Notification Forwarder zum Weiterleiten von DSM-Benachrichtigungen
23.06.2012 - Net Notifier 0.8-081 beta
  • Problem "TOASTY meldet immer OK, auch wenn Verbindung zum Ziel fehlschlägt" wurde behoben
  • Protokoll NMWP - Notify my Windows Phone (https://notifymywindowsphone.com/) zur Auswahl hinzugefügt
@B3rt: can you test this for me?
Sure i can test :)
- Toasty works now, no error in interface and i also get the test message on my phone now (very NICE!!!!!)
- 'Protokoll NMWP' is not present in the protocol pulldown list, have no idea how to test this.
Sure i can test :)
Fine, thanks
Please clear your browsercache, i checked the code, nmwp is definitly in the list, between nma and notifio
Fine, thanks
Indeed that works.
I confirm nmwp works also!
No error in the interface and i received the test message on my phone aswell, very very nice :)
Maybe a tip..
Remove or prefill the HOST field for these protocols or make a popup that states that the value entered in this field is not used.
I was not sure what to enter here exactly the first time, could not find info what to enter exactly, maybe you can add this in the help part.
Indeed that works.
Great news, thx for your help :)
Maybe a tip..
The field can not removed, because it is a part of the grid. Perhaps a tooltip/popup or whatelse, i think about it.
All protocols for smartphones have the provider api url hardcoded in the code class. The user not need to know which url he must use, he must only know the api-key/deviceID for the device as required value. A table in the first post of this thread tells about input specials in the last row, but only in german.
Thx.
Got a questin about usage of the addon.
Can i specify for say in an website/addon (example couchpotato server) as notification "growl"
Then specify hostname: ip of my NAS or localhost (if run on nas)
port: dunno, 80 or 5000?!?!
password: also no idea what...
My question really is: can "network notifier" be used as a growl notifier server?
If so this would be great, in almost all website apps you can specify "growl" as notify client and you could receive all these message on alomost each platform using this app.
So is this possible if so what do i enter as "hostname", "port" and "password" fields when entering growl details.
interested to push syno notifications via NMA on my phone, I installed Network Notifier on my Syno. Atfer install I add NMA connector and it works fine using the Test button but I was unable to find the way to forward syno notifications. My german is far away and I should have miss something somewhere... Could you help, please ? . Sorry to write in bad english but be sure it's better than my german ;-)
Thanks
Jean Marc
The forward ist done, if you select a user (e.g. admin) to forward notifications for. If your test connection was fine, than all be done. Wait for a event that sends a dsm notification and you get it always on your phone via nma.
if not clear, post a screenshot of your config row that you used for testing.
Thx.
not yet, but i'm working on it :)
Thanks Qtip.
yes it works and sends system events. I got a notification this morning telling me my network backup was ok ;-) So, now I'm wondering if there is a way to forward Surveillance Station notifications ?
Jean Marc
Thanks Qtip.
Jean Marc
Does the Surveillance Station sending notifications? If not, you can tell it synology that they include some.
Hello,
I have found this thread since i own a Synology and i have SickBeard installed. I have a few question and i hope you can answer them
Notifio (starting post) shouldn't this be "http://notifo.com" ?
I would like to use this for 2 things:
1) Sickbeard (private); i don't think i have to use this tool for this, right?
2) Webshop: If someone places a new order i would like to have a notification. Can this code be used for such a use case?
Hello,
Yes your're right, i don't know why i asume the name is notifio.
1) no, you need a growl server, which is currently in development
2) no, this tool can't help you, see 1) or you push the message from your webshop directly to your phone with one of the available protocols e.g. prowl or nma
Notification forwarder 0.8-084 beta
03.09.2012 - Notification forwarder 0.8-084 beta
  • Pflicht für Passwortfeld wurde entfernt
  • Name in "Notification forwarder" geändert
  • Notification types für Growl-UDP wurden angepasst
  • Hostname nun hinter dem Anwendungsnamen; betrifft nur Neuinstallationen (z.B. Anwendung@hostname)
Irgendwie will das bei mir nicht funktionieren oder ich bin zu doof.
Ich habe zuerst die Bibliothek installiert. Webstation läuft sowieso! Kann mir auch die php.ini angucken
Anschließend habe ich den Notification-forwarder installiert. Ohne Fehlermeldungen. Hat sich auch direkt gestartet.
Allerdings kann ich nirgendwo jetzt das Center finden und die Bibliothek steht irgendwie auf angehalten. Ich habe aber keine Option die Bibliothek zu starten geschweige denn den Notification-forwarder anzuhalten.
Browser Cache habe ich auch schon gelöscht. Muss die NAS ggf. neu gestartet werden?
Vielen Dank.
UPDATE: Ich war zu blöd. Man muss unter Anwendungsberechtigungen noch den User zuordnen.
Nun habe ich allerdings das Problem, dass keine Nachrichten auf meinem Mac (OS X 10.8, Growl 2.0) ankommen.
- An der Synology in der Firewall den Quellport 23053 als Freigabe eingetragen
- Growl auf Netzwerknachirchten hören gestellt
Gesendet wird von User Admin an die IP-Adresse meine Macs. Bei Passwort steht im Center das gleich wie bei Server-Kennwort im Bild.
Wenn ich auf Test drücke dann graut sich das Notification Center aus und ich bekomme nichts zudem kann ich nur wieder ins Center, wenn ich es neu öffne.
Info: Synology DS412+ mit DSM 4.1-2647 auf 4x3TB im SHR-Raid
Mit Notification Center meinst du bestimmt den Notification forwarder ;)
Welche Protokoll/Verschlüsselung/Hash Einstellungen hast du im Notification forwarder gewählt?
hm, diese Kombi funktioniert bei mir, aber du hast ja einen Mac. Kann das hier leider nicht reproduzieren, da kein Mac zur Verfügung. Versuche mal andere Kombinationen. Evtl. hilft auch mal ohne Passwort zu senden und/oder das Passwort auf dem Mac Growl zu ändern/löschen und dann wieder zu setzen. Growl 2.0 hat ja doch eine Menge Änderungen, kann gut sein das es da ein paar Unzulänglichkeiten in Verbindung mit meiner verwendeten PHP Bibliothek gibt.
Ich suche mal weiter im Netz nach ähnlichem Verhalten mit Growl 2.0
Problem met TOASTI und NMWP
Wen ich einen bericht sende sind + zeigen zwichen den worten:
Ich entfange: "Test+connection", es muste sein: "Tes connection".
Auch den tekst ist mit + zeigen.
Kan das geandert werden?
Ich gebauche selbs auch einen API in meinen script, hier sind keine + zeigen, es mus irgendwo passieren in diese software.
Mochte auch gern ein image mit senden mit TOASTI, wie wirkt dass?
Nomal gibt man einen value mit &image=http://link.to.image und es wirdt gezeigt in toasti.
Mit freundliche grussen!
ich habe das grad eben mal überprüft und habe das gleiche Ergebnis. Da ich aber kein Windows Phone besitze, konnte ich bisher nur sehen was rausgesendet wird und nie wie es auf dem Gerät ankommt. Ich glaube ich war zu voreilig mit meinem urlencode in der NMWP und TOASTY api.
Wenn du es schnell selbst entfernen möchtest und dir das zutraust, dann kannst du folgendes tun:
  • gehe in das Verzeichnis /volume1/@appstore/net_notifier/include/
  • öffne die Datei class.nmwp.php oder class.toasty.php mit einem geeigneten Editor
  • entferne die beiden urlencode(), aber nicht das utf8_encode()
Ich werde das in der kommnden Version berücksichtigen
Da TOASTY (ausser Growl) das einzige Protokoll ist, was auch ein Image mitsenden kann, hielt ich es bisher nicht für notwendig. Ich kann dir nur anbieten, das ich ein vordefiniertes Icon, abhängig von der Art der Meldung (INFO, OK, ERR, WARNING) mitschicken kann. Eine individuelle Möglichkeit gibt es zur Zeit nicht. Du müßtest das dann aber Testen, da ich wie schon erwähnt kein Windows Phone besitze.
