- Mitglied seit
- 30. Dez 2012
- Punkte für Reaktionen
- 3.710
time="2024-01-21T17:52:00+01:00" level=info msg="Verifying required tools" type=metrics
time="2024-01-21T17:52:00+01:00" level=info msg="Executing command: smartctl --scan --json" type=metrics
smartctl 6.5 (build date Oct 7 2021) [armv7l-linux-3.2.101] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=======> UNRECOGNIZED OPTION: json
Use smartctl -h to get a usage summary
time="2024-01-21T17:52:00+01:00" level=error msg="Error scanning for devices: exit status 1" type=metrics
time="2024-01-21T18:19:43+01:00" level=info msg="Verifying required tools" type=metrics
time="2024-01-21T18:19:43+01:00" level=info msg="Executing command: smartctl --scan --json" type=metrics
ERROR: ld.so: object 'openhook.so' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
"json_format_version": [
1,
"smartctl": {
"version": [
7,
"pre_release": false,
"svn_revision": "5530",
"platform_info": "armv7l-linux-3.2.101",
"build_info": "(localbuild)",
"argv": [
"smartctl",
"--scan",
"--json"
"exit_status": 0
"devices": [
"name": "/dev/sda",
"info_name": "/dev/sda",
"type": "scsi",
"protocol": "SCSI"
"name": "/dev/sdb",
"info_name": "/dev/sdb",
"type": "scsi",
"protocol": "SCSI"
time="2024-01-21T18:19:43+01:00" level=error msg="Error decoding detected devices: invalid character 'E' looking for beginning of value" type=metrics
/opt/bin
in PATH aufgenommen wird, wenn ein Terminal aufgemacht wird. --device=sat
zusätzlich notwendig ist. In der Collector Konfiguration konfiguriert man das ja auch. Du kannst ja mal Deine Konfiguration mit uns teilen.Die collector.yaml :. /opt/etc/profile; /volume1/\@Entware/scrutiny/bin/run_collect.sh
Kaum macht man's richtig, dann geht's auchversion: 1
host:
devices:
- device: /dev/sda
type: 'sat'
- device: /dev/sdb
type: 'sat'
api:
endpoint: 'http://192.168.x.x:8800'
