Jetzt lief es doch durch...siehe output
Aber nach Abschluss sieht mein Kopano aus wie vor der Migration.
So wie ich das sehe hat er sehr lange gewerkelt, allerdings ohne den notwendigen dump.
root@DiskStation:/volume1/kopano/backup# kopano4s-migration-zarafa start
Starting migration steps: 1) kopano baseline backup 2) zarafa db-backup. 3) restore to kopano-db. 4) user export from kopano migration version 5) restore users to kopano baseline
2020.01.16-22.22.35 step 1: skipped as kopano dump exists for today...
2020.01.16-22.22.35 step 2: skipped as zarafa dump exists for today...
Stopping Kopano core...
stopping kopano-server..
stopping kopano-spooler..
stopping kopano-dagent..
stopping kopano-gateway..
Stopping Kopano web...
stopping nginx..
stopping php7.0-fpm..
Stopping Kopano mail...
stopping postfix..
Stopping Kopano sys...
stopping rsyslog..
stopping cron..
kopano4s
Kopano services stopped
ls: cannot access /volume1/kopano/backup/dump-zarafa-*.sql.gz: No such file or directory
2020.01.16-22.23.18 step 3: restore zarafa dump of into kopano...
no valid restore argument was provided. Latest timestamp would be <no files exist>
2020.01.16-22.23.23 step 4: starting kopano migration (8.4.5) to run user export...
refresh: initializing container from fresh image loaded at docker hub..
init: remove and build kopano4s docker container from refreshed image.. stop:
remove container:
kopano4s
remove image:
Untagged: tosoboso/kopano4s
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
-Core-8.7.1.0_Webapp-3.5.6_Z-Push-2.5.1
Untagged: tosoboso/kopano4s@sha256:ac054294cb95cf3fcfed83dce284a4556ad9cdfa215c935557e57d6b91226b8d
Deleted: sha256:fd817dac472b66a6c5110e1a8f10838700b4801948f33bb48a39a285c1a60b5c
Deleted: sha256:96125bb816dbaffd49ab204f4e5954341cb18a7619b16764be193360672b3e71
Deleted: sha256:412cde449698fb946c00174435d2015af652744d71f5f67f0f9f22d69cb172a5
Deleted: sha256:098dc7d5ed1918c3eab4f933b7f7957cd7e214ee4eb1cef27efdbf78bea6105c
Deleted: sha256:ca0e2eee05931e6d091e9910920f57a8638848447333d49b62338977a7f966d7
Deleted: sha256:557f4b1483f0e07a9693a1d9c1f83069b210e4bfa1c6f03f3a573b8a003cf074
Deleted: sha256:99b5261d397c75b1de2c91f0c89f4e6f287248669b72de6cb143e82ea67ad056
build M-Core-8.4.5.0_Webapp-3.4.2_Z-Push-2.4.5:
postmap on '/etc/kopano/postfix/valiases'..
postmap on '/etc/kopano/postfix/recipient_bcc'..
postmap on '/etc/kopano/postfix/sender_bcc'..
postmap on '/etc/kopano/postfix/recipient_access'..
postmap on '/etc/kopano/postfix/sender_access'..
waiting for services to restart: 60s..
image intializing UID, GID, etc-cfg, log, ssl, post-build
initializing virtual aliases and pwd e.g. for proxy..
modifying kopano user and group ids (1061 / 65550) plus file limits ..
usermod: no changes
usermod: no changes
usermod: no changes
increasing php upload_max_filesize to 15M..
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "de_DE.UTF-8",
LC_ALL = "de_DE.UTF-8",
LANG = "de_DE.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
setting acl, ssl, fetchmail and plugins..
at least 1 poll entry must be present and init has to be done before starting it..
2020.01.16-22.39.38 sleep 4 min to have migration version running smoothly with zarafa database import..
2020.01.16-22.43.39 ERROR running imported data (see migrate-server.log); rolling back..
2020.01.16-22.43.39 rollback restore kopano baseline dump of 202001162056 ...
stoping kopano for restore of kopano from dump of 202001162056...
Gruß und gute Nacht
Gordon
