DDNS Updater DDNS Updater UI not loading
neikt
23. Nov 2013
QTip, is there any way to change default port 5002?
I wonder if this would be the reason that causes the problem.
neikt
23. Nov 2013
Well...!!!!
Changing 5002 to 5003 and... dada!
Can you believe it?
Thank you so much for your hard word!!!!!!
QTip
Super-Moderator
Teammitglied
04. Sep 2008
the results are very incomprehensible
so look, if there is a file /usr/syno/apache/conf/httpd.conf-sys.bak
if so, execute the commands one by one and watch the output
grep "Listen 5002" /usr/syno/apache/conf/httpd.conf-sys
Output: nothing
cat /usr/syno/synoman/webman/3rdparty/Init_3rdparty/step1.conf
Output:
#step1
# Integration of Init_3rdparty
 Listen 5002
LoadModule php5_module /lib/libphp5.so
AddType application/x-httpd-php .php
RewriteEngine On
RewriteCond %{SERVER_PORT} =5002
RewriteRule ^/$ http://%{SERVER_NAME}:5000/webman/3rdparty/Init_3rdparty/index.php [R]
Include /usr/syno/synoman/webman/3rdparty/Init_3rdparty/php.conf
#step1
cat /usr/syno/synoman/webman/3rdparty/Init_3rdparty/step1.conf >>/usr/syno/apache/conf/httpd.conf-sys
Output: nothing
tail -n 20 /usr/syno/apache/conf/httpd.conf-sys
Output:
</IfModule>
<IfDefine FrameOptions>
Include conf/extra/httpd-frameOptions.conf-sys
</IfDefine>
#step1
 Listen 5002
RewriteEngine On
#step1
QTip
Super-Moderator
Teammitglied
04. Sep 2008
Well...!!!!
Can you believe it?
Forget my last post.
I can't belive it, why is your port 5002 assigned and through what?
I assume, that apache ignore the changes on restart, because 5002 are always assigned.
neikt
23. Nov 2013
I can't understand it either.
Is there something that I need to run now to revert any changes we did earlier by running the previous commands or there is no need to do anything?
QTip
Super-Moderator
Teammitglied
04. Sep 2008
only the two ipkg commands that you installed manually. You can remove they with
ipkg remove nmap netstat
but you can leave it as it is, don't worry about the two tools
neikt
23. Nov 2013
Thank you so much for everything!
