lord_zunami
- 15. Feb. 2019
Stimmt CardDAV von Synology benutzt den Port 8008 8443
ich habe CardDAV deinstalliert
im Docker ist wieder:
sudo /volume1/it/matrix/run.sh up -d
rendering docker-compose.yml and passing it to docker-compose
Starting matrix_synapse_1 ...
matrix_db_1 is up-to-date
Starting matrix_synapse_1 ... done
sudo /volume1/it/matrix/run.sh prepare
creating host path for volume: /volume1/docker/matrix/synapse/data
creating host path for volume: /volume1/docker/matrix/element/config
creating host path for volume: /volume1/docker/matrix/db/data
copying synapse log.conf
/usr/local/lib/python3.8/site-packages/twisted/conch/ssh/common.py:14: CryptographyDeprecationWarning: int_from_bytes is deprecated, use int.from_bytes instead from cryptography.utils import int_from_bytes, int_to_bytes
Generating config file /data/homeserver.yaml
Generating signing key file /data/cloud.x***.at.signing.keyx***.at'. Please review this file and customise it to your needs.
rendering synapse homeserver.yaml
rendering element config.json
rendering reverse proxy configuration
synapse and element are not allowed to share the same domain, see: https://github.com/vector-im/element-web#important-security-note
Creating matrix_element_1 ... done
Creating matrix_db_1 ... done
Creating matrix_synapse_1 ... done
docker exec -ti matrix_synapse_1 register_new_matrix_user -c /data/homeserver.yaml http://localhost:8008
Error response from daemon: Container f9b978b9a6b068ee131d5b9074c0852b623a29cbd9818f216bf3d7a3368ad9ad is restarting, wait until the container is running
mkdir: can't create directory '/var/lib/postgresql/data/pgdata': Permission denied
