nginxproxymanager vs proxy von der Synology
daschmidt94
17. Mai 2020
hier ist meine
YAML:
version: "2.1"
services:
  crowdsec:
    image: crowdsecurity/crowdsec:latest
    container_name: crowdsec
    environment:
      - GID=0
      - COLLECTIONS=crowdsecurity/nginx crowdsecurity/http-cve crowdsecurity/whitelist-good-actors
      - CUSTOM_HOSTNAME=debian
    volumes:
      - /home/docker/swag/crowdsec/config:/etc/crowdsec:rw
      - /home/docker/swag/crowdsec/data:/var/lib/crowdsec/data:rw
      - /home/docker/swag/config/log/nginx:/var/log/swag:ro
      - /home/docker/swag/config/log/syslog:/var/log/syslog:ro
      - /var/log:/var/log/host:ro
    restart: unless-stopped
    logging:
      driver: syslog
      options:
        syslog-address: "udp://192.168.178.199:514"
        tag: 'crowdsec'
  swag:
    image: linuxserver/swag:latest
    container_name: swag
    cap_add:
      - NET_ADMIN
    environment:
      - PUID=0
      - PGID=0
      - TZ=Europe/Berlin
      - DOCKER_MODS=linuxserver/mods:swag-dashboard|linuxserver/mods:swag-auto-reload|linuxserver/mods:swag-maxmind|linuxserver/mods:swag-crowdsec
      - CROWDSEC_API_KEY=xxxxxx
      - CROWDSEC_LAPI_URL=http://crowdsec:8080
      - MAXMINDDB_LICENSE_KEY=xxx
      - URL=xxx.at
      - SUBDOMAINS=wildcard
      - VALIDATION=dns #WIE DAS LE ZERTIFIKAT GEHOLT WERDEN SOLL
      - DNSPLUGIN=cloudflare #DOMAIN ANBIETER
      - PROPAGATION=30
      - EMAIL=xxxxxx@xxxx.at
    volumes:
      - /home/docker/swag/config:/config
    ports:
      - 443:443
      - 80:80
      - 81:81
    dns:
      - 192.168.178.222
    logging:
      driver: syslog
      options:
        tag: 'swag'
  tailon:
    ports:
      - '5002:80'
    container_name: tailon
    volumes:
      - /home/docker/swag/config/log/syslog:/log/syslog
      - /home/docker/swag/config/log/nginx/access.log:/log/nginx/access.log
      - /home/docker/swag/config/log/nginx/unauthorized.log:/log/nginx/unauthorized.log
      - /home/docker/swag/config/log/nginx/error.log:/log/nginx/error.log
    image: ghcr.io/kmlucy/docker-tailon
  #WENN DAS NICHT VERWENDET WIRD, DANN MUSS DER TEIL MIT "loggin:" entfernt werden
  syslog-ng:
    image: lscr.io/linuxserver/syslog-ng:latest
    container_name: syslog-ng
    environment:
      - PUID=0
      - PGID=0
      - TZ=Europe/Berlin
    volumes:
      - /home/docker/docker/swag/syslog:/config
      - /home/docker/docker/swag/config/log/syslog:/var/log #optional
    ports:
      - 514:5514/udp
      - 601:6601/tcp
      - 6514:6514/tcp
  cloudcmd:
    user: "0:0"
    container_name: cloudcmd
    ports:
      - 9080:8000
    volumes:
      - /home/docker/swag/cloudcmd:/root
      - /home/docker/swag/config:/mnt/swag
    image: coderaiser/cloudcmd
    logging:
      driver: syslog
      options:
        tag: 'cloudcmd'
alexhell
13. Mai 2021
Starten beide Container richtig? Also mal in die Logs von beiden geguckt? So auf anhieb sehe ich nichts.... Mich wundert aber wieso du es als root ausführst. Bin mir nicht zu 100% sicher, aber glaube da könnte ein Container meckern.
Ulfhednir
26. Aug 2013
Danke! Jetzt muss ich mich nicht mehr selbst bei Crowdsec registrieren, da ich jetzt einen API-Key habe.
Unabhängig davon würde ich SWAG erstmal in der Minimalkonfiguration installieren und auch maxmind erstmal weglassen.
Wenn du verstanden hast, wie die Proxyfiles konfiguriert werden müssen, dann solltest du dich weitertasten.
Alles andere macht rein didaktisch überhaupt keinen Sinn.
Reaktionen: alexhell
alexhell
13. Mai 2021
Da stimme ich @Ulfhednir zu. Ich würde alles entfernen was nicht notwendig ist. Also Logging, maxmind, Crowdsec und alle anderen Container bis auf SWAG. Wenn SWAG richtig funktioniert, sprich du kannst deinen Dienst aufrufen, dann würde ich nach und nach mehr einbauen. Und ja entfern lieber alle API Keys und auch deine Email.
Ulfhednir
26. Aug 2013
Dann warte ich halt, bis du das nächste mal den API-Key hier im Forum postest. 🤡
P.S.: Ich wollte dich nur darauf aufmerksam machen, dass Konfigurationsdaten immer mit Obacht behandelt werden sollten.
Crowdsec tangiert mich derzeit nicht, da ich eine "echte" Firewall mit vergleichbarer Funktion vorgeschaltet habe. Du solltest den Key aber trotzdem ändern. Der Feind liest bekanntermaßen mit.
Reaktionen: daschmidt94
daschmidt94
17. Mai 2020
ab und zu geschehen doch wunder :D
in der vaultwardenconfig hab ich nach der ip ein ; vergessen -.-
alexhell
13. Mai 2021
Funktioniert jetzt das Routing richtig? Dann würde ich mal die vaultwarden config nochmal neu kopieren und es richtig ausfüllen und dann testen, ob alles funktioniert. Gerade mit den Syncs..... Und danach langsam weiter aufbauen wenn du noch Lust hast.
daschmidt94
17. Mai 2020
ja Funktioniert jetzt alles von deinem Stack bis auf
 [error] 649#649: *1 [lua] crowdsec.lua:459: Allow(): [Crowdsec] bouncer error: Http error 403 while talking to LAPI (http://crowdsec:8080/v1/decisions?ip=192.168.178.79), client: 192.168.178.79, server: _, request: "GET / HTTP/1.1", host: "192.168.178.220:81"
alexhell
13. Mai 2021
Dann funktioniert Crowdsec noch nicht richtig.... Ist da mehr zu finden in dne Logs von Crowdsec? zur not neustarten und logs prüfen.
daschmidt94
17. Mai 2020
leider müllt der den ganzen log im Portainer voll
daschmidt94
17. Mai 2020
nicht wirklich diese Fehler sind mir aufgefallen:
time="25-08-2023 09:04:58" level=error msg="while fetching bouncer info: select bouncer: ent: bouncer not found: unable to query" ip=172.19.0.5
time="25-08-2023 09:16:10" level=error msg="while fetching bouncer info: select bouncer: ent: bouncer not found: unable to query" ip=172.19.0.5
time="25-08-2023 09:24:28" level=error msg="while fetching bouncer info: select bouncer: ent: bouncer not found: unable to query" ip=172.19.0.5
und in der Weboberfläche folgendes:
alexhell
13. Mai 2021
So sieht es im Dasboard bei mir auch aus. Das ist ok....
Öffne mal zwei Tabs. Einmal die Logs und in dem anderen Tab Crowdsec neustarten. Und poste dann mal den Auszug.
alexhell
13. Mai 2021
Da kommt can't load CAPI credentials from '/etc/crowdsec//online_api_credentials.yaml. Hast du auf online einen Account erstellt?
daschmidt94
17. Mai 2020
Hab mich registriert und einen Api Key bekommen. Reicht das nicht?
Edit: die Datei ist bei mir auch leer
alexhell
13. Mai 2021
MAn muss online keinen Account machen. Das war nur die Frage, ob du es hast. Ich würde den kompletten Crowdsec Ordner löschen. Den API Key bei SWAG entfernen und neu starten. Crowdsec starten und bouncer registrieren, damit du einen API Key bekommst und dann den einfügen und gucken ob es funktioniert. Irgendwas ist bei dir durcheinander.
