Nach Deinstallation Mail Server und Mail Station und Restart.
Feb 23 13:56:24 kernel: [ 34.930000] o eth0, phy chipid = 1410e90, Support WOL = 32
Feb 23 13:56:24 kernel: [ 35.040000] md: invalid raid superblock magic on sda5
Feb 23 13:56:24 kernel: [ 35.050000] md: sda5 does not have a valid v0.90 supe rblock, not importing!
Feb 23 13:56:24 kernel: [ 35.100000] md: invalid raid superblock magic on sdb5
Feb 23 13:56:24 kernel: [ 35.110000] md: sdb5 does not have a valid v0.90 supe rblock, not importing!
Feb 23 13:56:24 kernel: [ 35.130000] md: sda2 has different UUID to sda1
Feb 23 13:56:24 kernel: [ 35.140000] md: sdb2 has different UUID to sda1
Feb 23 13:56:24 kernel: [ 35.880000] VFS: Mounted root (ext2 filesystem) on de vice 1:0.
Feb 23 13:56:24 kernel: [ 35.910000] ds212+_synobios: module license 'Synology Inc.' taints kernel.
Feb 23 13:56:24 kernel: [ 35.920000] Disabling lock debugging due to kernel ta int
Feb 23 13:56:24 kernel: [ 35.960000] correction with 0x0f
Feb 23 13:56:24 kernel: [ 36.020000] Brand: Synology
Feb 23 13:56:24 kernel: [ 36.020000] Model: DS-212+
Feb 23 13:56:24 kernel: [ 36.020000] This is default settings: set group disks wakeup number to 1, spinup time deno 1
Feb 23 13:56:24 kernel: [ 36.060000] synobios: unload
Feb 23 13:56:24 kernel: [ 37.240000] synoacl module [synoacl_ext4] is not load ed
Feb 23 13:56:24 kernel: [ 37.240000] synoacl module [synoacl_vfs] is not loade d
Feb 23 13:56:24 kernel: [ 37.280000] EXT3-fs: md0: couldn't mount because of u nsupported optional features (240).
Feb 23 13:56:24 kernel: [ 37.280000] EXT2-fs: md0: couldn't mount because of u nsupported optional features (240).
Feb 23 13:56:24 kernel: [ 37.320000] VFS: Mounted root (ext4 filesystem) on de vice 9:0.
Feb 23 13:56:24 kernel: [ 40.490000] cesadev_init(bf182000)
Feb 23 13:56:24 kernel: [ 40.520000] mvCesaInit: sessions=10240, queue=64, pSr am=f0000000
Feb 23 13:56:24 kernel: [ 40.670000] encryptfs using the OCF package.
Feb 23 13:56:24 kernel: [ 41.100000] correction with 0x0f
Feb 23 13:56:24 kernel: [ 41.160000] Brand: Synology
Feb 23 13:56:24 kernel: [ 41.160000] Model: DS-212+
Feb 23 13:56:24 kernel: [ 41.160000] This is default settings: set group disks wakeup number to 1, spinup time deno 1
Feb 23 13:56:25 spacetool: spacetool.c:2463 [Info] Old vg path: [/dev/vg1000], N ew vg path: [/dev/vg1000], UUID: [EDYxSd-DX0p-WFc8-7qLG-mI0V-8GNG-E5d193]
Feb 23 13:56:25 spacetool: spacetool.c:2470 [Info] Activate all VG
Feb 23 13:56:25 spacetool: spacetool.c:2481 Activate LVM [/dev/vg1000]
Feb 23 13:56:26 synovspace: vspace_wrapper_load_all.c:75 [INFO] The mount device path of space [/volume1] is [/dev/vg1000/lv]
Feb 23 13:56:34 scemd: scemd.c:154 fan_type=6, raid_type=1, led_type=1, thermal_ type=2, diskled_ctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_typ e=1, fan_number=1, eunit_pwron_type=2, pis_type=1, rtc_type=1, lcm_type=2, wifi_ wps_type=0
Feb 23 13:56:34 scemd: modules/fan_speed_adjust_common.c:118 Type: INTERNAL Fan Mode: LOW
Feb 23 13:56:35 scemd: modules/raid_sys_volume_check.c:150 MD0 active disks 2, d esigned disks 2
Feb 23 13:56:35 scemd: modules/raid_sys_volume_check.c:150 MD1 active disks 2, d esigned disks 2
Feb 23 13:56:35 scemd: modules/disk_hibernation.c:1802 Force hibernation enable, idle minutes 20
Feb 23 13:56:35 scemd: modules/disk_hibernation.c:1817 SATA Deep sleep timer 1
Feb 23 13:56:35 scemd: modules/disk_hibernation.c:1826 Eunit Deep sleep timer 0
Feb 23 13:56:35 scemd: disk/disk_config_all.c:124 apply /usr/syno/bin/syno_disk_ ctl --wcache-off /dev/sda 1>/dev/null 2>&1
Feb 23 13:56:35 kernel: [ 54.750000] ata1.00: Disable disk write cache in EH
Feb 23 13:56:35 scemd: disk/disk_config_all.c:124 apply /usr/syno/bin/syno_disk_ ctl --wcache-off /dev/sdb 1>/dev/null 2>&1
Feb 23 13:56:35 kernel: [ 54.830000] ata2.00: Disable disk write cache in EH
Feb 23 13:56:35 scemd: modules/scemd_connector.c:103 scemd connector thread star t.
Feb 23 13:56:35 scemd: scemd.c:154 fan_type=6, raid_type=1, led_type=1, thermal_ type=2, diskled_ctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_typ e=1, fan_number=1, eunit_pwron_type=2, pis_type=1, rtc_type=1, lcm_type=2, wifi_ wps_type=0
Feb 23 13:56:35 scemd: scemd.c:353 WIFI/WPS button is not support on this model.
Feb 23 13:56:36 kernel: [ 55.190000] usb usb2: No SuperSpeed endpoint companio n for config 1 interface 0 altsetting 0 ep 129: using minimum values
Feb 23 13:56:36 kernel: [ 55.440000] Got empty serial number. Generate serial number from product.
Feb 23 13:56:37 synoprint: printer_enable_ext.c:488 delete printer failed: no bu s id
Feb 23 13:56:37 syno_hdd_util: Model:[WD20EARS-00MVWB0], Firmware:[51.0AB51], S/ N:[WD-WMAZA1735746] in [/dev/sdb] is not ssd
Feb 23 13:56:37 syno_hdd_util: Model:[WD20EARS-00J99B0], Firmware:[80.00A80], S/ N:[WD-WCAWZ1741214] in [/dev/sda] is not ssd
Feb 23 13:56:37 synocheckshare: service_volume_getby_link.c(77)szLinkPath = /var /services/homes ,link value = , errno=Invalid argument
Feb 23 13:56:38 synocheckshare: Fix shares in smb.conf.
Feb 23 13:56:38 synocheckshare: service_volume_getby_link.c(77)szLinkPath = /var /services/homes ,link value = , errno=Invalid argument
Feb 23 13:56:39 synocheckshare: service_disable_set.c(68)Not defined date : id=4
Feb 23 13:56:39 synocheckshare: service_volume_getby_link.c(77)szLinkPath = /var /services/homes ,link value = , errno=Invalid argument
Feb 23 13:56:39 synocheckshare: synocheckshare.c(610)[8000] Failed to get info o f service ID=10
Feb 23 13:56:42 synousbdisk: service_volume_getby_link.c(77)szLinkPath = /var/se rvices/homes ,link value = , errno=Invalid argument
Feb 23 13:56:42 synousbdisk: RCClean succeeded
Feb 23 13:56:42 synosata: synosata.c:152 no external sata devices granted
Feb 23 13:56:44 ddnsd: main(ddnsd.c:3006): not enable DDNS, shutdown daemon
Feb 23 13:56:44 upnpd: lib/rule.c:668 can't get rule form rule.conf
Feb 23 13:56:44 upnpd: (upnpd.c:256) failed to load rule.conf
Feb 23 13:56:44 hotplugd: hotplugd.c:1033 failed get usb status from usb config, DEVICE=/proc/bus/usb/001/001, usbid=1d6b:0002
rion-ehci.0
Feb 23 13:56:44 hotplugd: ##### ACTION:add
Feb 23 13:56:44 hotplugd: DEVICE:/proc/bus/usb/001/001
Feb 23 13:56:44 hotplugd: DEVPATH:usb1
Feb 23 13:56:44 hotplugd: SUBSYSTEM:usb
Feb 23 13:56:44 hotplugd: hotplugd.c:807 Fail to recognize usb DEVNAME=, DEVPATH =usb1
Feb 23 13:56:44 hotplugd: hotplugd.c:1331 failed to setup usb config, (DEVPATH, DEVICE, ACTION, DEVNAME, INTERFACE)=(usb1, /proc/bus/usb/001/001, add, , )
rion-ehci.0
Feb 23 13:56:44 hotplugd: DEVPATH:1-0:1.0
Feb 23 13:56:44 hotplugd: INTERFACE:9/0/0
Feb 23 13:56:44 hotplugd: hotplugd.c:1033 failed get usb status from usb config, DEVICE=/proc/bus/usb/002/001, usbid=1d6b:0003:0000:01:01.0
Feb 23 13:56:44 hotplugd: DEVICE:/proc/bus/usb/002/001
Feb 23 13:56:44 hotplugd: DEVPATH:usb2
Feb 23 13:56:44 hotplugd: hotplugd.c:807 Fail to recognize usb DEVNAME=, DEVPATH =usb2
Feb 23 13:56:44 hotplugd: hotplugd.c:1331 failed to setup usb config, (DEVPATH, DEVICE, ACTION, DEVNAME, INTERFACE)=(usb2, /proc/bus/usb/002/001, add, , )
