- 16. Jan. 2013
Jetzt kam so viel, dass der Puffer von Putty scheibar voll ist:
:: Loading module vfat ... [ OK ]
:: Loading module fuse[ 39.470000] fuse init (API version 7.13)
... [ OK ]
:: Loading module hfsplus ... [ OK ]
:: Loading module synoacl_vfs ... [ OK ]
:: Loading module synoacl_ext4 ... [ OK ]
:: Mounting usbfs ... [ OK ]
:: Loading module sky2[ 39.670000] sky2 driver version 1.25
... [ OK ]
:: Loading module synobios[ 39.770000] correction with 0x00
[ 39.840000] synobios: load, major number 201
[ 39.840000] Brand: Synology
[ 39.850000] Model: DS-211j
[ 39.850000] This is default settings: set group disks wakeup number to 1, spinup time deno 1
... [ OK ]
synochecknetworkcfg: Pass
[ 40.290000] eth0: mac address changed
[ 42.370000] eth0: link down
[ 42.370000] eth0: started
[ 42.380000] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 42.720000] eth0: link up, full duplex, speed 1 Gbps
[ 42.730000] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
eth0 Link encap:Ethernet HWaddr 00:11:32:08:43:A6
inet6 addr: fe80::211:32ff:fe08:43a6/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:532
RX bytes:0 (0.0 B) TX bytes:150 (150.0 B)
Interrupt:11
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
ls: /etc/dhcpd/dhcpd-*.conf: No such file or directory
ls: /etc/dhcpd/dhcpd-*.info: No such file or directory
grep: /etc/dhcpd/dhcpd.info: No such file or directory
kernel.panic = 3
:: Starting syslogd ... [ OK ]
Pass s00_synocheckfstab ...
Pass CheckSynoinfo ...
Pass CheckUser
Pass CheckSmbConf ...
Pass CheckCronTab ...
Pass CheckGroup.
Pass s62_synocheckapple ...
start findhostd
synokerneltz: set kernel time zone to -60
kernel.core_pattern = /volume1/@%e.core
fs.suid_dumpable = 2
vm.min_free_kbytes = 8192
:: Starting scemd
[ 50.080000] ------------[ cut here ]------------
[ 50.080000] WARNING: at arch/arm/mach-feroceon-kw/./synology-gpio.c:213 SYNO_CTRL_INTERNAL_HDD_LED_SET+0x40/0xfc()
[ 50.090000] Modules linked in: ds211j_synobios(P) sky2 synoacl_ext4(P) synoacl_vfs(P) hfsplus fuse vfat fat cryptosoft ecryptfs sha512_generic sha256_generic sha1_generic ecb cesa_ocf_drv(P) cesa_dev cryptodev(P) ocf(P) chainiv des_generic crc32c eseqiv krng ansi_cprng rng aes_generic md5 cbc cryptomgr pcompress aead crypto_hash crypto_blkcipher crypto_wq crypto_algapi cpufreq cpufreq_stats freq_table dm_snapshot crc_itu_t crc_ccitt quota_v2 quota_tree usbcore sg psnap llc ipv6
[ 50.130000] [<c00efe6c>] (unwind_backtrace+0x0/0xe4) from [<c01165e4>] (warn_slowpath_common+0x50/0x68)
[ 50.140000] [<c01165e4>] (warn_slowpath_common+0x50/0x68) from [<c00f45dc>] (SYNO_CTRL_INTERNAL_HDD_LED_SET+0x40/0xfc)
[ 50.150000] [<c00f45dc>] (SYNO_CTRL_INTERNAL_HDD_LED_SET+0x40/0xfc) from [<bf23af94>] (synobios_ioctl+0x4ec/0x99c [ds211j_synobios])
[ 50.160000] unwind: Index not found bf23af94
[ 50.160000] ---[ end trace 358c2d4f4263e651 ]---
[ 50.170000] ------------[ cut here ]------------
[ 50.170000] WARNING: at arch/arm/mach-feroceon-kw/./synology-gpio.c:214 SYNO_CTRL_INTERNAL_HDD_LED_SET+0x58/0xfc()
[ 50.180000] Modules linked in: ds211j_synobios(P) sky2 synoacl_ext4(P) synoacl_vfs(P) hfsplus fuse vfat fat cryptosoft ecryptfs sha512_generic sha256_generic sha1_generic ecb cesa_ocf_drv(P) cesa_dev cryptodev(P) ocf(P) chainiv des_generic crc32c eseqiv krng ansi_cprng rng aes_generic md5 cbc cryptomgr pcompress aead crypto_hash crypto_blkcipher crypto_wq crypto_algapi cpufreq cpufreq_stats freq_table dm_snapshot crc_itu_t crc_ccitt quota_v2 quota_tree usbcore sg psnap llc ipv6
[ 50.220000] [<c00efe6c>] (unwind_backtrace+0x0/0xe4) from [<c01165e4>] (warn_slowpath_common+0x50/0x68)
[ 50.230000] [<c01165e4>] (warn_slowpath_common+0x50/0x68) from [<c00f45f4>] (SYNO_CTRL_INTERNAL_HDD_LED_SET+0x58/0xfc)
[ 50.240000] [<c00f45f4>] (SYNO_CTRL_INTERNAL_HDD_LED_SET+0x58/0xfc) from [<bf23af94>] (synobios_ioctl+0x4ec/0x99c [ds211j_synobios])
[ 50.250000] unwind: Index not found bf23af94
[ 50.250000] ---[ end trace 358c2d4f4263e652 ]---
[ 50.250000] Unable to handle kernel NULL pointer dereference at virtual address 0000002c
[ 50.260000] pgd = c6288000
[ 50.270000] [0000002c] *pgd=0627f031, *pte=00000000, *ppte=00000000
[ 50.270000] Internal error: Oops: 17 [#1]
[ 50.270000] last sysfs file: /sys/class/scsi_host/host1/proc_name
[ 50.270000] Modules linked in: ds211j_synobios(P) sky2 synoacl_ext4(P) synoacl_vfs(P) hfsplus fuse vfat fat cryptosoft ecryptfs sha512_generic sha256_generic sha1_generic ecb cesa_ocf_drv(P) cesa_dev cryptodev(P) ocf(P) chainiv des_generic crc32c eseqiv krng ansi_cprng rng aes_generic md5 cbc cryptomgr pcompress aead crypto_hash crypto_blkcipher crypto_wq crypto_algapi cpufreq cpufreq_stats freq_table dm_snapshot crc_itu_t crc_ccitt quota_v2 quota_tree usbcore sg psnap llc ipv6
[ 50.270000] CPU: 0 Tainted: P W (2.6.32.12 #2668)
[ 50.270000] PC is at __gpio_set_value+0x18/0x34
[ 50.270000] LR is at SYNO_CTRL_INTERNAL_HDD_LED_SET+0xc8/0xfc
[ 50.270000] pc : [<c0255c84>] lr : [<c00f4664>] psr: 60000013
[ 50.270000] sp : c62c3e98 ip : c62c3ea8 fp : c62c3ea4
[ 50.270000] r10: 00000000 r9 : c62c2000 r8 : beaeac48
[ 50.270000] r7 : 00000000 r6 : c03e9848 r5 : 00000001 r4 : 00000000
[ 50.270000] r3 : 00000000 r2 : 00000001 r1 : 00000001 r0 : 000000ff
[ 50.270000] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 50.270000] Control: 0005397f Table: 06288000 DAC: 00000015
[ 50.270000] Process scemd (pid: 2513, stack limit = 0xc62c2270)
[ 50.270000] Stack: (0xc62c3e98 to 0xc62c4000)
[ 50.270000] 3e80: c62c3ec4 c62c3ea8
[ 50.270000] 3ea0: c00f4664 c0255c7c beaeac48 beaeac48 00000005 00000000 c62c3ef4 c62c3ec8
[ 50.270000] 3ec0: bf23af94 c00f45ac c62c3f0c c62c3ed8 c01575c8 c0157134 40024000 00000000
[ 50.270000] 3ee0: beaeac48 c0084b0a c62c3f0c c62c3ef8 c01780b4 bf23aab8 c407cd20 beaeac48
[ 50.270000] 3f00: c62c3f7c c62c3f10 c01789f8 c0178090 c5decc80 00000000 c5decc80 c5e99650
[ 50.270000] 3f20: c62c3f44 c62c3f30 c015938c c016461c c5decc80 c4c6bc80 c62c3f84 c62c3f48
[ 50.270000] 3f40: c0159f04 c0159338 40023000 c44af980 00000006 00000000 00000005 beaeac48
[ 50.270000] 3f60: c0084b0a c407cd20 c002c0e8 00000000 c62c3fa4 c62c3f80 c0178a9c c0178400
[ 50.270000] 3f80: c015b180 00000000 00000001 00045f8c beaeacdc 00000036 beaeac5c c62c3fa8
[ 50.270000] 3fa0: c002bf40 c0178a6c 00000001 00045f8c 00000005 c0084b0a beaeac48 00000005
[ 50.270000] 3fc0: 00000001 00045f8c beaeacdc 00000036 00000000 00045df8 beaeae84 beaeac5c
[ 50.270000] 3fe0: 000000cf beaeac48 00020564 406bab3c 20000010 00000005 4098de60 ffffffd0
[ 50.270000] [<c0255c84>] (__gpio_set_value+0x18/0x34) from [<c00f4664>] (SYNO_CTRL_INTERNAL_HDD_LED_SET+0xc8/0xfc)
[ 50.270000] [<c00f4664>] (SYNO_CTRL_INTERNAL_HDD_LED_SET+0xc8/0xfc) from [<bf23af94>] (synobios_ioctl+0x4ec/0x99c [ds211j_synobios])
[ 50.270000] unwind: Index not found bf23af94
[ 50.270000] Code: e59f3020 e1a02001 e7933180 e24cb004 (e593102c)
[ 50.280000] ---[ end trace 358c2d4f4263e653 ]---
Segmentation fault
:: Failed to start scemd. Reboot and get into steel plan or network install mode. ... [ !! ]
[ 52.480000] findhostd uses obsolete (PF_INET,SOCK_PACKET)
[ 53.490000] eth0: no IPv6 routers present
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to[ 59.380000] md: md0 in immediate safe mode
all processes
[ 59.380000] md: md1 in immediate safe mode
Unmounting all file systems.
Unmounting /proc/bus/usb ...
Unmounting /sys ...
Unmounting /dev/pts ...
Unmounting /tmp ...
Unmounting / ...
Unmounting / ...
All file systems unmounted.
Requesting system reboot
[ 65.870000] md: stopping all md devices.
[ 65.870000] md: md1 switched to read-only mode.
[ 65.890000] md: md0 switched to read-only mode.
[ 66.890000] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[ 67.110000] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 67.130000] Restarting system.
ûþ
__ __ _ _
| \/ | __ _ _ ____ _____| | |
| |\/| |/ _` | '__\ \ / / _ \ | |
| | | | (_| | | \ V / __/ | |
|_| |_|\__,_|_| \_/ \___|_|_|
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__| ** LOADER **
** MARVELL BOARD: Synology Disk Station LE
U-Boot 1.1.4 (Jul 14 2010 - 20:36:08) Marvell version: 3.4.4
U-Boot code: 00600000 -> 0067FFF0 BSS: -> 0068B3B4
Soc: 88F6281 A1 (DDR2)
CPU running @ 1200Mhz L2 running @ 480Mhz
SysClock = 400Mhz , TClock = 200Mhz
DRAM CAS Latency = 6 tRP = 6 tRAS = 18 tRCD=6
DRAM CS[0] base 0x00000000 size 128MB
DRAM Total size 128MB 16bit width
[4096kB@f8000000] Flash: 4 MB
Addresses 8M - 0M are saved for the U-Boot usage.
Mem malloc Initialization (8M - 7M): Done
Using default environment
CPU : Marvell Feroceon (Rev 1)
Streaming disabled
Write allocate disabled
USB 0: host mode
PCI 0: PCI Express Root Complex Interface
PEX interface detected Link X1
Synology Model: DS411j
Fan Status: Good
Net: egiga0 [PRIME], egiga1
Hit any key to stop autoboot: 0
## Booting image at f8080000 ...
Bad Magic Number
Marvell>>
Nick
... [ OK ]
... [ OK ]
... [ OK ]
Interrupt:11
kernel.panic = 3
Pass CheckUser
Pass CheckGroup.
start findhostd
:: Starting scemd
Segmentation fault
all processes
Unmounting /sys ...
Unmounting /tmp ...
Unmounting / ...
Unmounting / ...
ûþ
__ __ _ _
_ _ ____ _
| | | | | __ ) ___ ___ | |_
Streaming disabled
USB 0: host mode
Fan Status: Good
Bad Magic Number
Marvell>>
Nick
