- 27. Mai 2007
Hallo
Es gibt eine neue Firmware für die DS-207. Leider hab ich noch nichts von Zeitsteuerung gefunden, wo man einstellen kann wann sie hoch und runterfährt. Dauert wohl doch noch etwas - schade!
Hier der Originaltext zur neuen Firmware:
Synology Disk Station DS207 Release Notes
Version: v2.0.3 - 0509
(2007/08/21)
Change log
1. (3809) Danish, Norwegian, and Swedish management interface are now supported. This localization will also take effect on Synology Assistant, Synology Data Replicator II, and Synology Download Redirector.
2. (3528) Audio Station: The Synology Audio Station is a web-based music organizer for users to manage, play personalized playlists for stored digital music, as well as streaming Internet radio stations and iPod music. Simply connect a verified USB speakers and the Synology Remote receptor to the USB port on specified Synology products, users will be able to enjoy digital music, Internet radio, and iPod with the freedom of a wireless remote control.
3. (2544) File Station: The Synology File Station is a web-based file organizer that allows users to access and manage files remotely with major web browsers. Internet file sharing no longer requires advanced FTP knowledge. The Synology File Station also increased the file transfer efficiency between shared folders. The files require no routing through your computer anymore. Data moving can now be done in seconds.
4. The management login page now dynamically shows the enabled web application services.
5. (3406) 3 More UPS devices are support: APC Back-UPS ES350, APC Back-UPS CS650, APC Smart UPS 750. See complete support list.
6. (3562) Photo Station 2 + video: Playing videos is now supported on Photo Station 2 + video. Video clips uploaded to the "photo" shared folder can be viewed directly on an adjustable screen in the web interface without having to be downloaded to the desktop and played with your media player.
7. (3755) PPPoE Synology product can now connect directly to the Internet.
8. (3491) Ez-Internet: with the integration of DynDNS.org service, hosting a fixed domain name website with a dynamic IP is supported now.
9. (3523) Rsync: Synology Network Backup now supports backing up to or from any Rsync compatible server.
10. (3745) Report external IP in PASV mode: By enabling this option, the server will report its external IP to FTP clients. The option only works when the server is behind NAT, and the FTP clients reside in a different subnet with the server. Usually you don’t need to enable this option, but if the FTP clients fail to connect to the server, you can try to enable this option.
11. Data upload through Windows network has massive 10-20% transfer efficiency increase, which varies among different models.
Limitation & Known Issues
* Safari 3 Beta is not officially supported currently. Please access Synology Products with prior versions of Safari or any other browsers.
* See "Limitation & Known Issues for all versions" below for other limitations.
(2007/08/21)
Change log
