- 30. Dez. 2012
Das Häkchen? Welches genau?Hast du in den Einstellungen das Häkchen gesetzt?
services:
immich-server:
container_name: immich_server
image: ghcr.io/immich-app/immich-server:${IMMICH_VERSION:-release}
#extends:
# file: /volume2/docker/appdata/immich-app/hwaccel.transcoding.yml
# service: quicksync # set to one of [nvenc, , rkmpp, vaapi, vaapi-wsl] for accelerated transcoding
volumes:
# Do not edit the next line. If you want to change the media storage location on your system, edit the value of UPLOAD_LOCATION in the .env file
#- ${UPLOAD_LOCATION}:/data
- /etc/localtime:/etc/localtime:ro
- /volume1/data/photo:/usr/src/app/upload:rw
- /volume1/data/photo:/volume1/data/photo:ro
- /volume1/photo:/volume1/photo:ro
env_file:
- stack.env
devices:
- /dev/dri:/dev/dri
ports:
- '2283:2283'
depends_on:
- redis
- database
restart: always
healthcheck:
disable: false
immich-machine-learning:
container_name: immich_machine_learning
# For hardware acceleration, add one of -[armnn, cuda, rocm, openvino, rknn] to the image tag.
# Example tag: ${IMMICH_VERSION:-release}-cuda
image: ghcr.io/immich-app/immich-machine-learning:${IMMICH_VERSION:-release}-openvino
device_cgroup_rules:
- 'c 189:* rmw'
devices:
- /dev/dri:/dev/dri
#extends: # uncomment this section for hardware acceleration - see https://immich.app/docs/features/ml-hardware-acceleration
#file: hwaccel.ml.yml
#service: cpu # set to one of [armnn, cuda, rocm, openvino, openvino-wsl, rknn] for accelerated inference - use the `-wsl` version for WSL2 where applicable
volumes:
- model-cache:/cache
- /dev/bus/usb:/dev/bus/usb
env_file:
- stack.env
restart: always
healthcheck:
disable: false
redis:
container_name: immich_redis
image: docker.io/valkey/valkey:8-bookworm@sha256:a137a2b60aca1a75130022d6bb96af423fefae4eb55faf395732db3544803280
healthcheck:
test: redis-cli ping || exit 1
restart: always
database:
container_name: immich_postgres
image: ghcr.io/immich-app/postgres:14-vectorchord0.4.3-pgvectors0.2.0@sha256:32324a2f41df5de9efe1af166b7008c3f55646f8d0e00d9550c16c9822366b4a
environment:
POSTGRES_PASSWORD: ${DB_PASSWORD}
POSTGRES_USER: ${DB_USERNAME}
POSTGRES_DB: ${DB_DATABASE_NAME}
POSTGRES_INITDB_ARGS: '--data-checksums'
# Uncomment the DB_STORAGE_TYPE: 'HDD' var if your database isn't stored on SSDs
# DB_STORAGE_TYPE: 'HDD'
volumes:
# Do not edit the next line. If you want to change the database storage location on your system, edit the value of DB_DATA_LOCATION in the .env file
- ${DB_DATA_LOCATION}:/var/lib/postgresql/data
shm_size: 128mb
restart: always
volumes:
model-cache:
gerne@arphex Kannst du bitte trotzdem mal deine Einstellungen posten?
