DDNS Updater ddns updater for OVH provider
QTip
Super-Moderator
Teammitglied
04. Sep 2008
ok.
I have upgraded my DSM to version 4.0.2197.
I have seen in this version, under "Packages" that ddns was part of the "Other sources" packages. I guess it is because I have added "http://update.10trum.de/packageupdate/getpackages.php " as other potential sources ?
So I have installed your packages from there, meaning :
1. init-thirdparty version 1.5
2. ddns updater version 1.19
I have forgot to install the help package - not sure if it is of any use for me ? Is it mandatory ?
Yes, thats right, the help package patch ist only needed in DSM 3.xx
I have set the parameters as stated above for OVH, and this is working fine.
Do you know when OVH will be part of the "providers" in a next release ?
Many Thanks !
Fine, that the setting worked for you, i'll put OVH in the list of providers in the next release.
