DSM 6.0 Beta Video Station
TimEv
26. Okt 2015
Im Prinzip hast du ja recht. Aber bei Fehlern in der Beta soll man sich ja melden.
Wenn dann so eine Antwort kommt:
Hi Tim,
For DS video, there are two ways to stream videos to DLNA/Chromecast/AppleTV
1. go to the video and then select the player (DLNA/Chromecast/AppleTV)
2. select the player and then select the video
It seems you are using 2. please press the green 'play' button.
Hope this helps.
Yours Sincerely,
Harper Shen
Technical support
Synology
Ist man doch schon sauer.
Eine Stunde später dann das Update
Hi Tim,
Sorry for the miscommunications.
We have identified the issue and it is noted down.
We will try to find the root cause of the problem and fix it in a future release.
Thank you for reporting and all of your time and effort, we are deeply sorry for any inconvenience caused.
Yours Sincerely,
Harper Shen
Technical support
Synology
Also guter Support.
Warten wir also ab:)
