Austausch einer HDD ?
ViperRt10
16. Aug 2009
Lwk3 dürfte dann nicht sata3 sein...
smartctl 6.5 (build date Sep 26 2022) [x86_64-linux-4.4.302+] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Toshiba MG06ACA... Enterprise Capacity HDD
Device Model:     TOSHIBA MG06ACA10TE
Serial Number:    X120A006FKQE
LU WWN Device Id: 5 000039 b38c84916
Firmware Version: 0109
User Capacity:    10,000,831,348,736 bytes [10.0 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA >3.2 (0x1ff), 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Mar 13 08:08:30 2024 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x84)    Offline data collection activity
                    was suspended by an interrupting command from host.
                    Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (  120) seconds.
capabilities:              (0x5b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    No Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      (1017) minutes.
SCT capabilities:            (0x003d)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
ID# ATTRIBUTE_NAME                                                   FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate                                              0x000b   100   100   050    Pre-fail  Always       -       0
  2 Throughput_Performance                                           0x0005   100   100   050    Pre-fail  Offline      -       0
  3 Spin_Up_Time                                                     0x0027   100   100   001    Pre-fail  Always       -       9237
  4 Start_Stop_Count                                                 0x0032   100   100   000    Old_age   Always       -       2010
  5 Reallocated_Sector_Ct                                            0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate                                                  0x000b   100   100   050    Pre-fail  Always       -       0
  8 Seek_Time_Performance                                            0x0005   100   100   050    Pre-fail  Offline      -       0
  9 Power_On_Hours                                                   0x0032   060   060   000    Old_age   Always       -       16108
 10 Spin_Retry_Count                                                 0x0033   100   100   030    Pre-fail  Always       -       0
 12 Power_Cycle_Count                                                0x0032   100   100   000    Old_age   Always       -       309
191 G-Sense_Error_Rate                                               0x0032   100   100   000    Old_age   Always       -       1
192 Power-Off_Retract_Count                                          0x0032   100   100   000    Old_age   Always       -       20
193 Load_Cycle_Count                                                 0x0032   100   100   000    Old_age   Always       -       2012
194 Temperature_Celsius                                              0x0022   100   100   000    Old_age   Always       -       43 (Min/Max 19/49)
196 Reallocated_Event_Count                                          0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector                                           0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable                                            0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count                                             0x0032   200   200   000    Old_age   Always       -       0
220 Disk_Shift                                                       0x0002   100   100   000    Old_age   Always       -       134610956
222 Loaded_Hours                                                     0x0032   065   065   000    Old_age   Always       -       14212
223 Load_Retry_Count                                                 0x0032   100   100   000    Old_age   Always       -       0
224 Load_Friction                                                    0x0022   100   100   000    Old_age   Always       -       0
226 Load-in_Time                                                     0x0026   100   100   000    Old_age   Always       -       533
240 Head_Flying_Hours                                                0x0001   100   100   001    Pre-fail  Offline      -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     11463         -
# 2  Short offline       Completed without error       00%     11295         -
# 3  Short offline       Completed without error       00%     11127         -
# 4  Short offline       Completed without error       00%     10959         -
# 5  Extended offline    Completed without error       00%     10952         -
# 6  Short offline       Completed without error       00%     10791         -
# 7  Short offline       Completed without error       00%     10623         -
# 8  Short offline       Completed without error       00%     10455         -
# 9  Short offline       Completed without error       00%     10288         -
#10  Extended offline    Completed without error       00%     10214         -
#11  Short offline       Completed without error       00%     10126         -
#12  Short offline       Completed without error       00%      9958         -
#13  Short offline       Completed without error       00%      9790         -
#14  Short offline       Completed without error       00%      9622         -
#15  Extended offline    Completed without error       00%      9495         -
#16  Short offline       Completed without error       00%      9454         -
#17  Short offline       Completed without error       00%      9286         -
#18  Short offline       Completed without error       00%      9118         -
#19  Short offline       Completed without error       00%      8950         -
#20  Short offline       Completed without error       00%      8782         -
#21  Extended offline    Completed without error       00%      8751         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Das ist die falsche HDD.
Was ist sata2?
ViperRt10
16. Aug 2009
das ist Lwk 3
Model Family:     Seagate IronWolf
Device Model:     ST4000VN008-2DR166
Serial Number:    ZDH9LNBN
LU WWN Device Id: 5 000c50 0c93b6f94
Firmware Version: SC60
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5980 rpm
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Mar 13 08:10:35 2024 CET
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
                    been run.
data collection:         (  581) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    power-saving mode.
recommended polling time:      (   1) minutes.
recommended polling time:      ( 607) minutes.
Conveyance self-test routine
SCT capabilities:            (0x50bd)    SCT Status supported.
SMART Attributes Data Structure revision number: 10
  1 Raw_Read_Error_Rate                                              0x000f   082   064   044    Pre-fail  Always       -       146745614
  3 Spin_Up_Time                                                     0x0003   094   093   000    Pre-fail  Always       -       0
  4 Start_Stop_Count                                                 0x0032   096   096   020    Old_age   Always       -       4765
  7 Seek_Error_Rate                                                  0x000f   083   060   045    Pre-fail  Always       -       197310481
  9 Power_On_Hours                                                   0x0032   080   080   000    Old_age   Always       -       17906 (111 9 0)
 10 Spin_Retry_Count                                                 0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count                                                0x0032   096   096   020    Old_age   Always       -       4434
184 End-to-End_Error                                                 0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect                                               0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout                                                  0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes                                                  0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel                                          0x0022   072   063   040    Old_age   Always       -       28 (Min/Max 27/31)
191 G-Sense_Error_Rate                                               0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count                                          0x0032   100   100   000    Old_age   Always       -       45
193 Load_Cycle_Count                                                 0x0032   098   098   000    Old_age   Always       -       4875
194 Temperature_Celsius                                              0x0022   028   040   000    Old_age   Always       -       28 (0 17 0 0 0)
197 Current_Pending_Sector                                           0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable                                            0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count                                             0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours                                                0x0000   100   253   000    Old_age   Offline      -       17882h+42m+44.359s
241 Total_LBAs_Written                                               0x0000   100   253   000    Old_age   Offline      -       31808639413
242 Total_LBAs_Read                                                  0x0000   100   253   000    Old_age   Offline      -       56642634446
No Errors Logged
# 1  Extended offline    Completed without error       00%     17840         -
# 2  Short offline       Completed without error       00%     17831         -
# 3  Short offline       Completed without error       00%     13248         -
# 4  Short offline       Completed without error       00%     13080         -
# 5  Short offline       Completed without error       00%     12912         -
# 6  Short offline       Completed without error       00%     12744         -
# 7  Extended offline    Completed without error       00%     12729         -
# 8  Short offline       Completed without error       00%     12576         -
# 9  Short offline       Completed without error       00%     12408         -
#10  Short offline       Completed without error       00%     12240         -
#11  Short offline       Completed without error       00%     12072         -
#12  Extended offline    Completed without error       00%     11990         -
#13  Short offline       Completed without error       00%     11909         -
#14  Short offline       Completed without error       00%     11741         -
#15  Short offline       Completed without error       00%     11573         -
#16  Short offline       Completed without error       00%     11405         -
#17  Extended offline    Completed without error       00%     11270         -
#18  Short offline       Completed without error       00%     11237         -
#19  Short offline       Completed without error       00%     11069         -
#20  Short offline       Completed without error       00%     10901         -
#21  Short offline       Completed without error       00%     10733         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Raw & Seak sagen dann: HDD Müll ?
Sieht sauber aus.
Reaktionen: ViperRt10
ViperRt10
16. Aug 2009
gibts das auch für seek?
schaut dann OK aus, warum hat die Syno dann wild geschrien??
Damit kannst du beide Werte umrechnen ID 1 +7
Keine Ahnung, sehr strange.
ViperRt10
16. Aug 2009
alles klar, besten dank
dann habe ich jetzt Reserve-HDD
sollte ich da ev. Hot-Spare draus machen?
Kann man machen, muss man aber nicht :cool:
ViperRt10
16. Aug 2009
am besten dann rausnehmen aus der Syno?
Ja, würde ich so machen. Wie sieht denn dein gesamtes Speicher Setup aus?
ViperRt10
16. Aug 2009
einfach rausnehmen, oder soll/kann man die hdd vorher stoppen/aus der DS entfernen?
Wieviele Laufwerke hast du verbaut?
ViperRt10
16. Aug 2009
DS 5/6
DX 5/5
ahhh, hatte mich etwas gewundert, deine Signatur ist nicht up to date.
Leg die HDD in den Schrank.
ViperRt10
16. Aug 2009
OK danke.
