Synology Toolset
Synology hat ab DSM3 einige eigen-entwickelte Tools dokumentiert.
/bin
ash - Kommandointerpreter/Almquist-Shell
busybox - BusyBox combines tiny versions of many common UNIX utilities into a single small executable. It provides minimalist replacements for most of the utilities you usually find in GNU coreutils, util-linux, etc. The utilities in BusyBox generally have fewer options than their full-featured GNU cousins; however, the options that are included provide the expected functionality and behave very much like their GNU counterparts.
cat [-u] [FILE]... - Concatenate FILEs and print them to stdout
- -u Use unbuffered i/o (ignored)
catv [-etv] [FILE]... - Display nonprinting characters as ^x or M-x
- -e End each line with $
- -t Show tabs as ^I
- -v Don't use ^x or M-x escapes
chgrp [-RhLHP]... GROUP FILE... - Change the group membership of each FILE to GROUP
- -R Recurse
- -h Affect symlinks instead of symlink targets
- -L Traverse all symlinks to directories
- -H Traverse symlinks on command line only
- -P Don't traverse symlinks (default)
chmod [-R] MODE[,MODE]... FILE... - Each MODE is one or more of the letters ugoa, one of the symbols +-= and one or more of the letters rwxst
- -R Recurse
chown [-RhLHP]... OWNER[<.|:>[GROUP]] FILE... - Change the owner and/or group of each FILE to OWNER and/or GROUP
- -R Recurse
cp [OPTIONS] SOURCE DEST - Copy SOURCE to DEST, or multiple SOURCE(s) to DIRECTORY
- -a Same as -dpR
- -R,-r Recurse
- -d,-P Preserve symlinks (default if -R)
- -L Follow all symlinks
- -H Follow symlinks on command line
- -p Preserve file attributes if possible
- -f Force overwrite
- -i Prompt before overwrite
- -l,-s Create (sym)links
date [OPTIONS] [+FMT] [TIME] - Display time (using +FMT), or set time
- [-s,--set] TIME Set time to TIME
- -u,--utc Work in UTC (don't convert to local time)
- -R,--rfc-2822 Output RFC-2822 compliant date string
- -I[SPEC] Output ISO-8601 compliant date string
- SPEC='date' (default) for date only, 'hours', 'minutes', or 'seconds' for date and time to the indicated precision
- -r,--reference FILE Display last modification time of FILE
- -d,--date TIME Display TIME, not 'now'
- -D FMT Use FMT for -d TIME conversion
Recognized TIME formats:
hh:mm[:ss]
[YYYY.]MM.DD-hh:mm[:ss]
YYYY-MM-DD hh:mm[:ss]
[[[[[YY]YY]MM]DD]hh]mm[.ss]
dd [if=FILE] [of=FILE] [ibs=N] [obs=N] [bs=N] [count=N] [skip=N] [seek=N] [conv=notrunc|noerror|sync|fsync] - Copy a file with converting and formatting
- if=FILE Read from FILE instead of stdin
- of=FILE Write to FILE instead of stdout
- bs=N Read and write N bytes at a time
- ibs=N Read N bytes at a time
- obs=N Write N bytes at a time
- count=N Copy only N input blocks
- skip=N Skip N input blocks
- seek=N Skip N output blocks
- conv=notrunc Don't truncate output file
- conv=noerror Continue after read errors
- conv=sync Pad blocks with zeros
- conv=fsync Physically write data out before finishing
Numbers may be suffixed by c (x1), w (x2), b (x512), kD (x1000), k (x1024), MD (x1000000), M (x1048576), GD (x1000000000) or G (x1073741824)
df [-Pkmh] [FILESYSTEM]... - Print filesystem usage statistics
- -P POSIX output format
- -k 1024-byte blocks (default)
- -m 1M-byte blocks
- -h Human readable (e.g. 1K 243M 2G)
dmesg [-c] [-n LEVEL] [-s SIZE] - Print or control the kernel ring buffer
- -c Clear ring buffer after printing
- -n LEVEL Set console logging level
- -s SIZE Buffer size
dnsdomainname - Show the system's DNS domain name
echo [OPTION]... [STRING]... - Display a line of text
- -n Suppress trailing newline
- -e Interpret backslash-escaped characters (i.e., \t=tab)
- -E Disable interpretation of backslash-escaped characters
egrep [ARG] FILE... - Print lines matching a pattern. Egrep is the same as grep -E
false - Do nothing, unsuccessfully
fgrep [ARG] FILE... - Print lines matching a pattern. Egrep is the same as grep -F
get_key_value FILE KEY - Finds first line starting with KEY from KEY=VALUE-paired FILE and returns Value
grep [-HhnlLoqvsriFE] [-m N] [-A/B/C N] PATTERN/-e PATTERN.../-f FILE [FILE]... - Search for PATTERN in FILEs (or stdin)
- -H Add 'filename:' prefix
- -h Do not add 'filename:' prefix
- -n Add 'line_no:' prefix
- -l Show only names of files that match
- -L Show only names of files that don't match
- -c Show only count of matching lines
- -o Show only the matching part of line
- -q Quiet. Return 0 if PATTERN is found, 1 otherwise
- -v Select non-matching lines
- -s Suppress open and read errors
- -r Recurse
- -i Ignore case
- -F PATTERN is a literal (not regexp)
- -E PATTERN is an extended regexp
- -m N Match up to N times per file
- -A N Print N lines of trailing context
- -B N Print N lines of leading context
- -C N Same as '-A N -B N'
- -e PTRN Pattern to match
- -f FILE Read pattern from file
gunzip [OPTIONS] [FILE]... - Uncompress FILEs (or stdin)
- -c Write to stdout
- -f Force
- -t Test file integrity
gzip [OPTIONS] [FILE]... - Compress FILEs (or stdin)
- -d Decompress
- -f Force
hostname [OPTIONS] [HOSTNAME | -F FILE] - Get or set hostname or DNS domain name
- -s Short
- -i Addresses for the hostname
- -d DNS domain name
- -f Fully qualified domain name
- -F FILE Use FILE's content as hostname
ip [OPTIONS] {address | route | link | -o[neline]} {COMMAND} - Show/manipulate routing, devices, policy routing and tunnels
ipcalc [OPTIONS] ADDRESS[[/]NETMASK] [NETMASK] - Calculate IP network settings from a IP address
- -b Display calculated broadcast address
- -n Display calculated network address
- -m Display default netmask for IP
- -p Display the prefix for IP/NETMASK
- -h Display first resolved host name
- -s Don't ever display error messages
kill [-l] [-SIG] PID... - Send a signal (default: TERM) to given PIDs
- -l List all signal names and numbers
ln OPTIONS] TARGET... LINK|DIR - Create a link LINK or DIR/TARGET to the specified TARGET(s)
- -s Make symlinks instead of hardlinks
- -f Remove existing destinations
- -n Don't dereference symlinks - treat like normal file
- -b Make a backup of the target (if exists) before link operation
- -S suf Use suffix instead of ~ when making backup files
login [-p] [-h HOST] [[-f] USER] - Begin a new session on the system
- -f Don't authenticate (user already authenticated)
- -h Name of the remote host
- -p Preserve environment
ls [-1AacCdeFilnpLRrSsTtuvwxXhk] [FILE]... - List directory contents
- -1 List in a single column
- -A Don't list . and ..
- -a Don't hide entries starting with .
- -C List by columns
- -c With -l: sort by ctime
- --color[={always,never,auto}] Control coloring
- -d List directory entries instead of contents
- -e List full date and time
- -F Append indicator (one of */=@|) to entries
- -i List inode numbers
- -l Long listing format
- -n List numeric UIDs and GIDs instead of names
- -p Append indicator (one of /=@|) to entries
- -L List entries pointed to by symlinks
- -R Recurse
- -r Sort in reverse order
- -S Sort by file size
- -s List the size of each file, in blocks
- -T N Assume tabstop every N columns
- -t With -l: sort by modification time
- -u With -l: sort by access time
- -v Sort by version
- -x List by lines
- -X Sort by extension
- -h List sizes in human readable format (1K 243M 2G)
mkdir mknod more mount mv netstat ntfs-3g ntfs-3g.probe pidof ping ping6 ps pwd rm rmdir run-parts sed sh sleep stat stty su sync synodd tar touch true umount uname usleep vi zcat
/sbin
blockdev dhcp6c dhcpcd dmsetup e2fsck fdisk freeramdisk fsck.ext3 fsck.ext4 getty halt hotplug hwclock ifconfig ifdown ifup init insmod ip ip6tables ip6tables-multi ip6tables-restore ip6tables-save iptables iptables-multi iptables-restore iptables-save iwconfig iwlist iwpriv klogd losetup lsmod lvcreate lvdisplay lvextend lvm lvremove lvs makedevs mdadm mkdosfs mke2fs mkfs.ext3 mkfs.ext4 mkfs.msdos mkfs.vfat mkswap modprobe parted portmap poweroff pvcreate pvdisplay pvremove pvresize pvs quota quotacheck quotaoff quotaon raidtool reboot resize2fs rmmod route setquota sfdisk sfdisk.org sparted swapoff swapon sysctl syslog-ng syslog-ng-ctl syslogd tune2fs vgcfgbackup vgcfgrestore vgchange vgcreate vgdisplay vgextend vgreduce vgremove vgs
/usr/bin
[ [[ a2p alac awk basename c2ph cksum clear cmp cpan cut diff dirname dprofpp du enc2xs env expr faad find find2perl flac free h2ph h2xs head id instmodsh killall libnetcfg logger mac metaflac nohup nslookup oggdec perl perl5.8.6 perlbug perlcc perldoc perlivp php piconv pl2pm printf prove psed pstruct readlink realpath renice reset s2p seq sort splain tail tee telnet test time top traceroute traceroute6 tty uniq unxz uptime uuidgen wc which who whoami wvunpack xargs xsubpp xz xzcat yes
/usr/sbin
adsl-connect adsl-start adsl-status adsl-stop chroot crond exportfs ietadm ietd inetd mountd nfsd nfsstat ntpdate pppd pppoe showmount sm-notify
statd [OPTIONS] - NSM (Network Status Monitor) RPC protocol status monitor
- -h, -?, --help - Print this help screen.
- -F, --foreground - Foreground (no-daemon mode)
- -d, --no-syslog - Verbose logging to stderr. Foreground mode only.
- -p, --port - Port to listen on
- -o, --outgoing-port - Port for outgoing connections
- -V, -v, --version - Display version information and exit.
- -n, --name - Specify a local hostname.
- -P - State directory path.
- -N - Run in notify only mode.
- -L, --no-notify - Do not perform any notification.
- -H - Specify a high-availability callout program.
telnetd [OPTIONS] - Handle incoming telnet connections via inetd
- -l LOGIN - Exec LOGIN on connect
- -f ISSUE_FILE - Display ISSUE_FILE instead of /etc/issue
- -K - Close connection as soon as login exits (normally wait until all programs close slave pty)
/usr/syno/bin
7z <command> [<switches>...] <archive_name> [<file_names>...] [<@listfiles...>] - A file archiver with highest compression ratio <Commands>
- a: Add files to archive
- b: Benchmark
- d: Delete files from archive
- e: Extract files from archive (without using directory names)
- l: List contents of archive
- t: Test integrity of archive
- u: Update files to archive
- x: eXtract files with full paths
<Switches>
- -ai[r[-|0]]{@listfile|!wildcard}: Include archives
- -ax[r[-|0]]{@listfile|!wildcard}: eXclude archives
- -bd: Disable percentage indicator
- -i[r[-|0]]{@listfile|!wildcard}: Include filenames
- -m{Parameters}: set compression Method (see the manual)
- -l: don't store symlinks; store the files/directories they point to; CAUTION : the scanning stage can never end because of symlinks like '..' (ex: ln -s .. ldir)
- -o{Directory}: set Output directory
- -p{Password}: set Password
- -r[-|0]: Recurse subdirectories (CAUTION: this flag does not do what you think, avoid using it)
- -sfx[{name}]: Create SFX archive
- -si[{name}]: read data from stdin
- -slt: show technical information for l (List) command
- -so: write data to stdout (eg: 7z a dummy -tgzip -so Doc.txt > archive.gz)
- -ssc[-]: set sensitive case mode
- -t{Type}: Set type of archive
- -v{Size}[b|k|m|g]: Create volumes
- -u[-][p#][q#][r#][x#][y#][z#][!newArchiveName]: Update options
- -w[path]: assign Work directory. Empty path means a temporary directory
- -x[r[-|0]]]{@listfile|!wildcard}: eXclude filenames
- -y: assume Yes on all queries
SYNOClearTdb FILE - Synology clear .tbd-File Tool
apple_dump
autoupdate.php
burnin-net
checkNewDSM.php
cjkterms
compare
composite
confmimetype
convert
convert-thumb
cupsdisable
cupsenable
curl
dcraw
ddns_reg_able.sh
downloadDSM.php
dsassistant
enca
ethtool
exiftool
exiv2
ffmpeg
ffmpeg-thumb
findhostd
firewalltool
get_section_key_value
hdparm
iscsitrgtool
jpegtran
ldapmodify
ldappasswd
ldapsearch
lpadmin
lpc
lpq
lpr
lprm
lpstat
mediaserver.sh
mount.cifs
mplayer
mplayer-daemon
nbprgstr
net
netcardtool
nmblookup
nzbget
openssl
pkgindexer_add
pkgindexer_del
qt-faststart
rsync
s2s_addWatchedShare
s2s_createShare
s2s_createTaskFakeFile
s2s_genSyncerCmdFile
s2s_monitor
s2s_rmWatchedShare
s2s_syncShareRealtimeTask
s2s_syncd
s2s_syncer
s3
scandisk
scemd
scriptindex
servicetool
slapacl
slapadd
slapauth
slapcat
slapdn
slapindex
slappasswd
smartctl
smbclient
smbcontrol
smbstatus
spacetool
sqlite3
sscamera
sscamgroup
ssctl
ssemap
ssevent
ssguard
ssh
ssh-keygen
sskit
sslayout
ssnotif
sspatrol
ssupgradeaccountdb
ssupgradefpsdb
ssupgradescheduledb
ssupgradestreamingtypedb
sswebui
stress
stressrtc
stressusb
syno_bkp_data_update
syno_disk_ctl OPTIONS DEVICE - Synology disk control
device: something like /dev/hda or /dev/sda
- --ncq-off: turn off ncq; ex: syno_disk_ctl --ncq-off /dev/sda
- --wcache-off: turn off write cache and tell kernel don't allow open it anymore; ex: syno_disk_ctl --wcache-off /dev/sda
- --wd-idle: Read, Set or disable the idle3 timer of Western Digital drives
- -d: disable wd idle3 timer ex: syno_disk_ctl --wd-idle -d /dev/sda
- -g: get wd disk idle3 timer ex: syno_disk_ctl --wd-idle -g /dev/sda
- -s<value>: set wd disk idle3 timer ex: syno_disk_ctl --wd-idle -s80 /dev/sda
syno_hdd_util OPTION - Synology Disk Utility
- --ssd_detect; ex: syno_hdd_util --ssd_detect
syno_hibernate_debug_tool OPTION - Synology Hibernation Debug Tool
- --enable [VALUE]; ex: syno_hibernate_debug_tool --enable 10; ex: syno_hibernate_debug_tool --enable 1
- --disable; ex: syno_hibernate_debug_tool --disable
- --enable-force_hibernation; ex: syno_hibernate_debug_tool --enable-force_hibernation
- --disable-force_hibernation; ex: syno_hibernate_debug_tool --disable-force_hibernation
syno_poweroff_task - Synology Shutdown and Poweroff Tool
synoacltool OPTIONS - Synolgy Accesscontrol Tool (more information by using -h-Option)
- -h: show help
- -check: check acl permission of file
- -get: get syno acl of file
- get-perm: extract windows permission from acl or linux permission
- -add: add syno ace into file
- -replace: replace specified ace by index number
- -del: delete syno acl of file
- -get-archive: get ACL archive bit
- -set-archive: set ACL archive bit
- -del-archive: delete ACL archive bit
- -copy: copy ACL from source to destination, only works when ACL exists
- -set-eadir-acl: set ACL for EA dir
- -enforce-inherit: enforce ACL inheritance
- -set-share-default-perm: set default ACL on share
synoauth local_username password - Set/establish password to local user
synoautoblock OPTIONS - Manage autoblock feature
- --help
- --attempt ip
- --deny ip
- --reset ip
synoblog_backup [-r|-b] p [-u username] [-o] - Manage blog feature
- -b Backup blog database.
- -r Restore blog database.
- p Path to store backup file or to get restore file.
- -u username to backup or restore blog.
- -o Overwrite mode for restoring blog database. Default is skip mode.
synobootup
synobox
synobttool
synocfgen
synocheckiscsitrg
synocheckshare
synocheckvolume
synodctest
synodiskport
synodlmail
synodsmnotify
synoeaupgrade
synoethinfo
synoexternal
synofetch
synoflvconv
synofstool
synogetfstype
synogetkeyvalue
synogrinst
synoindex
synoitunesdb
synojournalerr
synokerneltz
synoldapbrowser
synoldapserver
synolocalbkp
synolocalbkpd
synologset1
synomail
synomkflv
synomkthumb
synomkthumbd
synomount
synomsg_collector
synonetbkp
synonetbkpd
synonetbkps3
synopftest
synophoto_backup
synophoto_dsm_user
synophoto_sns_utils
synophotoio
synopkg
synoportforward
synoprint
synorcvol
synornd
synorsstool
synosata
synosavetime
synosearch
synosetwins
synoshareperm
synosms
synosubox
synosurv_backup
synosyncdctime
synothumb
synotunnelexec
synoupnp
synoups
synousbcam
synousbcopy
synousbdisk
synowimax
synowireless
tar
tdbbackup
tdbtool
timebkp
umount.cifs
unrar
unzip
ups.sh
upsc
upsdrvctl
usbhid-ups
volume
volumetool
wbinfo
wget
wget.org
zip
/usr/syno/sbin
afpd amuled atalkd avahi-daemon bind_driver cnid_dbd cnid_metad cups-lpd cupsd ddnsd dms dms.local ecryptfs-rewrap-passphrase ecryptfs-unwrap-passphrase ecryptfs-wrap-passphrase fileindexd ftpd gcpd hotplugd keyctl kinit klist lighttpd manutild mount.ecryptfs mt-daapd nmbd nslcd papd scheduler slapd smbd snmpd ssd sseventexportd sshd ssrotated synoairplayd synoamulecgid synoaudiod synodate synogroup synoindexd synoisns synoldapclient synologd synolvm_expand synolvm_mklv synolvm_mksnap synolvm_rmsnap synomkflvd synonet synorcd synoservice synoshare synouser synowin transmissiond upnpd upsd upsmon upssched usbip usbipd vsctrld winbindd
