- Mitglied seit
- 18. Mrz 2009
- Punkte für Reaktionen
- 275
Das einzige, was aus der Betaversion 1869 benötigt wird ist die scemd
VG mas27
also müss(t)en wir aus der Beta die beiden Files rausholen.... sobald wir die beta finden...I ll add the synobios.o and scemd file are easy to get from http://ukdl.synology.com/download/beta/DSM3.2_beta/DSM_DS-108j_1869.pat
This pat file is TAR archive. Rename it DSM_DS-108j_1869.tar and untar this file.
It contains a file hda1.tgz which is a gzipped tar file. Untar this hda1.tgz file and you ll find lib/modules/synobios.o and usr/syno/bin/scemd files.
Feb 10 21:16:30 scemd: modules/led.c:82 unexpected LED behavior
Feb 10 21:16:32 scemd: modules/led.c:82 unexpected LED behavior
Feb 10 21:16:34 scemd: modules/led.c:82 unexpected LED behavior
Feb 10 21:16:37 root: /usr/syno/etc/rc.d/S98findhostd.sh stop findhostd
Feb 10 21:16:44 rsyncd[2357]: rsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at rsync.c(572) [receiver=3.0.4]
Feb 10 21:16:51 ntpdate: Sync with time server 157.161.57.2 offset -0.099280 sec.
Feb 10 21:16:55 syslogd exiting
Feb 10 21:17:30 syslogd started: BusyBox v1.16.1
Feb 10 21:17:31 s00_synocheckfstab: system_blk_dev_readahead_set.c:35 Failed to set '/dev/hda3''s readahead to 4096d
Feb 10 21:17:31 s00_synocheckfstab: volume_readahead_allset.c:32 Failed to set RA on [/dev/hda3]
Feb 10 21:17:32 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Feb 10 21:17:34 dhcpcd[1102]: dhcpReboot: do not want cache
Feb 10 21:17:37 scemd: scemd.c:126 fan_type=0, raid_type=0, led_type=0, thermal_type=0, fanctrl_type=0, auto_poweron_type=0, dual_power_type=0, usbcopy_type=0, fan_number=0, ebox_type=1, pis_type=0, rtc_type=0
Feb 10 21:17:37 scemd: modules/mapping_fan.c:215 Default fan type FAN_UNKNOWN is used.
Feb 10 21:17:37 scemd: modules/disk_hibernation.c:430 Force hibernation enable, idle minutes 10
Feb 10 21:17:38 synoprint: printer_enable_ext.c:488 delete printer failed: no bus id
Feb 10 21:17:45 scemd: modules/cpu_frequence_adjust.c:176 cpufreq module was not loaded, CPU Frequence Scalling was disabled.
Feb 10 21:17:46 kernel: PCI: 00:0e.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW.
Feb 10 21:17:46 kernel: PCI: 00:0e.2 PCI cache line size corrected to 32.
Feb 10 21:17:46 kernel: USB_DEVICE: This is hub. No need to call_policy_interface.
Feb 10 21:17:46 kernel: eth0: network connection up using port A
Feb 10 21:17:46 kernel: speed: 100
Feb 10 21:17:46 kernel: autonegotiation: yes
Feb 10 21:17:46 kernel: duplex mode: full
Feb 10 21:17:46 kernel: flowctrl: symmetric
Feb 10 21:17:46 kernel: irq moderation: disabled
Feb 10 21:17:46 kernel: scatter-gather: enabled
Feb 10 21:17:46 kernel: tx-checksum: enabled
Feb 10 21:17:46 kernel: rx-checksum: enabled
Feb 10 21:17:46 syno_hdd_util: Model:[WDC WD10EADS-22M2B0], Firmware:[01.00A01], S/N:[WD-WCAV54205940] in [/dev/hda] is not ssd
Feb 10 21:17:48 dhcpcd[1102]: client.c(1589)HUP ddnsd result: return code = 256
Feb 10 21:17:52 synousbdisk: RCClean succeeded
Feb 10 21:17:53 synosata: synosata.c:174 failed to enum all external sata devices
Feb 10 21:17:54 ddnsd: main(ddnsd.c:2783): not enable DDNS, shutdown daemon
Feb 10 21:18:01 ntpdate: Sync with time server 157.161.57.2 offset 1.484681 sec.
Feb 10 21:18:03 cupsd[1939]: [listen.c:184] Unable to open listen socket for address :::631 - Address family not supported by protocol.
Feb 10 21:19:47 scemd: scemd.c:380 stop manutild.
Hallo Leute!
Wie kann mann eigentlich die Festplatte formatieren ohne den aus dem ds auszubauen,weil hier im Forum hat einer erzählt das er es ohne ausbauen gemacht hat, um den hda1 bereich zu vergrößern damit ich die 3.1 oder 3.2 installieren kann.
mfg
cruiser-22
