Zarafa 5.2 > mit Z-Push nach Andtiod sync Probleme : Kontakte Kalender usw...
syn166
26. Mrz 2013
ch habe folgende Probleme mit meiner NAS lief bis vor 4Tagen noch SUPER hat jemand eine IDEE danke
Zarafa hat diesen DEADLOCK
Fri Sep 11 11:49:36 2015: Starting zarafa-server version 7,1,8,44004, pid 8358
Fri Sep 11 11:49:36 2015: Listening for priority pipe connections on /var/run/zarafa-prio
Fri Sep 11 11:49:36 2015: Listening for pipe connections on /var/run/zarafa
Fri Sep 11 11:49:36 2015: Listening for TCP connections on port 236
Fri Sep 11 11:49:37 2015: Connection to database 'zarafa' succeeded
Fri Sep 11 11:49:37 2015: zarafa-licensed is running,
Fri Sep 11 11:49:48 2015: Loading searchfolders
Fri Sep 11 11:49:50 2015: Startup succeeded on pid 8364
Fri Sep 11 13:00:48 2015: SQL [00000012] result failed: Deadlock found when trying to get lock; try restarting transaction, Query: "SELECT count(if(flags & 0x440 = 0 && type = 5, 1, null)) AS cc, count(if(flags & 0x440 = 0x40 and type = 5, 1, null)) AS acc, count(if(flags & 0x440 = 0x400 and type = 5, 1, null)) AS dmc, count(if(flags & 0x440 = 0x440 and type = 5, 1, null)) AS dac, count(if(flags & 0x400 = 0 and type = 3, 1, null)) AS cfc, count(if(flags & 0x400 and type = 3, 1, null)) AS dfc from hierarchy where parent=608 FOR UPDATE"
Fri Sep 11 13:12:05 2015: SQL [00000013] result failed: Deadlock found when trying to get lock; try restarting transaction, Query: "SELECT count(if(flags & 0x440 = 0 && type = 5, 1, null)) AS cc, count(if(flags & 0x440 = 0x40 and type = 5, 1, null)) AS acc, count(if(flags & 0x440 = 0x400 and type = 5, 1, null)) AS dmc, count(if(flags & 0x440 = 0x440 and type = 5, 1, null)) AS dac, count(if(flags & 0x400 = 0 and type = 3, 1, null)) AS cfc, count(if(flags & 0x400 and type = 3, 1, null)) AS dfc from hierarchy where parent=608 FOR UPDATE"
Fri Sep 11 13:30:12 2015: SQL [00000008] Failed: Lock wait timeout exceeded; try restarting transaction, Query Size: 62, Query: "SELECT change_id,sourcekey FROM syncs WHERE id=1510 FOR UPDATE"
Fri Sep 11 13:30:38 2015: SQL [00000006] Failed: Lock wait timeout exceeded; try restarting transaction, Query Size: 62, Query: "SELECT change_id,sourcekey FROM syncs WHERE id=1510 FOR UPDATE"
mit Z-push hat diesen Fehler WBXMLExeption: WBXMLDecoder->getElementStartTag()unmatched WBXML tag Setting:Settings matching Provision:provision type 1 flags 1 code: 0
im Log File
z-push ist dieser FEHLER WBXMLExeption: WBXMLDecoder->getElementStartTag()unmatched WBXML tag Setting:Settings matching Provision:provision type 1 flags 1 code: 0
die Kontakte werden seit kurzem nicht mehr synchronisiert HTC M8 und beim SAMSUNG NOTE 10.1 werden die emails nicht synchronisiert
z-push 2.1.1
SPK Version: 0.5.5
Zarafa Version: 7.1.8
Fetchmail Version: 6.3.26
DS212j
Installierte DSM-Version:
DSM 5.2-5592 Update 4
DSM-Datum:
2015/09/04
tom9865
20. Feb 2013
Hi, hast Du es beheben können? Bei mir ist ein Problem welches nur mit meinem speziellen Handy und Z-Push 2.1.x besteht.
Eine idee wie ich Z-Push auf Version 2.2.x updaten kann? (Synology natürlich)
Es gibt ja noch kein spk, aber geht das auch irgendwie anders?
