Ich erhalte folgende log beim Versuch die Web Station zu aktivieren:
Jun 25 20:13:29 DISKSTATION kernel: [14544.256685] init: php-fpm main process (18740) terminated with status 78
Jun 25 20:13:29 DISKSTATION kernel: [14544.264401] init: php-fpm main process ended, respawning
Jun 25 20:13:29 DISKSTATION kernel: [14544.429980] init: php-fpm main process (18744) terminated with status 78
Jun 25 20:13:29 DISKSTATION kernel: [14544.437691] init: php-fpm main process ended, respawning
Jun 25 20:13:29 DISKSTATION kernel: [14544.603176] init: php-fpm main process (18748) terminated with status 78
Jun 25 20:13:29 DISKSTATION kernel: [14544.610028] init: php-fpm main process ended, respawning
Jun 25 20:13:30 DISKSTATION kernel: [14544.775463] init: php-fpm main process (18752) terminated with status 78
Jun 25 20:13:30 DISKSTATION kernel: [14544.783187] init: php-fpm main process ended, respawning
Jun 25 20:13:30 DISKSTATION kernel: [14544.951187] init: php-fpm main process (18756) terminated with status 78
Jun 25 20:13:30 DISKSTATION kernel: [14544.958037] init: php-fpm respawning too fast, stopped
Jun 25 20:16:25 DISKSTATION kernel: [14720.397935] init: nginx main process (18867) terminated with status 1
Jun 25 20:16:25 DISKSTATION kernel: [14720.410616] init: nginx faild on spawn stage, stopped
Jun 25 20:16:25 DISKSTATION entry.cgi_SYNO.Core.Web.HTTP[1].set[18846]: web_start_web_station.c:34 SYNOWebService(enable) failed[0xD400 servicectl_job_start.c:40]
Jun 25 20:16:25 DISKSTATION entry.cgi_SYNO.Core.Web.HTTP[1].set[18846]: webstation_http_service.cpp:121 SYNOWebStationStart failed
Jun 25 20:16:25 DISKSTATION kernel: [14720.555492] init: php-fpm main process (18853) terminated with status 78
Jun 25 20:16:25 DISKSTATION kernel: [14720.563213] init: php-fpm main process ended, respawning
Jun 25 20:16:25 DISKSTATION kernel: [14720.728455] init: php-fpm main process (18874) terminated with status 78
Jun 25 20:16:25 DISKSTATION kernel: [14720.736191] init: php-fpm main process ended, respawning
Jun 25 20:16:26 DISKSTATION kernel: [14721.058264] init: php-fpm main process (18879) terminated with status 78
Jun 25 20:16:26 DISKSTATION kernel: [14721.067194] init: php-fpm main process ended, respawning
Jun 25 20:16:26 DISKSTATION kernel: [14721.232883] init: php-fpm main process (18884) terminated with status 78
Jun 25 20:16:26 DISKSTATION kernel: [14721.239889] init: php-fpm main process ended, respawning
Jun 25 20:16:26 DISKSTATION kernel: [14721.407063] init: php-fpm main process (18888) terminated with status 78
Jun 25 20:16:26 DISKSTATION kernel: [14721.414781] init: php-fpm main process ended, respawning
Jun 25 20:16:26 DISKSTATION kernel: [14721.586893] init: php-fpm main process (18892) terminated with status 78
Jun 25 20:16:26 DISKSTATION kernel: [14721.594686] init: php-fpm respawning too fast, stopped
Vielleicht nochmal genau was ich gemacht habe. Die Web Station auf der baugleichen NAS (213j) von einem Freund funktioniert nach dem Update auf DSM 5 nämlich.
Ich habe eine zweite Festplatte eingebaut und hatte das Volume dumemrweise auf SHR erstellt, ich hatte also keinen weiteren Speicherplatz zur Verfügung sondern nur eine Sicherung auf der zweite Platte. Also habei ch die gesamten 3TB auf einen Server kopiert, das Volumen neu erstellt und die Daten wieder draufkopiert. Inklusive dem Ordner "web". Bei der anderen DS habe ich das nicht gemacht.
Evtl. hat mit diesen Hinweisen jemand eine Idee.
Viele Grüße,
Tapy
