' xxxxxx.dnsalias.org WebDisk.vbs
' 05/17/2010 - Initial write.
Option Explicit
Dim errReturn, strURL, strDomain
' Configurable Variables
strURL = "http://xxxx.dnsalias.org:5005/" ' This is the URL to the WebDAV share.
strDomain = "xxxxxxxx" ' This is the name of the domain.
' This subroutine searches for the WebDAV service known as 'WebClient' and
' makes sure that it is configured for automatic startup, and that it is
' currently running.
Sub ConfigureService()
Dim objWMIService
Set objWMIService = GetObject("winmgmts:"_
& "{impersonationLevel=impersonate}!\\.\root\cimv2")
' We only care about one service, so the search is only for
' the WebClient service.
Dim colServiceList
Set colServiceList = objWMIService.ExecQuery _
("Select * from Win32_Service where Name = 'WebClient'")
' If more than one service was returned, something is funky.
' Likewise, if no services are returned, we shouldn't be running.
If colServiceList.Count = 1 Then
Dim objService
For Each objService in colServiceList
' Test to see if the service is scheduled to run on startup, if not, configure it to.
If objService.StartMode <> "Automatic" Then
errReturn = objService.Change( , , , , "Automatic")
End If
' Test to see if the service is currently running, if not, start it.
If objService.State <> "Started" Then
objService.StartService()
End If
Next
Else
WScript.Echo "Could not find WebClient service."
End If
End Sub
' This Subroutine launches an IE browser that contains the HTML required
' to open the web folder for viewing. It then fires the OnClick event
' for the link in order to open the WebFolder. The browser is then
' closed.
Sub LaunchBrowser()
Dim objIE
Set objIE = CreateObject("InternetExplorer.Application")
objIE.Visible = false
objIE.Navigate2 "about:blank"
objIE.Document.write "<!DOCTYPE html PUBLIC ""-//W3C//DTD XHTML 1.0 Transitional//EN"" ""http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"">"_
&"<html><head>"_
&"<style>a {behavior: url(#default#AnchorClick);}</style></head>"_
&"<body><a href='" & strURL & "' FOLDER='" & strURL & "' TARGET='_top'>"_
&"Click here to finish setting up your Web Folder</a></body></html>"
Dim links
Set links = objIE.Document.links
links(0).fireEvent("OnClick")
objIE.Quit
Set objIE = Nothing
End Sub
' This subroutine creates a shortcut to the web disk.
Sub CreateShorty ()
Dim strName, strAppname, strNetHood, blnDeleteMode, objFSO, objWSHShell, objShell, objFolder, objFolderItem, blnVerboseMode, strDesktop,oMyShortCut, objDesktopIni, objNewLinkFolder, filesys, path, fso, f, ff, f1
strAppname = "xxxxx.dnsalias.org_WebDisk.vbs"
Const NETHOOD = &H13&
Const MAXIMIZE_WINDOW = 3
strName = "xxxxx.dnsalias.org WebDisk"
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objWshShell = CreateObject("WScript.Shell")
Set objShell = CreateObject("Shell.Application")
Set objFolder = objShell.Namespace(NETHOOD)
Set objFolderItem = objFolder.Self
strNetHood = objFolderItem.Path
'Set objNewLinkFolder = objFSO.CreateFolder(strNetHood & "\" & strName)
'Set objDesktopIni = objFSO.CreateTextFile(strNetHood & "\" & strName & "\Desktop.ini")
Set filesys = CreateObject("Scripting.FileSystemObject")
path = filesys.GetAbsolutePathName(strNetHood & "\" & strDomain & "\target.lnk" )
If filesys.FileExists(path) Then
strDesktop = objWshShell.SpecialFolders("Desktop")
Set oMyShortCut = objWshShell.CreateShortcut(strDesktop & "\" & strName & ".lnk")
oMyShortCut.IconLocation = "%SystemRoot%\system32\SHELL32.dll,9"
oMyShortCut.TargetPath = strNetHood & "\" & strDomain
oMyShortCut.Description = strName
oMyShortCut.Save
objWshShell.Run chr(34) & strDesktop & "\" & strName & ".lnk" & chr(34), MAXIMIZE_WINDOW
Else
WScript.Echo "There was a problem connecting to the WebDisk service. Please make sure port 5005 is not firewalled."
End If
End Sub
' This subroutine opens Windows Explorer to My Network Places to show
' the location of the web disk.
' Main Function Area. This is where it all goes down.
ConfigureService
LaunchBrowser
CreateShorty
