anmelde error mail station
wolfz
10. Dez 2011
unix 2 [ ACC ] STREAM LISTENING 4855 5275/avahi-daemon: /va
r/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 7297 6450/afpd /va
r/run/afpd_ipc
unix 2 [ ACC ] STREAM LISTENING 2254 2751/postgres /tm
p/.s.PGSQL.5432
unix 2 [ ACC ] STREAM LISTENING 8662 7306/synoaudiod /tm
p/mplayer.sock
unix 2 [ ACC ] STREAM LISTENING 8664 7306/synoaudiod /tm
p/synoaudiod.sock
unix 2 [ ACC ] STREAM LISTENING 7403 7020/vsctrld /tm
p/vsctrlsocket
unix 2 [ ACC ] STREAM LISTENING 5873 6278/fileindexd /tm
p/fileindexd.sck
unix 2 [ ACC ] STREAM LISTENING 130198 11310/saslauthd /va
r/run/saslauthd/mux
Wolf> netstat -lnp grep 143
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
PID/Program name
tcp 0 0 0.0.0.0:49152 0.0.0.0:* LISTEN
7306/synoaudiod
tcp 0 0 0.0.0.0:993 0.0.0.0:* LISTEN
11332/dovecot
tcp 0 0 0.0.0.0:995 0.0.0.0:* LISTEN
11332/dovecot
tcp 0 0 0.0.0.0:9093 0.0.0.0:* LISTEN
6395/transmissiond
wolfz
10. Dez 2011
tcp 0 0 0.0.0.0:110 0.0.0.0:* LISTEN
11332/dovecot
tcp 0 0 0.0.0.0:143 0.0.0.0:* LISTEN
11332/dovecot
tcp 0 0 127.0.0.1:783 0.0.0.0:* LISTEN
11329/spamd.pid
tcp 0 0 0.0.0.0:50001 0.0.0.0:* LISTEN
7082/dms
tcp 0 0 0.0.0.0:50002 0.0.0.0:* LISTEN
7096/lighttpd
tcp 0 0 0.0.0.0:31860 0.0.0.0:* LISTEN
6395/transmissiond
tcp 0 0 0.0.0.0:631 0.0.0.0:* LISTEN
4953/cupsd
tcp 0 0 0.0.0.0:5432 0.0.0.0:* LISTEN
2751/postgres
tcp 0 0 0.0.0.0:25 0.0.0.0:* LISTEN
11324/master
tcp 0 0 127.0.0.1:4700 0.0.0.0:* LISTEN
6448/cnid_metad
tcp 0 0 ::%2:993 ::%3197282764:* LISTEN
11332/dovecot
tcp 0 0 ::%3:515 ::%3197282764:* LISTEN
13325/inetd
tcp 0 0 ::%4:995 ::%3197282764:* LISTEN
11332/dovecot
tcp 0 0 ::%5:548 ::%3197282764:* LISTEN
6450/afpd
wolfz
10. Dez 2011
tcp 0 0 ::%6:5000 ::%3197282764:* LISTEN
7350/httpd
tcp 0 0 ::%7:3240 ::%3197282764:* LISTEN
5781/usbipd
tcp 0 0 ::%8:139 ::%3197282764:* LISTEN
6429/smbd
tcp 0 0 ::%9:9900 ::%3197282764:* LISTEN
7350/httpd
tcp 0 0 ::%10:110 ::%3197282764:* LISTEN
11332/dovecot
tcp 0 0 ::%11:143 ::%3197282764:* LISTEN
11332/dovecot
tcp 0 0 ::%12:80 ::%3197282764:* LISTEN
12002/httpd
tcp 0 0 ::%13:31860 ::%3197282764:* LISTEN
6395/transmissiond
tcp 0 0 ::%14:23 ::%3197282764:* LISTEN
13325/inetd
tcp 0 0 ::%15:631 ::%3197282764:* LISTEN
4953/cupsd
tcp 0 0 ::%16:5432 ::%3197282764:* LISTEN
2751/postgres
tcp 0 0 ::%17:25 ::%3197282764:* LISTEN
11324/master
tcp 0 0 ::%18:445 ::%3197282764:* LISTEN
6429/smbd
udp 0 0 0.0.0.0:514 0.0.0.0:*
7688/syslog-ng
udp 0 0 192.168.1.82:137 0.0.0.0:*
6363/nmbd
udp 0 0 0.0.0.0:137 0.0.0.0:*
6363/nmbd
udp 0 0 192.168.1.82:138 0.0.0.0:*
6363/nmbd
udp 0 0 0.0.0.0:138 0.0.0.0:*
6363/nmbd
udp 0 0 0.0.0.0:9997 0.0.0.0:*
2048/findhostd
udp 0 0 0.0.0.0:9998 0.0.0.0:*
2048/findhostd
udp 0 0 0.0.0.0:9999 0.0.0.0:*
2048/findhostd
udp 0 0 0.0.0.0:19999 0.0.0.0:*
7020/vsctrld
udp 0 0 0.0.0.0:34602 0.0.0.0:*
5275/avahi-daemon:
udp 0 0 192.168.1.82:55900 0.0.0.0:*
7082/dms
udp 0 0 192.168.1.82:55901 0.0.0.0:*
7306/synoaudiod
udp 0 0 0.0.0.0:5353 0.0.0.0:*
5275/avahi-daemon:
udp 0 0 0.0.0.0:1900 0.0.0.0:*
7306/synoaudiod
7082/dms
wolfz
10. Dez 2011
udp 0 0 127.0.0.1:41711 0.0.0.0:*
7082/dms
udp 0 0 0.0.0.0:31860 0.0.0.0:*
6395/transmissiond
udp 0 0 127.0.0.1:49529 0.0.0.0:*
7306/synoaudiod
Active UNIX domain sockets (only servers)
Proto RefCnt Flags Type State I-Node PID/Program name Pat
h
unix 2 [ ACC ] STREAM LISTENING 130489 11332/dovecot /va
r/run/dovecot//login/default
unix 2 [ ACC ] STREAM LISTENING 130494 11332/dovecot /va
r/run/dovecot//auth-worker.11333
unix 2 [ ACC ] STREAM LISTENING 130319 11324/master pub
lic/cleanup
unix 2 [ ACC ] STREAM LISTENING 130350 11324/master pub
lic/flush
unix 2 [ ACC ] STREAM LISTENING 130370 11324/master pub
lic/showq
unix 2 [ ACC ] STREAM LISTENING 130326 11324/master pri
vate/tlsmgr
unix 2 [ ACC ] STREAM LISTENING 130330 11324/master pri
vate/rewrite
unix 2 [ ACC ] STREAM LISTENING 130334 11324/master pri
vate/bounce
unix 2 [ ACC ] STREAM LISTENING 130338 11324/master pri
vate/defer
unix 2 [ ACC ] STREAM LISTENING 130342 11324/master pri
vate/trace
unix 2 [ ACC ] STREAM LISTENING 8714 7322/synorcd /tm
p/synoctrl
unix 2 [ ACC ] STREAM LISTENING 130346 11324/master pri
vate/verify
unix 2 [ ACC ] STREAM LISTENING 9578 7688/syslog-ng /va
r/run/log
unix 2 [ ACC ] STREAM LISTENING 130354 11324/master pri
vate/proxymap
unix 2 [ ACC ] STREAM LISTENING 130358 11324/master pri
vate/proxywrite
unix 2 [ ACC ] STREAM LISTENING 130487 11332/dovecot /va
r/run/dovecot//dict-server
unix 2 [ ACC ] STREAM LISTENING 130362 11324/master pri
vate/smtp
unix 2 [ ACC ] STREAM LISTENING 130366 11324/master pri
vate/relay
unix 2 [ ACC ] STREAM LISTENING 130374 11324/master pri
vate/error
unix 2 [ ACC ] STREAM LISTENING 130378 11324/master pri
vate/retry
unix 2 [ ACC ] STREAM LISTENING 130382 11324/master pri
vate/discard
unix 2 [ ACC ] STREAM LISTENING 130386 11324/master pri
vate/local
unix 2 [ ACC ] STREAM LISTENING 130390 11324/master pri
vate/virtual
unix 2 [ ACC ] STREAM LISTENING 130394 11324/master pri
wolfz
10. Dez 2011
vate/lmtp
unix 2 [ ACC ] STREAM LISTENING 130398 11324/master pri
vate/anvil
unix 2 [ ACC ] STREAM LISTENING 130402 11324/master pri
vate/scache
unix 2 [ ACC ] STREAM LISTENING 130420 11324/master pri
vate/spamassassin
unix 2 [ ACC ] STREAM LISTENING 7454 7035/ssd /tm
p/sscmd2
unix 2 [ ACC ] STREAM LISTENING 9581 7688/syslog-ng /tm
p/syslog-ng.ctl
r/run/afpd_ipc
p/.s.PGSQL.5432
p/mplayer.sock
p/synoaudiod.sock
p/vsctrlsocket
p/fileindexd.sck
r/run/saslauthd/mux
Wolf> ps grep postfix
ps: invalid option -- g
BusyBox v1.16.1 (2011-11-26 14:58:46 CST) multi-call binary.
Usage: ps
Report process status
Options:
w Wide output
Wolf> help
Built-in commands:
. : [ [[ alias break cd chdir continue eval exec exit export
false getopts hash help let local printf pwd read readonly return
set shift source test times trap true type ulimit umask unalias
unset wait
Wolf> help/?
-ash: help/?: not found
Wolf> !?
-ash: !?: not found
Wolf> ?
-ash: ?: not found
Wolf> help ?
Built-in commands:
unset wait
Wolf> cat /proc/cpuinfo
Processor : Feroceon 88FR131 rev 1 (v5l)
BogoMIPS : 794.62
Features : swp half thumb fastmult edsp
CPU implementer : 0x56
CPU architecture: 5TE
CPU variant : 0x2
CPU part : 0x131
CPU revision : 1
Hardware : Feroceon-KW
Revision : 0000
Serial : 0000000000000000
Wolf> ps | grep postfix
11326 postfix 10520 S pickup -l -t fifo -u
11327 postfix 10580 S qmgr -l -t fifo -u
13687 root 3008 S grep postfix
Wolf> ps | grep dovecot
11332 root 8708 S /usr/syno/mailstation/sbin/dovecot
11333 root 12692 S dovecot-auth
11335 dovecot 8604 S pop3-login
11336 dovecot 8604 S pop3-login
11337 dovecot 8604 S pop3-login
11340 dovecot 8612 S imap-login
11477 dovecot 8612 S imap-login
12132 dovecot 8612 S imap-login
13701 root 3008 S grep dovecot
Wolf> netstat -lnp | grep 25
11324/master
tcp 0 0 ::%3:515 ::%3200547292:* LISTEN
13325/inetd
tcp 0 0 ::%14:23 ::%3200547292:* LISTEN
13325/inetd
tcp 0 0 ::%17:25 ::%3200547292:* LISTEN
11324/master
p/.s.PGSQL.5432
Wolf> netstat -lnp | grep 143
11332/dovecot
tcp 0 0 ::%11:143 ::%3202529756:* LISTEN
11332/dovecot
Wolf>
wolfz
10. Dez 2011
endlich geschaft aber dafür das forum zugemüllt mit text leider
Ap0phis
16. Dez 2010
Bitte benutze dringend die
-Funktion bei der Eingabe solcher Daten!
Ansonsten ist das wie man sieht kaum lesbar.
laserdesign
11. Jan 2011
@wolfz,
jetzt müllst du aber das Forum gewaltig voll, wer soll sich das noch anschauen und dir dann helfen??
wolfz
10. Dez 2011
ich wollte nur das machen wie jahlives gesagt hat sols hier anschliessend posten
ist mir schon klar das ich alles zumülle leider
wolfz
10. Dez 2011
nur die netstats
11324/master
tcp 0 0 ::%3:515 ::%3203451356:* LISTEN
13325/inetd
tcp 0 0 ::%14:23 ::%3203451356:* LISTEN
13325/inetd
tcp 0 0 ::%17:25 ::%3203451356:* LISTEN
11324/master
p/.s.PGSQL.5432
11332/dovecot
tcp 0 0 ::%11:143 ::%3203729884:* LISTEN
11332/dovecot
Ap0phis
16. Dez 2010
Liest du immer nur den letzten Beitrag? ;)
jahlives
19. Aug 2008
ich habe es jetzt nur überflogen (ist wirklich zuviel): postfix (SMTP-Server) scheint zu laufen und auch der dovecot hat seine Ports offen. Von dem her sollte es eigentlich laufen. Hast du denn eventuell die Firewall an der DS am laufen welche etwas verbieten würde?
wolfz
10. Dez 2011
habe firewall mit hacken und ohne prob wenn ich anschliessend auf webmail gehe kommt immer noch nach der anmeldunfg der error
bohne
05. Jan 2011
Das hilft jetzt zwar nicht zu Deinem Problem bei, aber zur Info:
Egal ob Du den Hacken setzt oder nicht, Deine Firewall lässt immer alles zu.
Das ausschlaggebende ist die Option ganz unten "Wenn keine Regel zutrifft".
wolfz
10. Dez 2011
was könnte noch falsch sein bei den einstellungen?!
jahlives
19. Aug 2008
Um den Fehler weiter einzugrenzen wären sinnvolle Logmeldungen ganz interessant. Leider werden beim Log von Synology die meisten Mailsachen ignoriert. Falls dir das Stichwort ipkg etwas sagt, dann guck mal in unser Wiki zum Thema syslog-ng. Das ist ein alternativer Logdienst, der wirklich jede Meldung des Mailservers aufzeichnet. Bevor du dich aber an den syslog-ng machst, wäre es eventuell eine Idee die Logs auf der DS trotzdem mal anzugucken. Dazu als root auf die Konsole verbinden und
tail -f /var/log/messages
machen. Dann das Webmail aufrufen und das Log im Auge behalten. Sind irgendwelche Meldungen dazugekommen?
jahlives
19. Aug 2008
dein User heisst also Wolf? Funzt denn auch wolf ned? Es gab da mal einen Bug in Roundcube, der es unmöglich machte sich als Wolf einzuloggen. Der Name wurde immer als wolf an den Server übermittelt und der kannte ihn dann natürlich ned
wolfz
10. Dez 2011
habs gerade prob aber es geht mit wolf auch nicht und mit root hatte ich es schon prob.
komischer weise geht es mit admin weiter aber kommt der fehler
jahlives
19. Aug 2008
was heisst geht weiter? Kommt dann die Meldung im syslog (messages) nicht?
Noch ein Tipp: Kennst du Putty? Ist ein client für ssh und telnet. Damit kann man sehr bequem den Output der Konsole als Text kopieren ohne einen Screenshot machen zu müssen ;-)
