IP=127.0.0.1 socket=12 (2 out of 4 threads idle)
00:10:32.471218 SQPmp    Request 225 on socket 13 queued for processing (1 items on Q)
00:10:32.471254 SQW01    Processing connection from IP=127.0.0.1 socket=13 (1 out of 4 threads idle)
00:10:32.530360 SQPmp    Request 226 on socket 12 queued for processing (1 items on Q)
00:10:32.530396 SQW03    Processing connection from IP=127.0.0.1 socket=12 (1 out of 4 threads idle)
00:10:33.109920 SQPmp    Request 227 on socket 10 queued for processing (1 items on Q)
00:10:33.109950 SQW03    Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:33.115471 SQW03    API method name:            IProgress::COMGETTER(ErrorInfo)
00:10:33.115494 SQW03    API return code:            0x80004005 (NS_ERROR_FAILURE)
00:10:33.115501 SQW03    COM error info result code: 0x80004005 (NS_ERROR_FAILURE)
00:10:33.115506 SQW03    COM error info text:        Error info is not available, operation is still in progress
00:10:33.133157 SQPmp    Request 228 on socket 10 queued for processing (1 items on Q)
00:10:33.133188 SQW03    Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:35.120830 SQPmp    Request 229 on socket 10 queued for processing (1 items on Q)
00:10:35.120861 SQW01    Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:35.171508 SQPmp    Request 230 on socket 10 queued for processing (1 items on Q)
00:10:35.171539 SQW04    Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:35.178621 SQPmp    Request 231 on socket 10 queued for processing (1 items on Q)
00:10:35.178663 SQW02    Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
00:10:38.119935 SQPmp    Request 232 on socket 10 queued for processing (1 items on Q)
00:10:38.119984 SQW03    Processing connection from IP=127.0.0.1 socket=10 (3 out of 4 threads idle)
Exception Object
    [message:protected] => The virtual machine 'ubuntu-1' has terminated unexpectedly during startup because of signal 11
    [string:Exception:private] =>
    [code:protected] => 0
    [file:protected] => /volume2/web/phpvirtualbox/endpoints/lib/vboxconnector.php
    [line:protected] => 2429
    [trace:Exception:private] => Array
            [0] => Array
                    [file] => /volume2/web/phpvirtualbox/endpoints/lib/vboxconnector.php
                    [line] => 951
                    [function] => remote_progressGet
                    [class] => vboxconnector
                    [type] => ->
                    [args] => Array
                            [0] => Array
                                    [progress] => 265067e6c45d2f1d-0000000000000004
            [1] => Array
                    [file] => /volume2/web/phpvirtualbox/endpoints/api.php
                    [line] => 316
                    [function] => __call
                    [type] => ->
                    [args] => Array
                            [0] => progressGet
                            [1] => Array
                                    [0] => Array
                                    [1] => Array
                                            [0] => Array
                                                    [data] => Array
                                                            [responseData] => Array
        [info] => Array
        [completed] => 1
        [canceled] =>
        [description] => Starting VM
        [operationDescription] => Creating process for virtual machine "ubuntu-1" (headless)
        [timeRemaining] => Array
        [timeElapsed] => Array
        [days] => 16953
        [hours] => 1
        [minutes] => 55
        [seconds] => 12
        [percent] => 0
                                                            [success] => 1
                                                            [key] => 53474945cfd7ac0bf8114767c209c2a6
                                                    [errors] => Array
                                                    [persist] => Array
                                                    [messages] => Array
DKeppi
01. Apr 2011
DKeppi
01. Apr 2011
Immerhin der Fehler ist jetzt ein anderer ;)
Wie sehen deine Reiter "Motherboard" und "Acceleration" aus?
DKeppi
01. Apr 2011
Sieht alles normal aus, wie bei mir - aber du hast den Fehler ja selbst lösen können ;)
