DSM 7.2 DSM 7.2-64570
Adama
05. Mrz 2013
Es gibt ein fettes Update für 7.2. Jedenfalls ist die Liste der Änderungen recht lang:
Version: 7.2-64570
(2023-06-08)
Important Note
    After installing this update, you will not be able to downgrade to a previous DSM version.
    This update will restart your Synology NAS.
    Starting from this version, logs for drives will no longer appear in Storage Manager > HDD and will be available only in Log Center.
    Removed the "Automatically create port forwarding rules" option from QuickConnect advanced settings to increase network security.
    Users can now create a Btrfs volume of up to 1 PB on specific Synology NAS models. This update automatically converts existing volumes that use the Btrfs (Peta Volume) file system to Btrfs. However, to create a volume larger than 200 TB, a RAID 6 storage pool and at least 64 GB of system memory are still required.Learn more
    The maximum single volume size supported by RS2423+/RS2423RP+ has been adjusted to 200 TB (with a minimum system memory requirement of 32 GB).
    Starting from this version, only Windows Server 2008 R2 and above versions will be supported. After installing this update, the current Windows Server 2008 domain and earlier versions will be unavailable.
    This update fixed the following issues with version 7.2-64561:
        Fixed an issue where updating to DSM 7.2 might fail if users' Synology NAS weren't connected to the Internet.
        Fixed an issue where, when the Encryption Key Vault of encrypted volumes was set on a KMIP server, the system would not be able to auto-unlock these volumes after a restart.
        Fixed an issue where, if Web Station was installed on an encrypted volume, resetting the system would cause the volume to crash.
        Updated C2 Identity Edge Server to version 1.52.0-0186 to ensure its availability and functionality.
    For the models below, you can only download the upgrade patch from Synology Download Center because you won't receive notifications for this update on your DSM.
        FS Series: FS3017, FS2017, FS1018
        XS Series: RS18016xs+, RS4017xs+, RS3617xs+, RS3617xs, RS3617RPxs, RS18017xs+, DS3617xs, DS3617xsII, DS3018xs
        Plus Series: RS2416RP+, RS2416+, DS916+, DS716+II, DS716+, DS216+II, DS216+, DS1817+, DS1517+, RS2818RP+, RS2418RP+, RS2418+, RS818RP+, RS818+, DS1618+, DS918+, DS718+, DS218+, RS1219+
        Value Series: DS416, DS416play, DS216, DS216play, DS116, RS816, DS1817, DS1517, RS217, DS418play
        J Series: DS416slim, DS416j, DS216j, DS418j, DS218j, DS419slim, DS119j
What’s New
    Added support for WriteOnce shared folders. This feature is based on the Write Once, Read Many (WORM) technology and can be enabled to prevent files from being modified, deleted, or renamed for a specified period.
    Added support for volume encryption. All volume encryption keys are stored in the Encryption Key Vault, which can be set up on a local Synology NAS or via KMIP on a remote Synology NAS.
    Added more Synology NAS models to support M.2 NVMe SSD storage pools. Learn more
    Added more Synology NAS models to support the M2D18 adapter card: RS822RP+, RS822+, RS1221RP+, and RS1221+.
    Added more SSD cache group management options, including changing the RAID type and replacing a drive.
    Added support for inline zero-block removal to increase the efficiency of data deduplication.
    Adjusted how drive information is presented in Storage Manager. Users can now quickly check the condition of their drives by looking at the "Drive Status" field.
    Users can now view the amount of used and free space for each storage pool and volume in Storage Manager.
    Added a warning notification for when the available shared folder quota is low.
    Supports deleting individual desktop notifications.
    Supports sending DSM notifications via additional webhook providers, including LINE and Microsoft Teams.
    Supports creating custom notification rules for system events, giving users greater control over what notifications to receive.
    Supports exporting a list of users and of groups.
    Added support for SAML to integrate DSM with external SSO servers.
    Added the option to allow non-admin users to safely eject USB devices.
    Users can now manually input the IP addresses or FQDNs of one or more domain controllers in the trusted domain. This allows Synology NAS to sync domain data directly with the specified domain controllers.
    Users can now enable Synology's email server to send DSM notifications directly to their Synology Account.
    Added support for Auto Block, which restricts SMB login attempts from abnormal IP addresses.
Fixed Issues
    Fixed an issue where adding drives to a JBOD storage pool did not expand its capacity.
    Updated Mbed-TLS to version 2.28.2 to fix multiple security vulnerabilities (CVE-2021-36647, CVE-2022-46392, CVE-2022-46393).
    Updated Libksba to version 1.6.3 to fix a security vulnerability (CVE-2022-3515).
    Updated SQLite to version 3.40.0 to fix a security vulnerability (CVE-2022-46908).
    Updated Certifi to version 2022.12.07 to fix a security vulnerability (CVE-2022-23491).
    Updated Node.js to version 14.21.1 to fix a security vulnerability (CVE-2022-43548).
    Updated cURL to version 7.86.0 to fix multiple security vulnerabilities (CVE-2022-27774, CVE-2022-27775, CVE-2022-27776, CVE-2022-27781, CVE-2022-27782, CVE-2022-32205, CVE-2022-32206, CVE-2022-32207, CV E-2022-32221, CVE-2022-35252, CVE-2022-42915, CVE-2022-42916).
    Updated PHP to version 8.1.9 to fix multiple security vulnerabilities (CVE-2019-11043, CVE-2021-21705, CVE-2022-31625).
    Updated Sysstat to version 12.7.1 to fix a security vulnerability (CVE-2022-39377).
    Updated OpenSSL to version 3.0.7 to fix multiple security vulnerabilities (CVE-2022-2068, CVE-2022-2097, CVE-2022-2274, CVE-2022-3358, CVE-2022-3602, CVE-2022-3786).
    Updated Expat to version 2.5.0 to fix a security vulnerability (CVE-2022-43680).
    Updated Libtirpc to version 2.87 to fix a security vulnerability (CVE-2021-46828).
    Updated GnuPG to version 2.2.39 to fix a security vulnerability (CVE-2022-34903).
    Updated OpenVPN to version 2.5.8 to fix a security vulnerability (CVE-2022-0547).
    Updated libxml2 to version 2.9.14 to fix a security vulnerability (CVE-2022-23308).
    Updated GMP to version 6.2.1 to fix a security vulnerability (CVE-2021-43618).
    Updated ImageMagick to version 6.9.12-61 to fix multiple security vulnerabilities (CVE-2020-25664, CVE-2020-25665, CVE-2020-25666, CVE-2020-25667, CVE-2020-25674, CVE-2020-25675, CVE-2020-25676, CVE-2020-27560, CVE-2020-27750, CVE-2020-27751, CVE-2020-27752, CVE-2020-27753, CVE-2020-27754, CVE-2020-27755, CVE-2020-27756, CVE-2020-27757, CVE-2020-27758, CVE-2020-27759, CVE-2020-27760, CVE-2020-27761, CVE-2020-27762, CVE-2020-27763, CVE-2020-27764, CVE-2020-27765, CVE-2020-27766, CVE-2020-27767, CVE-2020-27768, CVE-2020-27769, CVE-2020-27770, CVE-2020-27771, CVE-2020-27772, CVE-2020-27773, CVE-2020-27774, CVE-2020-27775, CVE-2020-27776, CVE-2020-29599, CVE-2021-20176, CVE-2021-20224, CVE-2021-20241, CVE-2021-20245, CVE-2021-20246, CVE-2021-20309, CVE-2021-3574, CVE-2021-3596, CVE-2021-39212, CVE-2021-4219, CVE-2022-1114, CVE-2022-1115, CVE-2022-28463, CVE-2022-32545, CVE-2022-32546, CVE-2022-32547).
    Updated FFmpeg to version 4.1.9 to fix multiple security vulnerabilities (CVE-2020-20892, CVE-2020-20902, CVE-2020-21688, CVE-2020-21697, CVE-2021-3566, CVE-2021-38114, CVE-2021-38291).
    Fixed a security vulnerability regarding Netatalk (CVE-2022-45188).
    Fixed multiple security vulnerabilities regarding Python3 (CVE-2020-10735, CVE-2021-28861, CVE-2022-45061).
    Fixed multiple security vulnerabilities regarding iproute2 (CVE-2022-3527, CVE-2022-3529, CVE-2022-3530).
    Fixed multiple security vulnerabilities regarding D-Bus (CVE-2022-42010, CVE-2022-42011, CVE-2022-42012).
    Fixed a security vulnerability regarding syslog-ng (CVE-2022-38725).
    Fixed a security vulnerability regarding inetutils (CVE-2022-39028).
    Fixed a security vulnerability regarding DNSmasq (CVE-2022-0934).
    Fixed a security vulnerability regarding BusyBox-udhcp (CVE-2019-5747).
    Fixed multiple security vulnerabilities regarding Linux Kernel (CVE-2021-22600, CVE-2021-38209, CVE-2021-4037, CVE-2022-0168, CVE-2022-1016, CVE-2022-1729, CVE-2022-1786, CVE-2022-20141, CVE-2022-20368, CVE-2022-2078, CVE-2022-2639, CVE-2022-2905, CVE-2022-29581, CVE-2022-32250, CVE-2022-3524, CVE-2022-3566, CVE-2022-3567, CVE-2022-36879, CVE-2022-36946, CVE-2022-42703).
    Fixed a security vulnerability regarding Nginx (CVE-2022-3638).
    Fixed a security vulnerability regarding ghostscript (CVE-2023-28879).
    Fixed a security vulnerability regarding curl (CVE-2023-23916).
Limitation
    S.M.A.R.T. testing for M.2 NVMe SSDs is no longer supported.
    Starting from DSM 7.2 Beta, Virtual Machine Manager will no longer support creating clusters with older DSM versions. Please update each host in the cluster to the same DSM version or above versions for the Virtual Machine Manager cluster to operate properly.
https://www.synology.com/de-de/releaseNote/DSM?model=DS918+#7_2
Kurt-oe1kyw
10. Mai 2015
DANKE für die Info @Adama, ich probier es mal auf der Test-DS aus.
Ich war beim ersten lesen der Überschrift leicht irretiert, ich hatte erwartet DSM 7.2-64561 Update1 aber nein, sie nennen das neue Update jetzt DSM 7.2-64570, soll mir auch Recht sein.
Ich berichte dann.
Edit:
ah ok, jetzt verstehe ich es! Die haben das vorige DSM 7.2-64561 vom Synology Server heruntergenommen und jetzt ist nur das neue DSM 7.2-64570 vorhanden! Und es ist für mehr Synology Modelle verfügbar als in den releasenotes angegeben wurde.
Aber am Besten selber nachsehen, ob es für euer Modell schon verfügbar ist:
https://archive.synology.com/download/Os/DSM/7.2-64570
Reaktionen: Adama und maxblank
maxblank
25. Nov 2022
Dann bin ich gespannt, was du zu berichten hast. 👍🏻
Ulfhednir
26. Aug 2013
Nachdem ich abermals Probleme mit dem Speicherplatz meiner Partition hatte, einige Logs (SMB+Protokollcenter) gelöscht und die DS neu gestartet habe, konnte ich das Update jetzt auch installieren. Das Ergebnis von df -h hat sich nicht wirklich verändert. :rolleyes:
Kurt-oe1kyw
10. Mai 2015
So war etwas "holprig" aber der Reihe nach und vorweg, es geht jetzt.
Also Update DSM 7.2-64570 manuell eingespielt (anders geht noch nicht, wird erst in ein paar Tagen/Wochen autom funktionieren)
Dauer ca. 10 Minuten, DS118 fährt hoch und meldet sich mit Peeeeeep Warnton und Status - LED blinkt gelb.
Keine Panik, kenn ich schon mein Verdacht Noctua Lüfter zickt öfter nach einem Update herum, bedeutet nach dem Update läuft der nicht mehr, WEIL das Update die Lüfterstufe runtersetzt von "Modus volle Geschwindigkeit" auf "Kühlmodus" und das mag der Noctua in der Synology nicht.
Also Kontrolle Hand hinten drauf, Verdacht bestätigt, kein Luftstrom spürbar.
Anmerkung an der Stelle für Leute die SecureSignIn verwenden, durch das Update wird SecureSignIn aktualisiert, dh. ihr könnt euch in dieser Zeit NICHT via SecureSignIn einloggen.
Entweder paar Minuten warten oder auf "Andere Anmeldemethode" zB mit Kennwort umschalten (Link im Anmeldefenster draufklicken).
Kennwort eingetippt, eingeloggt, Lüftermodus umgestellt auf Modus Volle Geschwindigkeit, DS am SCHALTER (!) heruntergefahren.
DS118 neu hochgefahren.
Hinweis:
Nicht erschrecken, unmittelbar nach dem Einschalten läuft der Noctua und geht dann wieder kurz aus! ABER nachdem das Hochfahren beendet ist, also DSM "geladen" wurde, übernimmt die zuvor korrekt eingestellte Lüftersteuerung und der Noctua läuft wieder auf voller Geschwindigkeiten.
Leute mit Originallüfter ( n ) sind davon nicht betroffen.
Mehrere Pakete werden während des DSM Updates automatisch aktualisiert. Nach dem Einloggen wurde bei mir noch Synology Photos aktualisiert da es bei manchen mit Hyperbackup Probleme gegeben haben dürfte mit SP. Kann ich persönlich nicht bestätigen hat bei mir immer funktioniert.
Ansonsten, ja schaut gut aus.
Also Aufpassen:
Zeit lassen und auch nach dem Hochfahren der Synology mehrere Minuten noch warten bis Secure Sign In fertig ist mit seinem Paketupdate!
Danach könnt ihr auch wie gewohnt via SecureSignIn einloggen.
Jene mit "Fremdlüftern" kontrolliert ob die Lüfter laufen, falls nicht, entweder einloggen und Modus hochstellen oder Synology nach paar Minuten noch mal per Einschalter herunterfahren und wieder neu starten und dann ebenfalls im Lüftermenü nachsehen bezüglich Lüftermodus auf "Modus volle Geschwindigkeit".
Thonav
16. Feb 2014
Auf verschiedenen DS (923+, 1621+, 220j) installiert - teilweise auch mit Fremd-NVMe - alles Problemlos.
Auch von mir eine kurze Rückmeldung:
Manuelles Update von DSM 7.2-64561 auf DSM 7.2-64570 völlig problemlos. ~10 Pakete wurden automatisch aktualisiert, für Synology Photos wurde auch ein Update angeboten, aber nicht automatisch installiert.
Wie fast bei fast jedem größeren Update war hinterher /root (Homeverzeichnis von root) fast leer. Man sollte also dort nichts wichtiges ablegen (Links, Scripts etc) . Ich hatte das schonmal bei Synology bemängelt, jetzt liegt eine Textdatei dort mit Namen "FOR SYSTEM USE ONLY. DO NOT UPLOAD FILES HERE.". Ist nicht schlimm, sollte man nur wissen.
Kurt-oe1kyw
10. Mai 2015
RS1221+ und Backup-DS218+ ebenfalls ohne Probleme beim Update. Viele Pakete autom durch das DSM Update aktualisiert und wie bei Benares ein roter Punkt als Hinweis im Paketzentrum für neues Paket von Synology Photos > Aktualisieren angeklickt, SP aktualisiert - alles läuft bisher.
Interessanterweise hatte die DS218+ mit ihren beiden Noctualüftern kein Problem beim Update, die RS1221+ ist mit Originallüftern bestückt.
Tipp:
Je nach leistungsfähigkeit von eurere Synology also CPU und RAM wartet nach dem Hochfahren eurer DS 10-15 Minuten da ev die Paketupdates noch nicht fertig sind bis ihr euch einloggt. Dann geht es auch mit SecureSignIn gleich wieder wenn man der Synology "Zeit gibt" alles korrekt zu Ende zu bringen.
RS1221+ und DS218+ habe ich jeweils nach dem Fertigen Hochfahren noch weitere 10 Minuten bis zum Einloggen gewartet, danach ging es sofort mit SecureSignIn problemlos.
geimist
04. Jan 2012
Ich sehe da das Changelog der ursprünglichen Veröffentlichung.
Aber offensichtlich gab es noch Finetuning, wie man an den Paketupdates erkennen kann.
Darunter gibt es noch folgenden Vermerk:
Version: 7.2-64561​
(2023-05-22)
Important Note​
  1. This update has been recalled on June 8, 2023, because of an issue where updating to DSM 7.2 might fail if users' Synology NAS were not connected to the Internet. The issue is fixed in version 7.2-64570.
Adama
05. Mrz 2013
Du hast recht...
Heute morgen sah das noch anders aus, da stand darunter tatsächlich noch die komplette Historie der ersten releasten Version. Und ich hab mir ehrlich gesagt nicht die Mühe gemacht, die zu vergleichen...
Was für ein paar Nasen...
Reaktionen: maxblank
Tommes
26. Okt 2009
Somit hat sich mein chronisch überfülltes /dev/md0 Problem von ganz alleine gelöst. Prima :giggle:
Update installiert, NVME-SSD Volume musste online zusammengestellt werden, ansonsten alles ok.
DS-Thorsten
01. Mrz 2020
Meine DS716+II und DS1621+ mit dem 7.2-64570 versorgt.
Download über: https://archive.synology.com/download/Os/DSM/7.2-64570
Über https://www.synology.com/de-de/support/download und Auswahl des NAS und aktuelle Version geht (noch) nicht. Da 7.2-xxxxx noch nicht als aktuelle Version aus wählbar ist.
Secure Sign In hat sofort funktioniert. ...die DS1621+ ist auch relativ schnell. (laut Log war Secure Sign In nach 1:15 nach dem Start schon wieder verfügbar)
Probleme/ Auffälligkeiten: keine :)
@ctrlaltdelete
Ich frag mich, wieso das bei dir immer passiert und bei mir (DS1522+) nicht.
Vermutlich, weil bei mir in der /etc.defaults/synoinfo.conf der Eintrag support_m2_pool="yes" inzwischen dauerhaft drin ist und bei dir erst per Scriptvon 007revad (evtl. zu spät?) reinkommt?
Reaktionen: cinara
Ich glaube die DS mag meine Kingston Module nicht.
DS-Thorsten
01. Mrz 2020
Doch geht. Hast du evtl. nur vergessen oben bei "BS-Version" auf 7.2 umzuschalten? Der Default scheint immer noch 7.1 zu sein.
auch bei BS-Version 7.2. bietet er mir keine 7.2-xxxxx Versionen an als "aktuelle Version" von der ich auf 7.2-64570 aktualisieren kann.
Das neueste als "aktuelle Version" wird mir nur 7.1.1-42962 angezeigt. Egal ob ich BS-Version 7.2 oder BS-Version 7.1 wähle.
Links stellst du auch ein, was du aktuell hast und rechts, wo du hinwillst. Dann zeigt er die evtl. notwendigen Zwischenschritte an.
Und über den blauen Button "Download" bekommst du die Version auch, wenn du "BS-Version" umgestellt hast.
Bsp:
DS-Thorsten
01. Mrz 2020
Und über den blauen Button "Download" bekommst du die Version auch, wenn du BS-Version" umgestellt hast.
Bsp:
ja, verstanden.
Aber ich kann links nichts was mit 7.2-xxxx auswählen (was ich aktuell habe).
Rechts kommt: 7.2-64570. Und auch der Download passt. Somit "alles kein Problem". Es geht nichts schief und man kommt ans Ziel.
Nur eben Links kann ich nicht das auswählen was ich schon hab, wenn ich schon auf 7.2-xxxx bin.
Die 7.2-64561 gibt es ja nicht mehr, die wurde durch die 7.2-64570 ersetzt. Daher ist sie links wohl nicht wählbar. Aber egal, du kannst links auch einfach was uraltes einstellen, entscheiden sind die Links unten oder was der Download-Button liefert.
Reaktionen: DS-Thorsten
