Installation von Tiny Tiny RSS/Installationsskript
Installationsskript für Tiny Tiny RSS.
#!/bin/sh # #ttrss - post-install # switch to directory read -p "Give the directory of ttrss (enter '.' for current directory): " dir if [ -z "$dir" ]; then echo "no dir given" exit 1 fi cd "$dir" # Safety check if [ ! -e config.php* ]; then echo "This does not look like a ttrss directory" echo "Exiting..." exit 1 fi # check config_version ConVer=26 CONFIG_VERSION=`awk -F ' |)' '/CONFIG_VERSION/{print $2}' config.php-dist` if [ "$ConVer" -ne "$CONFIG_VERSION" ]; then echo "This script is written for a different CONFIG_VERSION of ttrss" exit 1 fi #mysql echo "Configuring mysql" read -p "Enter the database name (will be 'ttrss_db' if you leave it empty): " db read -p "Enter the MySQL user accessing ttRSSes database (will be 'ttrss_user' if you leave it empty): " db_user read -p "Enter this users password (will be the users name if you leave it empty): " db_pass read -p "Enter the full URL to TT RSSes directory (a la http://yourserver/tt-rss/): " ttrss_url # set default names if [ -z "$db" ]; then db=ttrss_db fi if [ -z "$db_user" ]; then db_user=ttrss_user fi if [ -z "$db_pass" ]; then db_pass="$db_user" fi # get MySQLs root passwd (refactored) got_root=0 root_pass="" get_MySQL_root (){ if [ "$got_root" -ne 0 ]; then return 0 fi read -p "Enter MySQL's root password: " root_pass /usr/syno/mysql/bin/mysql -u root -p"$root_pass" -e quit 2> /dev/null if [ $? -ne 0 ]; then echo "mysql's root password is wrong" get_MySQL_root fi got_root=1 return 0 } # create database read -p "Should I create the MySQL database '$db'? (y/n): " input if [ "$input" = "yes" -o "$input" = "y" ]; then echo "Creating database '$db'." get_MySQL_root /usr/syno/mysql/bin/mysql -u root -p"$root_pass" -e "CREATE DATABASE $db;" if [ $? -ne 0 ]; then echo "There were problems with the creation of database '$db'." echo "Exiting" exit 1 else echo "Created database '$db'." fi fi #create user read -p "Should I create the MySQL user '$db_user' and give him priviliges on '$db'? (y/n): " input if [ "$input" = "yes" -o "$input" = "y" ]; then echo "Creating MySQL user '$db_user' and granting him privileges on database '$db'." get_MySQL_root #Creating the user and granting privileges. /usr/syno/mysql/bin/mysql -u root -p"$root_pass" -e "CREATE USER '$db_user'@'localhost' IDENTIFIED BY '$db_pass'; GRANT USAGE ON *.* TO '$db_user'@'localhost' WITH MAX_QUERIES_PER_HOUR 0 MAX_CONNECTIONS_PER_HOUR 0 MAX_UPDATES_PER_HOUR 0 MAX_USER_CONNECTIONS 0; GRANT ALL PRIVILEGES ON \`$db\`.* TO '$db_user'@'localhost'; FLUSH PRIVILEGES;" if [ $? -ne 0 ]; then echo "There were problems with the creation of user '$db_user'." echo "Exiting" exit 1 else echo "Created user '$db_user'." fi fi #install schema echo "Installing schema." /usr/syno/mysql/bin/mysql -u "$db_user" -D "$db" -p"$db_pass" < schema/ttrss_schema_mysql.sql if [ $? -ne 0 ]; then echo "There were problems installing the schema." echo "Exiting" exit 1 else echo "Schema installed." fi echo "Finished mysql configuration." #give nobody ownership of some directories. for dir in "lock" "cache" "feed-icons"; do chown -R nobody:nobody "$dir" done #create config file echo "Creating config.php" cp -p config.php-dist config.php sed -i -e "s#[ ]*define('DB_TYPE',[ ]*\".*\");.*# define('DB_TYPE', \"mysql\");#" config.php sed -i -e "s#[ ]*define('DB_USER',[ ]*\".*\");.*# define('DB_USER', \"$db_user\");#" config.php sed -i -e "s#[ ]*define('DB_NAME',[ ]*\".*\");.*# define('DB_NAME', \"$db\");#" config.php sed -i -e "s#[ ]*define('DB_PASS',[ ]*\".*\");.*# define('DB_PASS', \"$db_pass\");#" config.php sed -i -e "s#[ ]*define('SELF_URL_PATH',[ ]*'.*');.*# define('SELF_URL_PATH', '$ttrss_url');#" config.php echo "Finished!"
