Z-Push contacts sync ./. HTC One M8 (2014)
tom9865
20. Feb 2013
I changed my phone to HTC One M8, found on the Internet that this device had sync issues with z-push.
In my case sync is working fine for everything except contacts.
I already installed the last experimental posted here. Is that version "Z-Push 2.1.3RC version (build 1891)" released 11-06-2014 (https://forums.zarafa.com/showthread.php?10564-Z-Push-2-1-3RC-released)?
They state there that the HTC One M8 issue is solved in that version.
When that one here is an older one, can anybody tell me how I have to modify the *.tar.gz file from the mentioned source? Or is anybody planning to update the experimental version?
Do you have maybe an idea how I could fix that issue? Is it necessary to install both experimental versions? (Zarafa&Z-Push)? Or is Z-Push (experimental) working with the stable Zarafa on Synology.
Your help would be very much appreciated.
Tom
tom9865
20. Feb 2013
Nobody here with an idea or the same problem?
Otherwise, any idea how to update z-push to newest 2.2.x version? In the release notes my exact problem - with HTC One m8 is metioned and should be solved...
Appreciate any input a lot!
cheers,
Tom
