Externe Festplatte an eSATA der DS-107e wird nicht erkannt!
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
Im Kernel log, kann nur Synology auslesen.
das File debug.dat ist einfach nur ein gepacktes tar File.
Inhalt:
usr/
usr/syno/
usr/syno/etc/
usr/syno/etc/webman.cfg
usr/syno/etc/ups/
usr/syno/etc/ups/upsd.users
usr/syno/etc/ups/upsmon.conf
usr/syno/etc/ups/upssched.conf
usr/syno/etc/ups/ups.conf
usr/syno/etc/ups/upsd.conf
usr/syno/etc/synosms.conf
usr/syno/etc/surveillance.pgsql
usr/syno/etc/ssl/
usr/syno/etc/ssl/ssl.key/
usr/syno/etc/ssl/ssl.key/server.key
usr/syno/etc/ssl/ssl.key/ca.key
usr/syno/etc/ssl/ssl.csr/
usr/syno/etc/ssl/ssl.csr/ca.csr
usr/syno/etc/ssl/ssl.csr/server.csr
usr/syno/etc/ssl/bak/
usr/syno/etc/ssl/bak/ssl.key/
usr/syno/etc/ssl/bak/ssl.key/server.key
usr/syno/etc/ssl/bak/ssl.key/ca.key
usr/syno/etc/ssl/bak/ssl.csr/
usr/syno/etc/ssl/bak/ssl.csr/ca.csr
usr/syno/etc/ssl/bak/ssl.csr/server.csr
usr/syno/etc/ssl/bak/ssl.crt/
usr/syno/etc/ssl/bak/ssl.crt/server.crt
usr/syno/etc/ssl/bak/ssl.crt/ca.crt
usr/syno/etc/ssl/mkcert.sh
usr/syno/etc/ssl/ssl.crt/
usr/syno/etc/ssl/ssl.crt/server.crt
usr/syno/etc/ssl/ssl.crt/ca.crt
usr/syno/etc/snmpd.conf
usr/syno/etc/smb.conf
usr/syno/etc/samba/
usr/syno/etc/rc.ssl_keygen
usr/syno/etc/rc.ssh
usr/syno/etc/rc.ftpd
usr/syno/etc/rc.d
usr/syno/etc/rc.atalk
usr/syno/etc/private/
usr/syno/etc/private/smbpasswd
usr/syno/etc/private/secrets.tdb
usr/syno/etc/private/secrets.tdb.bkp
usr/syno/etc/printcap
usr/syno/etc/php.ini
usr/syno/etc/papd.conf
usr/syno/etc/mimetypes.txt
usr/syno/etc/mediaserver.pgsql
usr/syno/etc/manutil.conf
usr/syno/etc/lpd/
usr/syno/etc/lpd/lpd.perms
usr/syno/etc/lpd/lpd.conf
usr/syno/etc/httpd-vhost.conf-user
usr/syno/etc/httpd-ssl-vhost.conf-user
usr/syno/etc/httpd-ssl-filestation.conf-sys
usr/syno/etc/httpd-filestation.conf-sys
usr/syno/etc/camera_support.conf
usr/syno/etc/camera_model.conf
usr/syno/etc/audio.users
usr/syno/etc/audio/
usr/syno/etc/audio/builtin_radio_station.asx
usr/syno/etc/audio/audio.conf
usr/syno/etc/atalkd.conf
usr/syno/etc/afpd.conf
usr/syno/etc/AppleVolumes.system
sys/
sys/class/
sys/class/scsi_host/
sys/class/scsi_host/host*/
proc/
proc/cmdline
proc/uptime
proc/interrupts
proc/cpuinfo
proc/swaps
proc/meminfo
proc/mounts
proc/net/
proc/net/route
proc/net/dev
proc/mtd
proc/partitions
proc/scsi/
proc/scsi/scsi
proc/usb/
etc/
etc/yp.conf.sv
etc/yp.conf
etc/upgrade.sh
etc/termcap
etc/syslog.deny
etc/sysctl.conf
etc/sysconfig/
etc/sysconfig/clock
etc/sysconfig/network
etc/sysconfig/networking/
etc/sysconfig/networking/profiles/
etc/sysconfig/networking/profiles/default/
etc/sysconfig/networking/ifcfg-lo
etc/sysconfig/networking/devices/
etc/sysconfig/network-scripts/
etc/sysconfig/network-scripts/ifdown
etc/sysconfig/network-scripts/ifup
etc/sysconfig/network-scripts/network-functions
etc/sysconfig/network-scripts/ifcfg-eth0
etc/sysconfig/network-scripts/ifcfg-lo
etc/sysconfig/console/
etc/synouser.conf
etc/synonetbkp.conf
etc/synolog.conf
etc/synoinfo.conf
etc/synogrinst.sh
etc/ssh/
etc/ssh/ssh_host_dsa_key.pub
etc/ssh/ssh_host_rsa_key.pub
etc/ssh/ssh_host_key
etc/ssh/ssh_host_key.pub
etc/ssh/moduli
etc/ssh/sshd_config
etc/shells
etc/shadow-
etc/shadow
etc/services
etc/security/
etc/security/pam_winbind.conf
etc/securetty
etc/rsyncd.secrets
etc/rsyncd.conf
etc/resolv.conf.sv
etc/resolv.conf
etc/rc.subr
etc/rc.network
etc/rc.local
etc/rc
etc/protocols
etc/profile
etc/ppp/
etc/ppp/options
etc/ppp/pap-secrets
etc/ppp/chap-secrets
etc/ppp/pppoe.conf
etc/passwd
etc/pam.d/
etc/pam.d/ftpd
etc/pam.d/findhostd
etc/pam.d/netatalk
etc/pam.d/other
etc/pam.d/webui
etc/pam.d/dovecot
etc/ntp.conf.sv
etc/ntp.conf
etc/nsswitch.conf.workgroup
etc/nsswitch.conf.domain
etc/nsswitch.conf
etc/newdisk.sh
etc/networks
etc/mtab
etc/mt-daapd.playlist
etc/mt-daapd.conf
etc/mke2fs.conf
etc/localtime
etc/ld.so.conf
etc/ld.so.cache
etc/installer.sh
etc/inetd.conf
etc/hosts.deny
etc/hosts.allow
etc/hosts
etc/host.conf
etc/group_desc
etc/group.cps
etc/group
etc/ftpusers
etc/fstab
etc/firewall/
etc/firewall/eth0.conf
etc/firewall/pppoe.conf
etc/exports_map
etc/exports
etc/dhcpc/
etc/dhcpc/dhcpcd-eth0.pid
etc/dhcpc/dhcpcd-eth0.cache
etc/dhcpc/dhcpcd-eth0.info.old
etc/defaults/
etc/defaults/rc.conf
etc/ddns_provider.conf
etc/ddns.conf
etc/crontab
etc/VERSION
etc/TZ
usr/syno/etc/dms/menu_custom3.xml
usr/syno/etc/dms/menu_custom2.xml
usr/syno/etc/dms/menu_custom1.xml
usr/syno/etc/amule/amule.conf
etc.defaults/VERSION
var/run/dmesg.boot
var/log/synoupdate.log
var/log/top.result
var/log/smart_sda.result
var/log/ps.result
var/log/ifconfig.result
var/log/free.result
var/log/dmesg.result
var/log/df.result
var/log/messages.0.gz
var/log/messages
@linuxdep
Hast Du über die Konsole in /var/log/messages reingeschaut?
itari
15. Mai 2008
Neben den Logfiles in /var/log, die man normalerweise dort immer findet, gibt es noch den Boot-Messages-Auszug dmesg.
Vermutlich werden vor dem Erstellen der Datei debug.dat noch ein paar Tools zum Generieren von Informationen angestoßen, die dann wohl nach der Produktion der Datei wieder gelöscht werden (z. B. /var/log/df.result).
Itari
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
ja die sind dann wieder weg.
linuxdep
02. Jan 2009
joh, habe in messages geschaut, aber nix zu sehen, rein garnix.
die letzte aktion ist das entfernen vom usb laufwerk...
spricht eigentlich für ein kontaktproblem... aber der Stecker geht ja rein, stößt auch nicht an wie in der Beschreibung steht, was aber sein könnte, das vorne zu viel plaste dran ist und er deshalb nicht
Habe mal was gelesen von einer eSATA LED, aber die sehe ich nicht, gibts sicher an meiner box nicht.
So, reboot hilft auch nicht... ist schon seltsam habe leider nix anderes zum testen.
Bevor ich alles dran setze das eSATA geht, ist da eigentlich an der Box schneller (als USB Anbindung) wenn ich die Disk als Backup nutzen möchte?
brakeprofi
14. Okt 2008
Bei mir ging die esata lampe kurz an und dann wieder aus. Das sagt mir, dass es am Kontakt nicht liegen kann.
brakeprofi
14. Okt 2008
Meine DS ist seit Oktober unterwegs, der Händler sagt sie ist in Taiwan, Synology kann sie nicht finden. Ich bin ziemlich sauer auf beide. Der Händler, weil es ihn nicht interessiert, dass das Ding ziemlich schnell nach Taiwan kommt auch wenn es bisschen was kostet und auf Synology, dass die von sich aus nicht einen besseren Service anbieten. Bei der nächsten NAS wird mit Sicherheit genau hingeschaut, was es noch für Alternativen gibt. Solange kann man nicht auf einen Server warten. Das werde ich denen auch noch mitteilen.
brakeprofi
14. Okt 2008
Ich hatte jetzt zwei DS107+ und bei beiden funktionierte der esata Port nicht.
Das ließ einen schon zweifeln, ob das Problem hinter der Tastatur sitzt :D
Bei meiner neuen DS109 gehen aber alle diese Geräte die vorher nicht gingen.
Da sind mit Sicherheit auch die esata Ports nicht funktionsfähig/defekt bei all den anderen Leuten bei denen es auch nicht geht, hier im thread.
DSL-Hexe
01. Apr 2008
Bei der DS-207+ funktioniert der eSATA Port.
Kugelblitz
22. Sep 2007
Habe jetzt eine 209+ und das eSATA problem besteht immer noch. Kernel log ist an Synology geschickt. Ich meld mich hier wenns was neues gibt.
DS 209+ | DSM 2.3-1157 | 2x Western Digital WD10EACS (je 1TB) | eSata ICY Box IB-362StUS2-B| 1x Western Digital WD500AAKS (je 500GB)
DS 107e | DSM 2.3-1157 | 1x Western Digital WD10EACS (je 1TB)
Computer:
1x Notebook Win 7 Home
1x Macbook Pro Win 7 & Mac OSX
Netzwerk: | 1000Mbit LAN | Wlan N
linuxdep
02. Jan 2009
also, ich habe mal in ein neues kabel investiert, jetzt geht es
