- 06. Jan. 2025
Wo kommt die 3001 her?
Probier mal
API_URL: http://immich-server:2283/api
ODE_ENV=production
TZ=Europe/Berlin
# Database
DB_HOSTNAME=immich-db
DB_USERNAME=immichuser
DB_PASSWORD=immichpassword
DB_DATABASE_NAME=immich
# Optional Database settings:
# DB_PORT=5432
# Redis
REDIS_HOSTNAME=immich-redis
# Optional Redis settings:
# REDIS_PORT=6379
# REDIS_DBINDEX=0
# REDIS_PASSWORD=
# REDIS_SOCKET=
# Log message level - [simple|verbose]
LOG_LEVEL=log
# JWT SECRET
# This JWT_SECRET is used to sign the authentication keys for user login
# You should set it to a long randomly generated value
# You can use this command to generate one: openssl rand -base64 128
JWT_SECRET=;P'-4\"VRZ=?WDs-,XxZTP;?w;fPScvSr'!IVX1X|.e+.8TW/,wHvbq.xHqA=eU{\=tS1-D[tF-Keva;v;gy)24CFwH1j7[*?Ob/C.|[-d,3[WHJ,yYe(Lr:,cfOhIAI
# Reverse Geocoding
# DISABLE_REVERSE_GEOCODING=false
# Reverse geocoding is done locally which has a small impact on memory usage
# This memory usage can be altered by changing the REVERSE_GEOCODING_PRECISION variable
# This ranges from 0-3 with 3 being the most precise
# 3 - Cities > 500 population: ~200MB RAM
# 2 - Cities > 1000 population: ~150MB RAM
# 1 - Cities > 5000 population: ~80MB RAM
# 0 - Cities > 15000 population: ~40MB RAM
REVERSE_GEOCODING_PRECISION=3
# Alternative Service Addresses - Optional
# This is an advanced feature for users who may be running their immich services on different hosts.
# It will not change which address or port that services bind to within their containers, but it will change where other services look for their peers.
# Note: immich-microservices is bound to 3002, but no references are made
IMMICH_WEB_URL=http://immich-web:3000
IMMICH_SERVER_URL=http://immich-server:3001
IMMICH_MACHINE_LEARNING_URL=http://immich-machine-learning:3003
# OAuth Setting - Optional
# These setting will enable OAuth login for your instance of Immich
# Folow the instructions in the page https://immich.app/docs/usage/oauth to set up your OAuth provider
# OAUTH_ENABLED=false
# OAUTH_ISSUER_URL=
# OAUTH_CLIENT_ID=
# OAUTH_CLIENT_SECRET=
# OAUTH_BUTTON_TEXT=Login with OAuth
# OAUTH_AUTO_REGISTER=true
# OAUTH_SCOPE="openid profile email"
Das war es! Man muss den Namen des Container nehmen und den Port 2283!Wo kommt die 3001 her?
Probier malWegen der Synology IP, das scheint mal wieder ein Synology Docker Problem zu sein. Siehe https://github.com/Salvoxia/immich-folder-album-creator/issues/105Code:API_URL: http://immich-server:2283/api
services:
immich-server:
image: ghcr.io/immich-app/immich-server:release
container_name: Immich-SERVER
hostname: immich-server
user: 1026:101
security_opt:
- no-new-privileges:true
env_file:
- immich.env
ports:
- 8212:2283
volumes:
- /volume2/photo2:/usr/src/app/upload:rw
- /volume2/photo:/home/photo/archiv:rw
- /volume2/homes/Sandro/Photos:/home/Sandro:rw
- /volume2/homes/Tanja/Photos:/home/Tanja:rw
restart: on-failure:5
depends_on:
immich-redis:
condition: service_healthy
immich-db:
condition: service_started
immich-redis:
image: redis
container_name: Immich-REDIS
hostname: immich-redis
security_opt:
healthcheck:
test: ["CMD-SHELL", "redis-cli ping || exit 1"]
user: 1026:100
environment:
- TZ=Europe/Berlin
volumes:
- /volume2/docker/immich/redis:/data:rw
immich-db:
image: tensorchord/pgvecto-rs:pg16-v0.2.0
container_name: Immich-DB
hostname: immich-db
security_opt:
healthcheck:
test: ["CMD", "pg_isready", "-q", "-d", "immich", "-U", "immichuser"]
interval: 10s
timeout: 5s
retries: 5
volumes:
- /volume2/docker/immich/db:/var/lib/postgresql/data:rw
environment:
- TZ=Europe/Berlin
- POSTGRES_DB=immich
- POSTGRES_USER=immichnutzer
- POSTGRES_PASSWORD=immichpw2025
image: ghcr.io/immich-app/immich-machine-learning:release
container_name: Immich-LEARNING
hostname: immich-machine-learning
user: 1026:100
security_opt:
env_file:
- immich.env
volumes:
- /volume2/docker/immich/upload:/usr/src/app/upload:rw
- /volume2/docker/immich/cache:/cache:rw
- /volume2/docker/immich/matplotlib:/matplotlib:rw
environment:
- MPLCONFIGDIR=/matplotlib
depends_on:
immich-db:
immich-folder-album-creator:
image: salvoxia/immich-folder-album-creator:latest
container_name: immich_folder_album_creator
restart: unless-stopped
environment:
API_URL: http://immich-server:8212/api
API_KEY: "xxx"
ROOT_PATH: /home/photo/archiv
ALBUM_LEVELS: "2,2"
CRON_EXPRESSION: "0 * * * *"
TZ: Europe/Berlin
1.
Du nutzt in den ersten beiden Beiträgen öfter die Bezeichnung "Alben" für Immich.
Sind damit Alben im Sinne von Synology Photo gemeint, also nur virtuelle Ordner (Playlisten) oder physische Ordner mit Dateien?
2.
Wie erreichst du Immich von außerhalb?
3.
Ist Zugang zu Immich auf dem NAS für User per Quickconnect möglich?
(ich kann meinen Usern nur QC anbieten wegen Starlink)
4.
Kann Immich mittlerweile mit IPTC Stichwörtern (Tags) umgehen?
Hintergrund: Ich kategorisiere mit Tags, das ist für mich sehr wichtig. (Unter anderem) ist mir wichtig, erkannte Personen zusätzlich mit einem PersonenTAG im Foto zu versehen. (nur) so bin ich unabhängig von der Datenbank der Fotosgallerie und kann erkannte Personen auch mit anderer Software auf anderen BS finden/filtern.
5.
Und sind bedingte Alben (Smartalben) möglich?
6.
Das man denselben Fotobestand des
privaten Bereichs (\homes\user\photo\....)
mit Immich und gleichzeitig mit Synology Photo nutzen kann, das hast du hinbekommen und beschrieben.
Wie ist das mit dem
Freigegebenen Bereich ( \photo\...),
bei dem hinsichtlich der Rechte ja Synology Photo den Hut auf hat?
Geht das auch?
Er hatte mal kurz 5 Bilder geladen aus meiner externen Bibliothek aber dann kommt immer wieder die Fehlermeldung.
Ja - das ist korrekt. Da hat sich ein Fehler auf der ersten Seite eingeschlichen. Sorry. Kann ich jetzt allerdings leider nicht mehr korrigieren.
wenn Du genau schreibst was wo geändert werden soll so kann ich das machen.
user: 1026:100 --> user: 1026:101
