Kein Firmewareupdate möglich -> Nicht ausreichende Kapazität für Aktualisierung....
admin@NAS:~$ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/md0 2385528 1998072 268672 89% /
none 1013120 4 1013116 1% /dev
/tmp 1017376 580 1016796 1% /tmp
/run 1017376 2140 1015236 1% /run
/dev/shm 1017376 12 1017364 1% /dev/shm
none 4 0 4 0% /sys/fs/cgroup
/dev/vg1000/lv 5621463124 596245448 5025217676 11% /volume1
Ich bin auch absoluter Linux idiot....
wenn ich ins verzeichniss rein gehe steht da nüx....
admin@NAS:~$ du -d 1 -x /dev/md0
0 /dev/md0
Bitte helft mir!
Ist eine DS 1515+
du: cannot read directory ‘/var/crash’: Permission denied
du: cannot read directory ‘/var/lib/pengine’: Permission denied
du: cannot access ‘/var/lib/heartbeat/cores’: Permission denied
du: cannot access ‘/var/lib/heartbeat/lrm’: Permission denied
du: cannot access ‘/var/lib/heartbeat/crm’: Permission denied
du: cannot access ‘/var/lib/ha/sync’: Permission denied
du: cannot read directory ‘/var/lib/net-snmp’: Permission denied
du: cannot read directory ‘/var/log/nginx’: Permission denied
du: cannot read directory ‘/var/log/selfcheck’: Permission denied
du: cannot read directory ‘/var/log/synolog’: Permission denied
du: cannot read directory ‘/var/spool/webapi’: Permission denied
du: cannot read directory ‘/var/state/ups’: Permission denied
du: cannot read directory ‘/var/target’: Permission denied
du: cannot read directory ‘/var/db’: Permission denied
33076 /var
du: cannot read directory ‘/etc/postgresql’: Permission denied
du: cannot access ‘/etc/syslog-ng/patterndb.d’: Permission denied
du: cannot access ‘/etc/syslog-ng/syslog-ng.conf’: Permission denied
du: cannot read directory ‘/etc/space’: Permission denied
9716 /etc
du: cannot read directory ‘/etc.defaults/postgresql’: Permission denied
du: cannot access ‘/etc.defaults/syslog-ng/patterndb.d’: Permission denied
du: cannot access ‘/etc.defaults/syslog-ng/syslog-ng.conf’: Permission denied
8980 /etc.defaults
17992 /.syno
16 /.system_info
4 /.old_patch_info
4 /initrd
du: cannot read directory ‘/lost+found’: Permission denied
4 /lost+found
4 /mnt
du: cannot read directory ‘/root’: Permission denied
4 /root
du: cannot access ‘/usr/share/cluster-glue/ha_cf_support.sh’: Permission denied
du: cannot access ‘/usr/share/cluster-glue/openais_conf_support.sh’: Permission denied
du: cannot access ‘/usr/share/cluster-glue/ha_log.sh’: Permission denied
du: cannot access ‘/usr/share/cluster-glue/combine-logs.pl’: Permission denied
du: cannot access ‘/usr/share/cluster-glue/utillib.sh’: Permission denied
du: cannot access ‘/usr/share/pacemaker/acls-1.2.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/rule.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/pacemaker.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/versions.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/resources-1.2.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/report.collector’: Permission denied
du: cannot access ‘/usr/share/pacemaker/pacemaker-1.2.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/crm.dtd’: Permission denied
du: cannot access ‘/usr/share/pacemaker/resources-1.1.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/constraints-1.0.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/resources-1.0.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/constraints-1.1.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/score.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/acls-1.1.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/constraints-1.2.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/upgrade06.xsl’: Permission denied
du: cannot access ‘/usr/share/pacemaker/pacemaker-1.1.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/pacemaker-1.0.rng’: Permission denied
du: cannot access ‘/usr/share/pacemaker/crm-transitional.dtd’: Permission denied
du: cannot access ‘/usr/share/pacemaker/report.common’: Permission denied
du: cannot access ‘/usr/share/pacemaker/nvset.rng’: Permission denied
du: cannot read directory ‘/usr/share/debsig/keyrings/C42CCD870EBD11E7’: Permission denied
du: cannot access ‘/usr/share/resource-agents/ra-api-1.dtd’: Permission denied
du: cannot access ‘/usr/share/man/man8’: Permission denied
du: cannot access ‘/usr/share/man/man1’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/pengine’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/logtest’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/send_arp’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/cib’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/crm_primitive.py’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/crm_primitive.pyc’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/cibmon’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/atest’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/hb2openais.sh’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/ha_logd’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/stonithd’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/hb2openais-helper.pyo’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/tickle_tcp’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/ipctest’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/stonith-test’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/lrmd’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/sfex_daemon’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/hb2openais-helper.py’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/attrd’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/plugins’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/crmd’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/crm_primitive.pyo’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/findif’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/hb2openais-helper.pyc’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/ipctransientclient’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/base64_md5_test’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/transient-test.sh’: Permission denied
du: cannot access ‘/usr/lib/heartbeat/ipctransientserver’: Permission denied
du: cannot access ‘/usr/lib/lcrso/vsf_quorum.lcrso’: Permission denied
du: cannot access ‘/usr/lib/lcrso/service_pload.lcrso’: Permission denied
du: cannot access ‘/usr/lib/lcrso/objdb.lcrso’: Permission denied
du: cannot access ‘/usr/lib/lcrso/coroparse.lcrso’: Permission denied
du: cannot access ‘/usr/lib/lcrso/vsf_ykd.lcrso’: Permission denied
du: cannot access ‘/usr/lib/lcrso/service_evs.lcrso’: Permission denied
du: cannot access ‘/usr/lib/lcrso/pacemaker.lcrso’: Permission denied
du: cannot access ‘/usr/lib/lcrso/service_cpg.lcrso’: Permission denied
du: cannot access ‘/usr/lib/lcrso/service_cfg.lcrso’: Permission denied
du: cannot access ‘/usr/lib/lcrso/quorum_votequorum.lcrso’: Permission denied
du: cannot access ‘/usr/lib/lcrso/service_confdb.lcrso’: Permission denied
du: cannot access ‘/usr/lib/lcrso/quorum_testquorum.lcrso’: Permission denied
du: cannot access ‘/usr/lib/ocf/lib’: Permission denied
du: cannot access ‘/usr/lib/ocf/resource.d’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/completion.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/main.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/singletonmixin.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/ra.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/ui.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/idmgmt.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/cliformat.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/template.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/clidisplay.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/cibconfig.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/msg.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/cache.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/xmlutil.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/levels.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/userprefs.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/__init__.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/cibstatus.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/vars.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/utils.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/help.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/term.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/synocrm/parse.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/cts/CTStests.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/cts/CM_ais.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/cts/CTSaudits.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/cts/CTSscenarios.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/cts/CM_lha.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/cts/__init__.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/cts/CTSvars.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/cts/CTS.py’: Permission denied
du: cannot access ‘/usr/lib/python2.7/site-packages/cts/CIB.py’: Permission denied
du: cannot read directory ‘/usr/local/etc/synocron.d’: Permission denied
du: cannot read directory ‘/usr/syno/etc.defaults/letsencrypt’: Permission denied
du: cannot read directory ‘/usr/syno/etc.defaults/ssl’: Permission denied
du: cannot read directory ‘/usr/syno/etc.defaults/synocron.d’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/UtilArp.sh’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/drbd.conf’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/corosync’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/init.d’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/rc.volume’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/UtilSafemode.sh’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/serv.mon.conf’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/UtilRec.sh’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/UtilTarSmallupdate.sh’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/serv_conf_def.sh’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/synoha.sc’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/confsync’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/UtilHeartbeatCheck.sh’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/rc.ha’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/rc.subr’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/drbd.d’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/rc.define’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/SxxPost.sh’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/SxxPre.sh’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/serv.must.conf’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/UtilAuthKey.sh’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/ha.conf’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/model_groups.list’: Permission denied
du: cannot access ‘/usr/syno/etc.defaults/synoha/ntpclient.sh’: Permission denied
du: cannot read directory ‘/usr/syno/selfcheck’: Permission denied
du: cannot access ‘/usr/syno/synoha/etc.defaults’: Permission denied
du: cannot access ‘/usr/syno/synoha/etc’: Permission denied
du: cannot access ‘/usr/syno/synoha/var’: Permission denied
du: cannot access ‘/usr/syno/synoha/lib’: Permission denied
du: cannot access ‘/usr/syno/synoha/sbin’: Permission denied
du: cannot read directory ‘/usr/syno/etc/codesign/.gnupg’: Permission denied
du: cannot read directory ‘/usr/syno/etc/letsencrypt’: Permission denied
du: cannot read directory ‘/usr/syno/etc/private/session/current.users.access.time’: Permission denied
du: cannot read directory ‘/usr/syno/etc/ssl’: Permission denied
du: cannot read directory ‘/usr/syno/etc/synocron.d’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/UtilArp.sh’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/drbd.conf’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/corosync’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/init.d’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/rc.volume’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/UtilSafemode.sh’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/serv.mon.conf’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/UtilRec.sh’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/UtilTarSmallupdate.sh’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/serv_conf_def.sh’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/synoha.sc’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/confsync’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/UtilHeartbeatCheck.sh’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/rc.ha’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/rc.subr’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/drbd.d’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/rc.define’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/SxxPost.sh’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/SxxPre.sh’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/serv.must.conf’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/UtilAuthKey.sh’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/ha.conf’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/model_groups.list’: Permission denied
du: cannot access ‘/usr/syno/etc/synoha/ntpclient.sh’: Permission denied
du: cannot read directory ‘/usr/syno/etc/certificate/_archive’: Permission denied
du: cannot read directory ‘/usr/syno/etc/preference/Falk’: Permission denied
du: cannot read directory ‘/usr/syno/etc/preference/Larissa’: Permission denied
du: cannot read directory ‘/usr/syno/etc/preference/Ziems’: Permission denied
du: cannot read directory ‘/usr/syno/etc/preference/LarissaNas’: Permission denied
du: cannot read directory ‘/usr/syno/etc/preference/guest’: Permission denied
du: cannot read directory ‘/usr/syno/etc/preference/plex’: Permission denied
du: cannot read directory ‘/usr/syno/etc/preference/ts3server’: Permission denied
du: cannot read directory ‘/usr/syno/etc/preference/ts3webint’: Permission denied
du: cannot read directory ‘/usr/syno/etc/synoshare.bak’: Permission denied
701156 /usr
du: cannot read directory ‘/var.defaults/crash’: Permission denied
du: cannot read directory ‘/var.defaults/lib/pengine’: Permission denied
du: cannot access ‘/var.defaults/lib/heartbeat/cores’: Permission denied
du: cannot access ‘/var.defaults/lib/heartbeat/lrm’: Permission denied
du: cannot access ‘/var.defaults/lib/heartbeat/crm’: Permission denied
du: cannot access ‘/var.defaults/lib/ha/sync’: Permission denied
du: cannot read directory ‘/var.defaults/state/ups’: Permission denied
du: cannot read directory ‘/var.defaults/log/nginx’: Permission denied
5916 /var.defaults
776880 /
admin@NAS:~$
Du mußt den Befehl als user root ausführen. root wirst Du wenn Du nach Anmeldung als admin noch den Befehl sudo -i absetzt.
root@NAS:~# du -d 1 -x /
33812 /var
9956 /etc
9192 /etc.defaults
17992 /.syno
16 /.system_info
4 /.old_patch_info
4 /initrd
4 /lost+found
4 /mnt
1204828 /root
708848 /usr
5940 /var.defaults
1990608 /
Danke für den Tip! Btw herzlichen Dank für eure Hilfe!
root@NAS:~# du -d 1 -x /root
8 /root/.gnupg
1204808 /root/Downloads
1204828 /root
root@NAS:~# rm -r /root/downloads
rm: cannot remove ‘/root/downloads’: No such file or directory
root@NAS:~#
bin zu dumm den ordner downloads zu löschen!
Dein Problem liegt im /root Ordner, also
du -d 1 -x /root
root@NAS:~# rm -r /root/Downloads
8 /root/.gnupg
20 /root
root@NAS:~#
nen Großes D tuts dann! Danke!
Kann leider auf das neue Update nicht gehen....
df gibt mir folgende Info:
/dev/md0 2385528 2174336 92408 96% /
none 1013116 4 1013112 1% /dev
/tmp 1017304 1204 1016100 1% /tmp
/run 1017304 2344 1014960 1% /run
/dev/shm 1017304 192 1017112 1% /dev/shm
/dev/vg1000/lv 2879381040 1460678868 1418583388 51% /volume1
none 2879381040 1460678868 1418583388 51% /volume1/@docker/aufs/mnt/2de651b7029815f4f73ff17277c1ad4fb17dc72168de5f612012e111800af365
none 2879381040 1460678868 1418583388 51% /volume1/@docker/aufs/mnt/e09ef38e7162cf184fb04f0f8eefaed42f549a4e426c2197343ccfe2dcd9a4bd
Schau einmal, ob es in /var/log ein übergroßes Logfile gibt. Wenn ja, lösche es und sieh zu, dass es dort nicht wieder wächst. Wenn nein, dann suche die Verzeichnisse durch beginnend mit dem Kommando
du -xmd 1 /
Ich muss mich jetzt auch mal hier anhängen. Habe zwar die ganzen Posts gelesen, aber komme nicht so richtig weiter.
Bei mir scheint der Ordner /var das Problem zu sein. Dieser ist immens groß. Aber warum?
/dev/md0 2385528 2171248 95496 96% /
none 2018000 4 2017996 1% /dev
/tmp 2022284 1076 2021208 1% /tmp
/run 2022284 3352 2018932 1% /run
/dev/shm 2022284 4 2022280 1% /dev/shm
/dev/vg1000/lv 2869891288 1318688592 1551083912 46% /volume2
/dev/md2 2879392624 2494108448 385165392 87% /volume1
/volume2/@Tauschlaufwerk@ 2869891288 1318688592 1551083912 46% /volume2/Tauschlaufwerk
10228 /etc
16 /.system_info
9184 /etc.defaults
4 /initrd
4 /mnt
32 /.old_patch_info
4 /lost+found
120 /root
14408 /.syno
1437228 /var
686676 /usr
5928 /var.defaults
40 /volumeUSB1
16 /volumeUSB2
2163908 /
drwxr-xr-x 16 root root 4096 Oct 11 01:41 .
drwxr-xr-x 24 root root 4096 Oct 11 01:42 ..
drwxr-xr-x 3 root root 4096 Oct 5 2015 cache
drwxrwx--- 2 root root 4096 Mar 23 2016 crash
drwx--x--x 3 root root 4096 May 9 22:27 db
drwxr-xr-x 3 root root 4096 Mar 25 2016 dynlib
drwxr-xr-x 2 root root 4096 Jun 29 2015 empty
drwxr-xr-x 16 root root 4096 Oct 11 09:10 lib
lrwxrwxrwx 1 root root 11 Oct 5 2015 lock -> ../run/lock
drwxr-xr-x 11 root root 4096 Oct 10 12:02 log
drwxr-xr-x 21 root root 4096 Oct 11 01:46 packages
lrwxrwxrwx 1 root root 6 Mar 25 2016 run -> ../run
drwxr-xr-x 3 root root 4096 Oct 11 01:42 services
drwxr-xr-x 3 root root 4096 Oct 11 08:30 spool
drwxr-xr-x 3 root root 4096 Mar 25 2016 state
drwxr-xr-x 5 root root 4096 Mar 25 2016 synobackup
drwx------ 4 root root 4096 Mar 25 2016 target
drwxrwxrwt 4 root root 4096 Oct 11 09:20 tmp
Dann dort weitermachen mit
du -mxd 1 /var
Vermutlich hast Du ein übergroßes Logfile in /var/log. Das findest Du per
ls -l /var/log
Joa.. sieht so aus.
1 /var/cache
1 /var/crash
3 /var/dynlib
1 /var/empty
6 /var/lib
1394 /var/log
3 /var/packages
1 /var/services
1 /var/spool
1 /var/state
1 /var/synobackup
1 /var/tmp
1 /var/target
1 /var/db
1405 /var
-rw-rw---- 1 system log 103889 Oct 11 01:46 apparmor.log
lrwxrwxrwx 1 root root 46 Oct 5 2015 asterisk -> /var/packages/Asterisk/target/var/log/asterisk
-rw-rw---- 1 system log 6129674 Oct 12 11:36 auth.log
-rw-rw---- 1 system log 122757 Oct 11 09:20 bash_err.log
-rw-rw---- 1 system log 12023 Oct 12 11:37 bash_history.log
drwxr--r-- 2 root root 4096 Jun 29 2015 cluster
-rw-r--r-- 1 root root 33349 Oct 10 11:58 DeviceBusyList
-rw-r--r-- 1 root root 8419 Oct 10 12:02 DeviceBusyList2
-rw-r--r-- 1 root root 687 Oct 6 2015 disk_log.xml
-rw-r--r-- 1 root root 4209 Oct 11 01:42 disk_overview.xml
-rw-r--r-- 1 root root 549636 Oct 11 01:43 dmesg
-rw-r--r-- 1 root root 44216 Apr 21 20:53 dmesg.1.xz
-rw-r--r-- 1 root root 1252552 Oct 12 11:35 dms.log
-rw-r--r-- 1 root root 236782 Oct 3 10:28 dms.log.0.gz
-rw-r--r-- 1 root root 247679 Oct 2 22:20 dms.log.1.gz
-rw-r--r-- 1 root root 247132 Oct 2 21:53 dms.log.2.gz
-rw-r--r-- 1 root root 157649 Oct 2 21:43 dms.log.3.gz
drwx------ 2 root root 4096 Oct 5 2015 Docker
-rw-r--r-- 1 root root 62536 May 22 09:19 dpkg.log
-rw-r--r-- 1 root root 42190 May 22 09:19 dpkg_upgrade.log
-rw-rw---- 1 system log 5241 Oct 11 01:42 esynoscheduler.log
drwxr-xr-x 2 root root 4096 Oct 25 2015 httpd
-rw-rw---- 1 system log 541443 Oct 11 01:42 iscsi.log
-rw-r--r-- 1 root root 1413303693 Oct 12 11:37 JDownloader.log
-rw-rw---- 1 system log 475165 Oct 11 07:57 kern.log
drwxr-xr-x 2 admin users 4096 Jul 14 00:48 lighttpd
-rw-r--r-- 1 root root 30 Oct 6 2015 lvm_lv_create_log
-rw-rw---- 1 system log 8019232 Oct 12 11:36 messages
-rw-rw---- 1 system log 164552 Jul 3 19:42 messages.1.xz
-rw-rw---- 1 system log 167200 Jun 26 06:00 messages.2.xz
-rw-rw---- 1 system log 167592 Jun 17 13:01 messages.3.xz
-rw-rw---- 1 system log 164692 Jun 11 09:42 messages.4.xz
-rw-r--r-- 1 root root 0 Oct 6 2015 mount.log
drwxr-x--- 2 http root 4096 Feb 18 2016 nginx
-rw-rw-rw- 1 root root 156750 Oct 11 01:48 opentftp.log
-rw-r--r-- 1 root root 0 Oct 6 2015 partition
-rw------- 1 root root 14090 Oct 11 01:46 php-fpm.log
-rw-rw---- 1 system log 191007 Oct 11 08:27 postgresql.log
-rw-rw---- 1 system log 299107 Oct 12 11:36 router.log
drwxr-xr-x 2 root root 4096 Oct 5 2015 samba
-rw-rw---- 1 system log 631173 Oct 12 11:17 scemd.log
drwxr-x--- 2 root root 4096 May 9 21:34 selfcheck
-rw-rw-rw- 1 root root 6706 Oct 11 01:42 space_operation_error.log
-rw-r--r-- 1 root root 2020 Oct 11 01:42 synocmsclient.log
-rw-r--r-- 1 root root 75944 Oct 11 00:14 synocrond-execute.log
-rw-rw---- 1 system log 8429 Oct 11 01:42 synocrond.log
-rw-r----- 1 root root 39121 Mar 25 2016 synodtv.log
-rw-rw---- 1 system log 15382 Oct 11 01:39 synofeasibilitycheck.log
-rw-r--r-- 1 root root 8239 Apr 21 20:52 synoinfo.conf.bad
drwxr-x--- 2 root root 4096 Oct 12 11:36 synolog
-rw-r--r-- 1 root root 3136241 Oct 11 01:46 synopkg.log
-rw-rw---- 1 system log 3027 Oct 11 01:39 synopoweroff.log
-rw------- 1 root root 13683 Oct 11 01:42 synorelayd.log
-rw-rw---- 1 system log 495415 Oct 12 11:36 synoservice.log
-rw-rw---- 1 system log 104760 Jul 24 23:59 synoservice.log.1.xz
-rw-rw---- 1 system log 103560 Jun 28 06:03 synoservice.log.2.xz
-rw-rw---- 1 system log 101460 Jun 3 09:30 synoservice.log.3.xz
-rw-rw---- 1 system log 101320 Apr 30 06:44 synoservice.log.4.xz
-rw-rw---- 1 system log 88624 Mar 31 2016 synoservice.log.5.xz
-rw-rw---- 1 system log 707 Oct 11 01:39 synotifyd.log
-rw-r--r-- 1 root root 2949 May 22 09:19 synoupdate.log
-rw-rw---- 1 system log 29901 Oct 11 01:41 syslog.log
drwxr-xr-x 2 root root 4096 Oct 11 01:39 upstart
Da ist wohl einiges was man löschen könnte.
Ich würde da nicht eingreifen - außer beim JDownloader.log, was Dein Problem verursachen dürfte (1,4GB Größe).
Und wie bekomme ich dieses Log File gelöscht?
Ich habe es jetzt folgendermaßen probiert:
cd /var/log
rm JDownloader.log ==> no such file or Directory
unlink JDownloder.log ==> no such file or Directory
Habe auf jeden Fall im JDownloader das Logfile deaktiviert. So wächst es in Zukunft wenigstens nicht mehr an
Bei mir war es der jdownloader. Nach dessen Deinstallation war wieder alles ok.
Bei mir ist es das Logfile vom JDownloader. Aber den benutze ich ja ziemlich oft. Deshalb habe ich das Anlegen eines Logfiles deaktiviert. Allerdings muss man doch das bestehende Logfile löschen können oder nicht?
Edit: Scheint jetzt funktioniert zu haben. Aber anscheinend ist die Systempartition immernoch zu voll. Update lt. DSM nicht möglich.
Was ist mit den Logfiles: messages, auth.log und dms.log?
total 21180
-rw-rw---- 1 system log 6130899 Oct 12 12:12 auth.log
-rw-rw---- 1 system log 124931 Oct 12 11:55 bash_err.log
-rw-rw---- 1 system log 18579 Oct 12 12:19 bash_history.log
-rw-r--r-- 1 root root 1253702 Oct 12 12:15 dms.log
-rw-rw---- 1 system log 631300 Oct 12 12:07 scemd.log
drwxr-x--- 2 root root 4096 Oct 12 12:12 synolog
rm /var/log/JDownloader.log
Aber die Datei taucht in Deiner Liste nicht mehr auf. Wie hast Du sie entfernt?
Die übrigen genannten Logs sind (im Vergleich) klein und werden sauber rotiert. Da würde ich nichts ändern.
Kommando zurück!!
Was immens wichtig ist, ist ein Neustart nach löschen des Log Files vom JDownloader. Jetzt funzt alles prima.
Thx an dil88 für den Support!
