Synology rt6600ax for M-Net
nettanourne
14. Feb 2024
Hello everyone!
I recently bought an RT6600AX (SRM 1.3.1) router and I'm trying to configure it to connect to the network of an M-Net provider in Germany.
I have connected the WAN port of my router to the LAN port of GPON Terminal Huawei EG8012H5.
To set up the connection, the ISP provides the data:
PPP-User - username
PPP-Password - password
VLAN-ID Data - 40
Protocol - IPv6 DS-Lite
AFTR Address - aftr.prod.m-online.net
In the router settings I specified:
WAN port tagged VLAN 40;
Primary interface: connection type is set as DS-Lite, AFTR address is aftr.prod.m-online.net;
IPv6 settings: PPPoE, username&password, as specified from m-net personal cabinet.
The connection shows as "limited", no internet access.
ISP support replied as follows: "According to the remote diagnosis, the M-net areas for which we are responsible are usable. We have also noticed that dial-up processes occur again and again, but the connection is then always disconnected again after a relatively short time. Apparently not by us. It is therefore reasonable to assume that your own hardware is incorrectly configured."
What I'm doing wrong? How to set it up correctly?
luddi
05. Sep 2012
Hello, I'm not familiar with the Synology router, and therefore I can not help in detail for specific settings on this device. But did you have the chance to check with another device to verify that the connection to your ISP in general will be established?
metalworker
25. Apr 2023
Du kannst hier Deutsch schreiben , ist ja ein deutsches Forum.
Also erstmal muss dien Huawei Router sauber die verbindung aufbauen.
Hast du den Huawei Router von dem ISP bekommen?
nettanourne
14. Feb 2024
Unfortunately, I just moved into this apartment. I don't have any other equipment.
nettanourne
14. Feb 2024
Sorry for the English, my Deutsch is not good enough, I just started learning it.
Yes, the GPON terminal is installed by the provider.
elisenlebkuch
17. Mrz 2024
Hallo, ist der Thread noch aktiv? Ich habe EXAKT das gleiche Problem, nur dass ich noch nicht versucht habe, M-net zu kontaktieren.
metalworker
25. Apr 2023
Na dann schreib den mal an
