ich melde mich nochmal da ich es nicht hinbekomme..
meine start-stop-status.sh sieht so aus
#!/bin/sh
#--------MINECRAFT/CRAFTBUKKIT start-stop-status script
#--------package maintained at pcloadletter.co.uk
DAEMON_USER="`echo ${SYNOPKG_PKGNAME} | awk {'print tolower($_)'}`"
DAEMON_ID="${SYNOPKG_PKGNAME} daemon user"
ENGINE_SCRIPT="/var/packages/${SYNOPKG_PKGNAME}/scripts/launcher.sh"
DAEMON_USER_SHORT=`echo ${DAEMON_USER} | cut -c 1-8`
daemon_status ()
ps | grep "^ *[0-9]* ${DAEMON_USER_SHORT} .*java" > /dev/null
case $1 in
start)
DAEMON_HOME="`cat /etc/passwd | grep "${DAEMON_ID}" | cut -f6 -d':'`"
#set the current timezone for Java so that log timestamps are accurate
#we need to use the modern timezone names so that Java can figure out DST
SYNO_TZ=`cat /etc/synoinfo.conf | grep timezone | cut -f2 -d'"'`
SYNO_TZ=`grep "^${SYNO_TZ}" /usr/share/zoneinfo/Timezone/tzname | sed -e "s/^.*= //"`
grep "^export TZ" ${DAEMON_HOME}/.profile > /dev/null \
&& sed -i "s%^export TZ=.*$%export TZ='${SYNO_TZ}'%" ${DAEMON_HOME}/.profile \
|| echo export TZ=\'${SYNO_TZ}\' >> ${DAEMON_HOME}/.profile
su - ${DAEMON_USER} -s /bin/sh -c "${ENGINE_SCRIPT} start ${DAEMON_USER} ${SYNOPKG_PKGDEST} &"
exit 0
stop)
su - ${DAEMON_USER} -s /bin/sh -c "${ENGINE_SCRIPT} stop ${DAEMON_USER} ${SYNOPKG_PKGDEST}"
exit 0
status)
if daemon_status ; then
exit 0
else
exit 1
fi
log)
echo "${SYNOPKG_PKGDEST}/server.log"
exit 0
esac
der Pfad der Datei ist /var/packages/Craftbukkit/scripts/launcher.sh,CraftBukkit-launcher.sh
/var/packages/Craftbukkit/scripts/start-stop-status.sh
wie müsste dann das Start bzw Stop Script aussehen?
Ich verstehe das mit den Script leider absolut nicht.
Danke schonmal
