Was auch immer für dich richtig ist, auf jeden Fall sollte es danach gehen.
NAS> python RSScrawler.py
Traceback (most recent call last):
File "RSScrawler.py", line 44, in <module>
import pycurl
ImportError: No module named pycurl
NAS> easy_install pycurl
Searching for pycurl
Reading http://pypi.python.org/simple/pycurl/
Best match: pycurl 7.43.0
Downloading https://pypi.python.org/packages/12/3f/557356b60d8e59a1cce62ffc07ecc03e4f8a202c86adae34d895826281fb/pycurl-7.43.0.tar.gz#md5=c94bdba01da6004fa38325e9bd6b9760
Processing pycurl-7.43.0.tar.gz
Running pycurl-7.43.0/setup.py -q bdist_egg --dist-dir /tmp/easy_install-VZebhq/pycurl-7.43.0/egg-dist-tmp-LonCll
Using curl-config (libcurl 7.24.0)
warning: no files found matching 'src/Makefile'
unable to execute '/usr/local/i686-pc-linux-gnu/bin/i686-pc-linux-gnu-ccache-gcc': No such file or directory
error: Setup script exited with error: command '/usr/local/i686-pc-linux-gnu/bin/i686-pc-linux-gnu-ccache-gcc' failed with exit status 1
NAS> /usr/local/python/bin/python RSScrawler.py --ontime --log-level=DEBUG
File "RSScrawler.py", line 34, in <module>
from docopt import docopt
ImportError: No module named docopt
