Es scheint, dass tvstreamrecord wohl alles richtig macht, ich bekomme jedoch VLC nicht zum Laufen.
Weder am MAC noch auf mein Tablet.
Es kommt folgende Fehlermeldung bei VLC, wenn ich es am MAC versuche:
main debug: processing request item: 3sat, node: Wiedergabeliste, skip: 0
main debug: rebuilding array of current - root Wiedergabeliste
main debug: rebuild done - 2 items, index 1
main debug: starting playback of the new playlist item
main debug: resyncing on 3sat
main debug: 3sat is at 1
main debug: creating new input thread
main debug: Creating an input for '3sat'
main debug: using timeshift granularity of 50 MiB, in path '/tmp'
main debug: `
http://192.168.178.4:9981/stream/channelid/251?ticket=129C4F3F8C2BB240C2F7DEF400A17C8FAC700328' gives access `http' demux `' path `192.168.178.4:9981/stream/channelid/251?ticket=129C4F3F8C2BB240C2F7DEF400A17C8FAC700328'
main debug: creating demux: access='http' demux='' location='192.168.178.4:9981/stream/channelid/251?ticket=129C4F3F8C2BB240C2F7DEF400A17C8FAC700328' file='(null)'
main debug: looking for access_demux module: 0 candidates
main debug: no access_demux module matched "http"
main debug: TIMER module_need() : 0.125 ms - Total 0.125 ms / 1 intvls (Avg 0.125 ms)
main debug: creating access 'http' location='192.168.178.4:9981/stream/channelid/251?ticket=129C4F3F8C2BB240C2F7DEF400A17C8FAC700328', path='(null)'
main debug: looking for access module: 2 candidates
access_http debug: http: server='192.168.178.4' port=9981 file='/stream/channelid/251?ticket=129C4F3F8C2BB240C2F7DEF400A17C8FAC700328'
main debug: net: connecting to 192.168.178.4 port 9981
main debug: connection succeeded (socket = 29)
access_http error: failed to read answer
access_http debug: switching to HTTP version 1.0
access_mms error: failed to read answer
main debug: no access module matching "http" could be loaded
main debug: TIMER module_need() : 5.547 ms - Total 5.547 ms / 1 intvls (Avg 5.547 ms)
main error: open of `
http://192.168.178.4:9981/stream/channelid/251?ticket=129C4F3F8C2BB240C2F7DEF400A17C8FAC700328' failed
main debug: finished input
main debug: dead input
main debug: changing item without a request (current 1/2)
main debug: nothing to play
main debug: TIMER input launching for '3sat' : 46.220 ms - Total 46.220 ms / 1 intvls (Avg 46.220 ms)
main debug: no fetch required for (null) (art currently (null))
main debug: no fetch required for 3sat (art currently (null))
Vielleicht sieht jemand den Fehler, den ich mache?
Nochmals Danke für die viele Hilfe hier im Forum.
