#!/bin/sh
main='/usr/syno/mailstation/etc/main.cf'
#main='./main.cf'
#map='./smtp_auth'
map='/usr/syno/mailstation/etc/smtp_auth'
echo -n 'Hostname des Relayhosts: '
while read relayhost
do
[ "x$relayhost" != 'x' ] && break
echo -n 'Hostname des Relayhosts: ' && continue
done
echo -n "$relayhost als Relay (r) oder Fallback (f) einrichten? Default f: "
while read type
do
case $type in
'r' | 'f')
break
type='f'
break
esac
done
echo -n "Benutzername fuer ${relayhost}: "
while read user
do
[ "x$user" != 'x' ] && break
done
if [ "x$user" != 'x' ]
then
echo -n "Passwort fuer $user auf $relayhost: "
while read passwort
do
break
done
fi
for i in relayhost smtp_sasl_auth_enable smtp_sasl_password_maps smtp_sasl_security_options smtp_use_tls smtp_enforce_tls smtp_tls_enforce_peername
do
case $i in
'relayhost')
[ "$type" == 'f' ] && echo 'fallback_relay = '$relayhost >> $main
[ "$type" == 'r' ] && echo 'relayhost = '$relayhost >> $main
'smtp_sasl_auth_enable' | 'smtp_use_tls' | 'smtp_enforce_tls')
echo "$i = yes" >> $main
'smtp_sasl_password_maps')
echo "$i = $map" >> $main
echo "$relayhost ${user}:${passwort}" >> $map
/usr/syno/mailstation/sbin/postmap $map
'smtp_sasl_security_options')
echo "$i = noanonymous" >> $main
'smtp_tls_enforce_peername')
echo "$i = no" >> $main
continue
esac
done
