Firmware 1944 im Anmarsch?
ubuntulinux
23. Jan 2010
Die IP liegt bei cablecom, darum denke ich er hostet es auf seiner syno zuhause.
atarifreak
01. Apr 2009
ok. Das ist klar. Aber wie bekommt er sie da drauf? jede datei Einzeln runterladen oder per Skript?
*auchmachenwill*
würds dann auch dem Webserver hosten :) schneller :-D
nachon
21. Aug 2011
Also ich konnte bisher nch nicht viel testen, aber bisher habe ich den Eindruck, das alles etwas flüssiger und Smoother läuft.
Mal abwarten und so ein paar Dinge ausprobieren.
Nomax2000
Gesperrt
25. Sep 2008
Dann mal der Changelog:
Change log:
Added 23 new IP camera models including Axis, D-Link, Forenix, Instar, Zavio, Foscam and Etrovision. For the complete supported camera list, please see here.
Added an option in Photo Station 5 to enable/disable the photo sharing feature to social networks.
Upgraded Apache server to 2.2.21.
Enhanced the compatibility with non-English Windows ADS.
Enhanced the compatibility with 3TB hard drives.
Enhanced the security, speed, and stability of Photo Station 5.
Enhanced the compatibility of Photo Station 5 with new Facebook APIs.
Enhanced the compatibility of Google docs viewer in File Browser.
Enhanced the compatibility of File Browser and File Station with Firefox 7.
Enhanced the compatibility of CalDAV and AirPlay with iOS 5.
Enhanced the stability of iTunes server.
Enhanced the compatibility of Media Server with LG BD player, Samsung TV, and SONY BRAVIA TV.
Enhanced the compatibility of Surveillance Station with Vivotek, ACTi, IQeye, TP-Link, Axis, Basler, HikVsion, Y-cam, Airlive and Compro cameras.
Optimized system memory management when Surveillance Station 5 is running multiple channel live-views.
Fixed an issue where you cannot log in Personal Photo Station with DS photo+ for Android mobile models.
Fixed an issue about schedule recording for Surveillance Station 5.
Other minor bug fixes.
Limitation & Known Issues
To connect to CalDAV server on DiskStation with an iOS 5 device, change the setting to "Sync All Events" in "Settings > Mail, Contact, Calendars" on your iOS 5 device.
Refer to "Limitation & Known Issues for all versions" for other limitations.
santos69
29. Okt 2010
Auf jeden Fall ist das Problem der Wiedergabe von der DS Audiostation an der Apple TV2 neuestes iOS mit dieser Version gelöst und ich wieder glücklich.
Probleme konnte ich keine feststellen.
teplet
24. Jul 2011
nur zur sicherheit: pyload und andere erweiterungen sind nach der installation erstmal weg, oder?
ubuntulinux
23. Jan 2010
IPKG-Sachen bleiben normalerweise.
Struppix
10. Apr 2009
DKeppi
01. Apr 2011
Der Sym-Link ist weg, wodurch pyload und auch optware nicht mehr gestartet wird.
ln -s /volume1/@optware /opt
auf der Kommandozeile, dann Neustart der DS und optware bzw. pyload funkt wieder!
Struppix
10. Apr 2009
Homer MB
20. Feb 2011
habe heute die neue 1944 Update aufgespielt.
Abfrage des Drucker Tintenstands funktioniert wieder. - Das IPKG ink Paket bleibt erhalten, was ihr nur noch machen müsst wie im Wiki ab Punkt drei bis Punkt fünf die weiteren Einstellungen vohrnehmen. Wer in Punkt 4 nicht lange suchen möchtet findet die Zeile (bei mir 358).
Mailstation : (Selfhostbenutzer) - Main.cf die fehlenden Daten am Ende einfügen. Bei mir fehlte die Zeile "smtpd_tls_security_level = may" was im Outlook und am I-Pod, Fritz-Fon zu Anmeldefehlern führte.
Sabnzbd : Man kann wieder Problemlos Update durchführen.
Gruß Homer
DKeppi
01. Apr 2011
laserdesign
11. Jan 2011
seltsam, ich muss den SymLink auf /opt auch immer neu setzen, was ich auch komisch finde, es wird schon von Photostation 6 gesprochen, ich habe nach dem update auf 1944 immer noch Photostation 5.
Ap0phis
16. Dez 2010
Wer sich nicht sicher ist, der schaut sich einfach die Release-Notes an.
Da finde ich auch nichts von PS 6 ... höchstens von Überarbeitungen der PS 5.
laserdesign
11. Jan 2011
@Ap0phis,
danke für die klärenden Worte
