Archiv:Bluetooth Treiber
- install compiler from ipkg
ipkg install gcc
- Setup Kernel Sourcen und bauen der bluetooth treiber
Toolchain besorgen: synogpl-2198-x64.tbz auspacken tar -xpvjf synogpl-2198-x64.tbz
cd source/linux-2.6.32/ cp synoconfigs/x86_64 .config # Kernel Sourcen vorbereiten
make config # Erforderliche bluetooth Treiber auswählen
- bluez utils mittels ipkg installieren
DiskStation2> ipkg list_installed|grep bluez bluez-hcidump - 1.42-1 - bluez-libs - 3.36-1 - Bluetooth libraries. bluez-utils - 3.36-3 -
- bluetooth kernel modul laden
modprobe bluetooth modprobe btusb
- bluetooth stack mittels hcitool testen
hciconfig hci0 up hcitool scan
- Startup Script bluetooth /opt/etc/init.d/S30bluetooth
#!/bin/sh start() { /sbin/modprobe btusb /opt/sbin/hciconfig hci0 up /opt/sbin/hciconfig hci0 reset } stop() { /opt/sbin/hciconfig hci0 down /sbin/rmmod btusb /sbin/rmmod bluetooth } case "$1" in start) start ;; stop) stop ;; restart) stop sleep 1 start ;; *) echo "Usage: $0 (start|stop|restart)" exit 1 ;; esac # End
