Du mußt Dich als root mit dem Passwort vom admin anmelden!
Aug 15 00:08:51 syslogd exiting
Aug 15 07:39:41 syslogd started: BusyBox v1.16.1
Aug 15 07:39:41 spacetool: spacetool.c:290 Failed to tune RAID stripe cache size[0x0600 raid_ioctl_info.c:49]
Aug 15 08:10:30 scemd: scemd.c:131 fan_type=3, raid_type=2, led_type=2, thermal_type=2, diskled_ctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_type=1, fan_number=1, ebox_type=1, pis_type=0, rtc_type=2
Aug 15 08:10:30 scemd: modules/fan_speed_adjust_common.c:118 Type: INTERNAL Fan Mode: LOW_STOP
Aug 15 08:10:30 scemd: modules/disk_check.c:187 Fail to get external sata devices
Aug 15 08:10:30 scemd: modules/disk_hibernation.c:1685 Force hibernation enable, idle minutes 10
Aug 15 08:10:30 synoprint: printer_enable_ext.c:488 delete printer failed: no bus id
Aug 15 08:10:32 synocheckshare: Fix shares in smb.conf.
Aug 15 08:10:35 synocheckshare: service_disable_set.c(68)Not defined date : id=4
Aug 15 08:10:38 scemd: disk/disk_config_all.c:63 apply /usr/syno/bin/syno_disk_ctl --wcache-off /dev/sda 1>/dev/null 2>&1
Aug 15 08:10:38 scemd: [/usr/syno/bin/syno_disk_ctl --wcache-off /dev/sda 1>/dev/null 2>&1], error (255)
Aug 15 08:10:39 kernel: [ 1894.490000] Got empty serial number. Generate serial number from product.
Aug 15 08:10:41 syno_hdd_util: Model:[WD10EARS-00Y5B1], Firmware:[80.00A80], S/N:[WD-WCAV5N195998] in [/dev/sda] is not ssd
Aug 15 08:10:42 synousbdisk: RCClean succeeded
Aug 15 08:10:42 synosata: synosata.c:150 failed to enum all external sata devices
Aug 15 08:10:43 heartbeatd: heartbeatd.c:170 Failed to get DDNS provider config: name = Synology
Aug 15 08:10:44 hotplugd: hotplugd.c:988 failed get usb status from usb config, DEVICE=/proc/bus/usb/001/001, usbid=1d6b:0002
rion-ehci.0
Aug 15 08:10:44 hotplugd: ##### ACTION:add
Aug 15 08:10:44 hotplugd: DEVICE:/proc/bus/usb/001/001
Aug 15 08:10:44 hotplugd: DEVPATH:usb1
Aug 15 08:10:44 hotplugd: SUBSYSTEM:usb
Aug 15 08:10:44 hotplugd: hotplugd.c:763 Fail to recognize usb DEVNAME=, DEVPATH=usb1
Aug 15 08:10:44 hotplugd: hotplugd.c:1289 failed to setup usb config, (DEVPATH, DEVICE, ACTION, DEVNAME, INTERFACE)=(usb1, /proc/bus/usb/001/001, add, , )
rion-ehci.0
Aug 15 08:10:44 hotplugd: DEVPATH:1-0:1.0
Aug 15 08:10:44 hotplugd: INTERFACE:9/0/0
Aug 15 08:10:44 hotplugd: DEVICE:/proc/bus/usb/001/002
Aug 15 08:10:44 hotplugd: DEVPATH:1-1
Aug 15 08:10:44 hotplugd: DEVPATH:1-1:1.0
Aug 15 08:10:44 hotplugd: hotplugd.c:790 ##### complete device hotplug!!
Aug 15 08:10:44 hotplugd: DEVICE:/proc/bus/usb/001/003
Aug 15 08:10:44 hotplugd: DEVPATH:1-1.1
Aug 15 08:10:44 hotplugd: DEVPATH:1-1.1:1.0
Aug 15 08:10:44 hotplugd: INTERFACE:8/6/80
Aug 15 08:10:44 ddnsd: ddnsd.c:2086 First update for DYNDNS.org
Aug 15 08:10:43 ntpdate: Sync with time server 78.46.85.230 offset -1.656687 sec.
Aug 15 08:10:43 kernel: [ 1900.370000] drivers/scsi/sd.c (2344) Got USB disk
Aug 15 08:10:43 kernel: [ 1900.440000] sd 2:0:0:0: [sdq] Test WP failed, assume Write Enabled
Aug 15 08:10:43 kernel: [ 1900.450000] sd 2:0:0:0: [sdq] Assuming drive cache: write through
Aug 15 08:10:43 kernel: [ 1900.480000] sd 2:0:0:0: [sdq] Test WP failed, assume Write Enabled
Aug 15 08:10:43 kernel: [ 1900.480000] sd 2:0:0:0: [sdq] Assuming drive cache: write through
Aug 15 08:10:49 kernel: [ 1906.190000] sd 2:0:0:0: [sdq] Test WP failed, assume Write Enabled
Aug 15 08:10:49 kernel: [ 1906.200000] sd 2:0:0:0: [sdq] Assuming drive cache: write through
Aug 15 08:10:51 hotplugd: ##### ACTION:add
Aug 15 08:10:51 hotplugd: DEVNAME:sdq
Aug 15 08:10:51 hotplugd: DEVICE:/proc/bus/usb/001/003
Aug 15 08:10:51 hotplugd: DEVGUID:57584D3141413050323338330
Aug 15 08:10:51 hotplugd: DEVPATH:sdq
Aug 15 08:10:51 hotplugd: SUBSYSTEM:block
Aug 15 08:10:51 hotplugd: PHYSDEVPATH:/devices/platform/orion-ehci.0/usb1/1-1/1-1.1/1-1.1:1.0/host2/target2:0:0/2:0:0:0
Aug 15 08:10:51 hotplugd: hotplugd.c:790 ##### complete device hotplug!!
Aug 15 08:10:51 hotplugd: hotplugd.c (1401) ==== USB disk [sdq] plugged in ====
Aug 15 08:10:51 hotplugd: hotplugd.c:1402 goto USB disk, szDeviceName=sdq
Aug 15 08:10:51 hotplugd: hotplugd.c:1404 ret=-1, fsType=0
Aug 15 08:10:51 scemd: modules/usbcopy.c:55 USBCopy - Unknown Signal: 12
Aug 15 08:11:01 syno_bkp_data_update: Fail to get share information (NetBackup)
Aug 15 08:11:01 syno_bkp_data_update: syno_bkp_data_update.c: main(231) - Fail to update netbakup data format.
Ich habe eingestellt, dass das NAS um 7 h starten soll, aber davon finde ich gar nichts im LOG. Das um 7:39 h war ich dann wohl, nachdem
ich den Netzstecker gezogen habe.
