ipkg install optware-devel wget wget-ssl konflikt
hollyofnone
11. Aug 2008
genau dieses
ls -l
w- 1 root root 129518 May 30 09:57 Packages.gz
w- 1 root root 170003 Apr 29 09:38 libidn_1.21-1_arm.ipk
w- 1 root root 881 Dec 4 2010 optware-devel_6.8-10_arm.ipk
w- 1 root root 250390 May 19 11:34 syno-x07-bootstrap_1.2-7_arm.xsh
w- 1 root root 171005 May 20 2010 wget-ssl_1.12-2_arm.ipk
w- 1 root root 172419 May 14 2010 wget-ssl_1.12-2_arm1.ipk
Binomico
01. Jun 2010
hollyofnone
11. Aug 2008
NASWEIS> umount /opt
NASWEIS> rm -rf /opt
NASWEIS> cd /volume1/public
NASWEIS> wget http://ipkg.nslu2-linux.org/feeds/op..._1.2-7_arm.xsh
wget: error while loading shared libraries: libssl.so.0.9.8: cannot open shared object file: No such file or directory
wobei die
unter /volume1/tmp/ liegt
Binomico
01. Jun 2010
Okay dann entweder ins tmp wechseln und "sh syno...." oder mal "/usr/syno/bin/wget http://ipkg.nslu2-linux.org/feeds/op..._1.2-7_arm.xsh"
hollyofnone
11. Aug 2008
NASWEIS> sh syno-x07-bootstrap_1.2-7_arm.xsh
Optware Bootstrap for syno-x07.
Extracting archive... please wait
bootstrap/
bootstrap/bootstrap.sh
bootstrap/ipkg-opt.ipk
bootstrap/ipkg.sh
bootstrap/optware-bootstrap.ipk
bootstrap/wget.ipk
1226+1 records in
1226+1 records out
Backup your configuration settings, then type:
rm -rf /volume1/@optware
rm -rf /usr/lib/ipkg
This will remove all existing optware packages.
You must *reboot* and then restart the bootstrap script.
BusyBox v1.16.1 (2011-04-08 10:15:04 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
NASWEIS>
reboot
und dann
NASWEIS> ipkg update
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-x07/cross/unstable/Packages.gz
An error ocurred, return value: 1.
Collected errors:
ipkg_download: ERROR: Command failed with return value 127: `wget --passive-ftp -q -P /opt/ipkg-JkAJYV http://ipkg.nsl
u2-linux.org/feeds/optware/syno-x07/cross/unstable/Packages.gz'
NASWEIS>
Binomico
01. Jun 2010
Do it ;-)
hollyofnone
11. Aug 2008
-ash: ipkg: not found
bootstrap/
bootstrap/ipkg.sh
bootstrap/wget.ipk
1226+1 records in
1226+1 records out
Creating temporary ipkg repository...
Installing optware-bootstrap package...
Unpacking optware-bootstrap.ipk...Done.
Configuring optware-bootstrap.ipk...Setting up ipkg arch-file
Done.
Installing ipkg...
Unpacking ipkg-opt.ipk...Done.
Configuring ipkg-opt.ipk...WARNING: can't open config file: /usr/syno/ssl/openssl.cnf
Done.
Removing temporary ipkg repository...
Installing wget...
Installing wget (1.12-2) to root...
Configuring wget
Successfully terminated.
Creating /opt/etc/ipkg/cross-feed.conf...
Setup complete.
Inflating http://ipkg.nslu2-linux.org/feeds/optware/syno-x07/cross/unstable/Packages.gz
Updated list of available packages in /opt/lib/ipkg/lists/cross
Danke
tAntChen
12. Sep 2011
Falls das nochmal jemand braucht.
Ich hatte gerade das selbe Problem und hab mich an diesen Thread gehalten, mir lief es aber kalt den Rücken herunter als es darum ging /opt zu löschen und ipkg neu auf zu setzten.
Es hat in meinem Fall tatsächlich gereicht, wie beschrieben, nach der fehlgeschlagenen Installation von wget dieses aus /usr/syno/bin/ zu entfernen und dann neu zu installieren.
Erstmal alles runter, nun ist wget aber noch da in /usr/syno/bin/wget , halt mit einer alten Version.
ipkg remove wget-ssf
ipkg remove wget
Das schlägt Fehl aber die ipkg-datei (wget_1.12-2_arm.ipk) hat man schon mal auf Tasche.
ipkg install wget
Also weg damit oder umbenennen.
rm /usr/syno/bin/wget
Und nun (die Datei sollte nach dem Fehlschlag im pwd liegen)
ipkg install wget_1.12-2_arm.ipk
Dann bekommt man mit wget --version
wget --version
GNU Wget 1.12 built on linux-gnueabi.
Dann klappte auch ipkg update wieder, das zumindest meine Erfahrung.
