@Puppetmaster: Hier die gewünschte Prozessliste:
Mem: 997204K used, 16332K free, 0K shrd, 159816K buff, 638748K cached
CPU: 2.6% usr 0.5% sys 0.0% nic 77.3% idle 19.3% io 0.0% irq 0.0% sirq
Load average: 8.10 7.47 7.31 2/227 24539
PID PPID USER STAT VSZ %MEM %CPU COMMAND
21306 9402 root S 12888 1.2 1.4 /usr/syno/apache/bin/httpd -DSSL -DFrameOptions -f /usr/syno/apache/conf/httpd.conf-sys
14714 9243 tmMBP S 20428 2.0 0.3 /usr/syno/sbin/afpd -g guest -c 256 -n DiskStation AFPServer -l default log_error
5096 1 root S 13844 1.3 0.1 scemd
14171 1 root S < 7988 0.7 0.1 /var/packages/AudioStation/target/sbin/synorcd
14136 1 root S < 64720 6.3 0.0 /var/packages/AudioStation/target/sbin/synoaudiod
18412 18411 root S 60784 5.9 0.0 /var/packages/SurveillanceStation/target/sbin/ssd -c 3
18386 1 root S 60784 5.9 0.0 /var/packages/SurveillanceStation/target/sbin/ssd -c 3
8621 8602 admin S 55448 5.4 0.0 /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --u
24133 9335 root S 17924 1.7 0.0 sshd: root@pts/1
8428 1 root S 12900 1.2 0.0 /usr/syno/sbin/snmpd -Ln -c /usr/syno/etc/snmpd.conf -p /var/run/snmpd.pid udp:161,udp6:161,tcp
9327 1 root S 12760 1.2 0.0 /usr/syno/sbin/synosnmpcd
1009 2 root SW 0 0.0 0.0 [kworker/u:2]
14344 14338 nobody S 95088 9.3 0.0 /usr/syno/apache/bin/httpd -DSSL -DHAVE_PHP
14342 14338 nobody S 95088 9.3 0.0 /usr/syno/apache/bin/httpd -DSSL -DHAVE_PHP
14343 14338 nobody S 95088 9.3 0.0 /usr/syno/apache/bin/httpd -DSSL -DHAVE_PHP
16258 14338 nobody S 95080 9.3 0.0 /usr/syno/apache/bin/httpd -DSSL -DHAVE_PHP
14338 1 root S 94892 9.3 0.0 /usr/syno/apache/bin/httpd -DSSL -DHAVE_PHP
14142 1 root S < 78504 7.7 0.0 /var/packages/AudioStation/target/bin/pulseaudio
10240 10237 root S 70444 6.9 0.0 /var/packages/MediaServer/target/sbin/dms
10241 10237 root S 70444 6.9 0.0 /var/packages/MediaServer/target/sbin/dms
10239 10237 root S 70444 6.9 0.0 /var/packages/MediaServer/target/sbin/dms
10242 10237 root S 70444 6.9 0.0 /var/packages/MediaServer/target/sbin/dms
10233 1 root S 70444 6.9 0.0 /var/packages/MediaServer/target/sbin/dms
10237 10233 root S 70444 6.9 0.0 /var/packages/MediaServer/target/sbin/dms
10243 10237 root S 70444 6.9 0.0 /var/packages/MediaServer/target/sbin/dms
10244 10237 root S 70444 6.9 0.0 /var/packages/MediaServer/target/sbin/dms
14147 14143 root S 64720 6.3 0.0 /var/packages/AudioStation/target/sbin/synoaudiod
14146 14143 root S 64720 6.3 0.0 /var/packages/AudioStation/target/sbin/synoaudiod
14148 14143 root S 64720 6.3 0.0 /var/packages/AudioStation/target/sbin/synoaudiod
14143 14136 root S 64720 6.3 0.0 /var/packages/AudioStation/target/sbin/synoaudiod
14145 14143 root S 64720 6.3 0.0 /var/packages/AudioStation/target/sbin/synoaudiod
14149 14143 root S 64720 6.3 0.0 /var/packages/AudioStation/target/sbin/synoaudiod
14144 14143 root S 64720 6.3 0.0 /var/packages/AudioStation/target/sbin/synoaudiod
10999 10996 root S 62824 6.1 0.0 /var/packages/VideoStation/target/sbin/synovpcd
11000 10996 root S 62824 6.1 0.0 /var/packages/VideoStation/target/sbin/synovpcd
11001 10996 root S 62824 6.1 0.0 /var/packages/VideoStation/target/sbin/synovpcd
10996 10993 root S 62824 6.1 0.0 /var/packages/VideoStation/target/sbin/synovpcd
10998 10996 root S 62824 6.1 0.0 /var/packages/VideoStation/target/sbin/synovpcd
11002 10996 root S 62824 6.1 0.0 /var/packages/VideoStation/target/sbin/synovpcd
10993 1 root S 62824 6.1 0.0 /var/packages/VideoStation/target/sbin/synovpcd
10997 10996 root S 62824 6.1 0.0 /var/packages/VideoStation/target/sbin/synovpcd
18415 18411 root S 60784 5.9 0.0 /var/packages/SurveillanceStation/target/sbin/ssd -c 3
18411 18386 root S 60784 5.9 0.0 /var/packages/SurveillanceStation/target/sbin/ssd -c 3
13849 13847 root S 59932 5.9 0.0 /var/packages/SurveillanceStation/target/sbin/vsctrld
13848 13847 root S 59932 5.9 0.0 /var/packages/SurveillanceStation/target/sbin/vsctrld
13840 1 root S 59932 5.9 0.0 /var/packages/SurveillanceStation/target/sbin/vsctrld
13847 13840 root S 59932 5.9 0.0 /var/packages/SurveillanceStation/target/sbin/vsctrld
13821 1 root S 57988 5.7 0.0 /var/packages/SurveillanceStation/target/sbin/sscored
8620 8602 admin S 55448 5.4 0.0 /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --u
8602 8601 admin S 55448 5.4 0.0 /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --u
8601 8534 admin S 55448 5.4 0.0 /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --u
8622 8602 admin S 55448 5.4 0.0 /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --u
8603 8602 admin S 55448 5.4 0.0 /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --u
8604 8602 admin S 55448 5.4 0.0 /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --u
8605 8602 admin S 55448 5.4 0.0 /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --u
8606 8602 admin S 55448 5.4 0.0 /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --u
8623 8602 admin S 55448 5.4 0.0 /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --u
8624 8602 admin S 55448 5.4 0.0 /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --u
13307 8506 admin S 34324 3.3 0.0 postgres: admin download [local] idle
8715 8506 admin S 34032 3.3 0.0 postgres: admin synolog [local] idle
