#!/usr/bin/php
<?PHP
$LOCALE_PATH = '/volume1/web/webaccess/';
function isUnicodeStore($store) {
$supportmask = mapi_getprops($store, array(PR_STORE_SUPPORT_MASK));
if (isset($supportmask[PR_STORE_SUPPORT_MASK]) && ($supportmask[PR_STORE_SUPPORT_MASK] & STORE_UNICODE_OK)) {
print("Store supports properties containing Unicode characters.\n");
define('STORE_SUPPORTS_UNICODE', true);
} else {
print("Store does not support properties containing Unicode characters.\n");
define('STORE_SUPPORTS_UNICODE', false);
function renamefolder($store, $entryid, $name)
if(!$entryid) {
print("Unable to find $name folder\n");
return;
$folder = mapi_msgstore_openentry($store, $entryid);
if(!$folder) {
print("Unable to open folder " . bin2hex($entryid) . "\n");
return;
mapi_setprops($folder, array(PR_DISPLAY_NAME => $name));
if(mapi_last_hresult() != 0)
print("Unable to rename " . bin2hex($entryid) . " to '$name'\n");
else
print("Renamed " . bin2hex($entryid) . " to '$name'\n");
include('/volume1/web/webaccess/include/mapi/mapi.util.php');
include('/volume1/web/webaccess/include/mapi/mapidefs.php');
include('/volume1/web/webaccess/include/mapi/mapicode.php');
include('/volume1/web/webaccess/include/mapi/mapitags.php');
include('/volume1/web/webaccess/include/mapi/mapiguid.php');
function translate($lang, $test=0)
global $LOCALE_PATH;
putenv("LANGUAGE=$lang");
bindtextdomain("zarafa", "$LOCALE_PATH");
if (STORE_SUPPORTS_UNICODE == false) {
bind_textdomain_codeset('zarafa', "windows-1252");
} else {
bind_textdomain_codeset('zarafa', "utf-8");
textdomain('zarafa');
setlocale(LC_ALL,$lang);
// Hier ändern ****************************************
$trans_array["Sent Items"] = "Gesendete Objekte";
$trans_array["Outbox"] = "Postausgang";
$trans_array["Deleted Items"] = "Geloeschte Objekte";
$trans_array["Inbox"] = "Posteingang";
$trans_array["Calendar"] = "Kalender";
$trans_array["Contacts"] = "Kontakte";
$trans_array["Drafts"] = "Entwuerfe";
$trans_array["Journal"] = "Journal";
$trans_array["Notes"] = "Notizen";
$trans_array["Tasks"] = "Aufgaben";
$trans_array["Junk E-mail"] = "Junk E-mail";
return $trans_array;
if(count($argv) != 3) {
print("Usage: foldernames <useraccount> <language>\n");
print("\n");
print("To do a test translation, use: -t <language>\n");
print("\n");
print("A <language> could be: nl_NL.UTF-8\n");
print("\n");
exit(2);
if($argv[1] == "-t") {
$trans_array=translate($argv[2], 1);
foreach ($trans_array as $key => $value) {
echo str_pad($key, 20, " ");
echo "$value\n";
exit(0);
$session = mapi_logon_zarafa("SYSTEM", "", "file:///var/run/zarafa");
$msgstorestable = mapi_getmsgstorestable($session);
$msgstores = mapi_table_queryallrows($msgstorestable, array(PR_DEFAULT_STORE, PR_ENTRYID));
foreach ($msgstores as $row) {
if($row[PR_DEFAULT_STORE]) {
$storeentryid = $row[PR_ENTRYID];
if(!$storeentryid) {
print "Can't find default store\n";
exit(1);
$store = mapi_openmsgstore($session, $storeentryid);
if(!$store) {
print "Unable to open system store\n";
exit(1);
$userstoreentryid = mapi_msgstore_createentryid($store, $argv[1]);
if(!$userstoreentryid) {
print "Unknown user\n";
exit(1);
$userstore = mapi_openmsgstore($session, $userstoreentryid);
if(!$userstore) {
print "Unable to open user store\n";
exit(1);
isUnicodeStore($userstore);
$inbox = mapi_msgstore_getreceivefolder($userstore);
$root = mapi_msgstore_openentry($userstore);
$storeprops = mapi_getprops($userstore, array(PR_IPM_SENTMAIL_ENTRYID, PR_IPM_OUTBOX_ENTRYID, PR_IPM_WASTEBASKET_ENTRYID));
$inboxprops = mapi_getprops($inbox, array(PR_ENTRYID, PR_IPM_APPOINTMENT_ENTRYID, PR_IPM_CONTACT_ENTRYID, PR_IPM_DRAFTS_ENTRYID, PR_IPM_JOURNAL_ENTRYID, PR_IPM_NOTE_ENTRYID, PR_IPM_TASK_ENTRYID));
$rootprops = mapi_getprops($root, array(PR_ADDITIONAL_REN_ENTRYIDS));
$trans_array = translate($argv[2]);
renamefolder($userstore, $storeprops[PR_IPM_SENTMAIL_ENTRYID], $trans_array["Sent Items"]);
renamefolder($userstore, $storeprops[PR_IPM_OUTBOX_ENTRYID], $trans_array["Outbox"]);
renamefolder($userstore, $storeprops[PR_IPM_WASTEBASKET_ENTRYID], $trans_array["Deleted Items"]);
renamefolder($userstore, $inboxprops[PR_ENTRYID], $trans_array["Inbox"]);
renamefolder($userstore, $inboxprops[PR_IPM_APPOINTMENT_ENTRYID], $trans_array["Calendar"]);
renamefolder($userstore, $inboxprops[PR_IPM_CONTACT_ENTRYID], $trans_array["Contacts"]);
renamefolder($userstore, $inboxprops[PR_IPM_DRAFTS_ENTRYID], $trans_array["Drafts"]);
renamefolder($userstore, $inboxprops[PR_IPM_JOURNAL_ENTRYID], $trans_array["Journal"]);
renamefolder($userstore, $inboxprops[PR_IPM_NOTE_ENTRYID], $trans_array["Notes"]);
renamefolder($userstore, $inboxprops[PR_IPM_TASK_ENTRYID], $trans_array["Tasks"]);
renamefolder($userstore, $rootprops[PR_ADDITIONAL_REN_ENTRYIDS][4], $trans_array["Junk E-mail"]);
