Einfach ausstecken, programm starten, einstecken.
Start by turning off the router using the power button on the back of the device. Now, using the small object of your choice, press and hold the "Restore Factory Settings", also known as the Reset button located on the bottom of the router (there is a red ring around it). While holding the rest button, turn the router back on. Continue to hold the reset button for approximately 45 seconds then release it.
