May 13 22:52:56 scemd: scemd: power button pressed, ret = 0
May 13 22:52:56 scemd: SCEMD: Shutdown the system.
May 13 22:52:56 kernel: [/etc/synolog.conf] opened by pid 1160 [u:(/usr/syno/bin/scemd), comm:(scemd)]
May 13 22:52:56 postfix/postfix-script[2651]: fatal: the Postfix mail system is not running
May 13 22:53:01 root: /usr/syno/etc/rc.d/S98findhostd.sh stop findhostd
May 13 22:53:01 findhostd: si_pid=[2742], process=[/bin/sh]
May 13 22:53:01 findhostd: si_ppid=[2741], process=[sh]
May 13 22:53:01 findhostd: findhostd.c:52(FHOSTDExit) exit on signal[10]
May 13 22:56:23 kernel: Marvell Gigabit Ethernet Driver 'egiga':
May 13 22:56:23 kernel: o Ethernet descriptors in DRAM
May 13 22:56:23 kernel: o DRAM SW cache-coherency
May 13 22:56:23 kernel: o Checksum offload enabled
May 13 22:56:23 kernel: o Loading network interface 'egiga0' as eth0
May 13 22:56:23 kernel: o Radom MAC address (da steht normal was :) )
May 13 22:56:23 kernel: drivers/scsi/sata_sil.c (124) Delay 20 seconds to wait for disk ready.
May 13 22:56:23 kernel: drivers/scsi/sd.c (1713) Internal disk with bus id: 0
May 13 22:56:23 kernel: Amd/Fujitsu Extended Query Table at 0x0040
May 13 22:56:23 kernel: DS406-0: Swapping erase regions for broken CFI table.
May 13 22:56:23 kernel: Mac1: (da steht normal auch was :) )
May 13 22:56:23 kernel: vender Mac1 checksum error ucSum:0x00 Buf:0x00 Sum:0.
May 13 22:56:23 kernel: Vender partition MacNum:1 retlen:128
May 13 22:56:23 kernel: Serial Number: (die kann ich nu leider hier nicht hinschreiben)
May 13 22:56:23 kernel: raid6: int32x1 29 MB/s
May 13 22:56:23 kernel: raid6: int32x2 45 MB/s
May 13 22:56:23 kernel: raid6: int32x4 51 MB/s
May 13 22:56:23 kernel: raid6: int32x8 48 MB/s
May 13 22:56:23 kernel: raid6: using algorithm int32x4 (51 MB/s)
May 13 22:56:23 kernel: arm4regs : 429.200 MB/sec
May 13 22:56:23 kernel: 8regs : 368.800 MB/sec
May 13 22:56:23 kernel: 32regs : 513.200 MB/sec
May 13 22:56:23 kernel: raid5: using function: 32regs (513.200 MB/sec)
May 13 22:56:23 kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
May 13 22:56:23 kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
May 13 22:56:23 kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
May 13 22:56:23 kernel: VFS: Mounted root (ext2 filesystem).
May 13 22:56:23 kernel: ds107+_synobios: module license 'Synology Inc.' taints kernel.
May 13 22:56:23 kernel: Brand: Synology
May 13 22:56:23 kernel: Model: DS-107+
May 13 22:56:23 kernel: synobios: unload
May 13 22:56:23 kernel: VFS: Mounted root (ext3 filesystem).
May 13 22:56:30 scemd: scemd.c:97 fan_type=4, led_type=2, raid_type=2, dual_power_type=1, auto_poweron_type=1
May 13 22:56:30 scemd: modules/disk_hibernation.c:86 Force hibernation enable, idle minutes 10
May 13 22:56:30 synoprint: printer_device_open.c:16 bad parameter.
May 13 22:56:30 synousbdisk: RCClean succeeded
May 13 22:56:34 ddnsd: main(ddnsd.c:1729): not enable DDNS, shutdown daemon
May 13 22:56:39 kernel: Got empty serial number. Generate serial number from product.
May 13 22:56:40 syno_hdd_util: Model:[ST3500320NS], Firmware:[SN06], S/N:[5QM12GLA] in [/dev/sda] is not ssd
May 13 22:56:54 synorcd: hw_raytac.c (126) failed to open /dev/usb/hiddev5 (No such device).
May 13 22:56:55 dms: _ReloadSetting(98) Buffer size [] is a wrong value and consider default buffer size: 8192
May 13 22:57:37 afpd[2552]: NemesisStation:AFPServer@* started on 65280.68:128 (2.0.1)
May 13 23:31:53 scemd: SCEMD: disk 1 wake up from hibernation
May 13 23:52:18 scemd: SCEMD: disk 1 wake up from hibernation
May 14 00:00:21 ntpdate: Failed to set date or time from NTP server.
May 14 00:00:42 synomail: smtp.c (369) Failed to connect to smtp.web.de:25
May 14 00:00:42 synomail: mail_smtp_error_call_back.c (20) Failed to send email. (Failed to resolve host address.)
May 14 00:46:23 scemd: SCEMD: disk 1 wake up from hibernation
May 14 00:46:30 scemd: SCEMD: disk 1 wake up from hibernation
May 14 01:18:54 scemd: SCEMD: disk 1 wake up from hibernation
May 14 01:19:01 scemd: SCEMD: disk 1 wake up from hibernation
May 14 01:38:13 scemd: SCEMD: disk 1 wake up from hibernation
May 14 01:38:20 scemd: SCEMD: disk 1 wake up from hibernation
May 14 02:18:04 scemd: SCEMD: disk 1 wake up from hibernation
May 14 02:49:13 scemd: SCEMD: disk 1 wake up from hibernation
May 14 02:49:20 scemd: SCEMD: disk 1 wake up from hibernation
May 14 03:14:54 scemd: SCEMD: disk 1 wake up from hibernation
May 14 03:15:01 scemd: SCEMD: disk 1 wake up from hibernation
May 14 03:36:58 scemd: SCEMD: disk 1 wake up from hibernation
May 14 03:37:05 scemd: SCEMD: disk 1 wake up from hibernation
May 14 03:58:31 scemd: SCEMD: disk 1 wake up from hibernation
May 14 04:53:13 scemd: SCEMD: disk 1 wake up from hibernation
May 14 04:53:20 scemd: SCEMD: disk 1 wake up from hibernation
May 14 05:10:54 scemd: SCEMD: disk 1 wake up from hibernation
May 14 05:11:01 scemd: SCEMD: disk 1 wake up from hibernation
May 14 05:26:54 scemd: SCEMD: disk 1 wake up from hibernation
May 14 05:27:01 scemd: SCEMD: disk 1 wake up from hibernation
May 14 05:58:41 scemd: SCEMD: disk 1 wake up from hibernation
May 14 06:24:08 scemd: SCEMD: disk 1 wake up from hibernation
May 14 06:24:15 scemd: SCEMD: disk 1 wake up from hibernation
May 14 06:40:08 scemd: SCEMD: disk 1 wake up from hibernation
May 14 06:40:15 scemd: SCEMD: disk 1 wake up from hibernation
May 14 07:31:28 scemd: SCEMD: disk 1 wake up from hibernation
May 14 07:31:35 scemd: SCEMD: disk 1 wake up from hibernation
May 14 08:13:23 scemd: SCEMD: disk 1 wake up from hibernation
May 14 08:13:30 scemd: SCEMD: disk 1 wake up from hibernation
